利用TIM2_CH2(端口PA1,stm32f407开发板)进行PWM输入捕获时,不断进入TIM2_IRQHandler中断,请各位专家帮忙分析分析
1、TIM2_CH2的有个设置如下:
void TIM2_Configuration(void)
TIM_ICInitTypeDef TIM_ICInitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); //TIM2时钟使能
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //使能PORTA时钟
GPIO_PinAFConfig(GPIOA,GPIO_PinSource1,GPIO_AF_TIM2); //PA1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //GPIOA1
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA1
TIM_TimeBaseStruct.TIM_Period=0xFFFFFFFF;
TIM_TimeBaseStruct.TIM_Prescaler=0;
TIM_TimeBaseStruct.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStruct);
TIM_ICInitStructure.TIM_Channel=TIM_Channel_2;//选择TIM2_CH2,选择输入端IC2映射到TI2上
TIM_ICInitStructure.TIM_ICPolarity=TIM_ICPolarity_Rising;//上升沿捕获
TIM_ICInitStructure.TIM_ICSelection=TIM_ICSelection_DirectTI;//映射到TI2上(TIM2映射至IC2--tuhongmao)
TIM_ICInitStructure.TIM_ICPrescaler=TIM_ICPSC_DIV1;//在捕获输入上每探测到一个边沿就执行一次捕获
TIM_ICInitStructure.TIM_ICFilter=0;//滤波设置,经历几个周期跳变认定波形稳定
//(采样高电平,只有连续采集到N个电平是高电平才认为是有效的,否则低于N个时认为是无效的N取0x0-0xF)
TIM_PWMIConfig(TIM2,&TIM_ICInitStructure);//以上是输入捕获设置
TIM_SelectInputTrigger(TIM2,TIM_TS_TI2FP2);//选择滤波后的TI2FP2输入作为触发源,触发下面程序的复位
TIM_SelectSlaveMode(TIM2,TIM_SlaveMode_Reset);//从模式控制器被设置为复位模式-选中的触发信号上升沿重新
//初始化计数器并产生一个更新信号(上升沿一到,TIM2->CNT被清零,每次上升沿来到,CNT都会被清零)
//从控制器默认的通道是否为TIM2_CH1 tuhongmao 20191015
TIM_SelectMasterSlaveMode(TIM2,TIM_MasterSlaveMode_Enable);//启动定时器的被动触发
TIM_ITConfig(TIM2,TIM_IT_CC2,ENABLE);//捕获中断打开
TIM_ClearFlag(TIM2,TIM_IT_CC2);//清除标志位
TIM_Cmd(TIM2,ENABLE);//使能定时器2
2、中断设置与处理函数如下:
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//中断处理程序
void TIM2_IRQHandler(void)
static u16 count=0;
if(TIM_GetITStatus(TIM2,TIM_IT_CC2)!= RESET)
float IC2Value=0;
float DutyCycle=0;
float Frequency=0;
float pulse=0;
TIM_ClearITPendingBit(TIM2,TIM_IT_CC2);
IC2Value=(float)TIM_GetCapture2(TIM2);//获取CCR2的值
pulse=(float)TIM_GetCapture1(TIM2);//获得CCR1的值
if(IC2Value !=0)
DutyCycle=pulse/IC2Value;
Frequency=(float)84000000/IC2Value;
duty=(u32)(DutyCycle*(u32)100);
freq=Frequency/((float)1000);
count++;
if(count>=10000)
count=0;
printf("IC2Value is %f \r\n",IC2Value);
printf("pulse is %f \r\n",pulse);
duty=0;
freq=0;
3、主程序Main.c如下:
int main(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
delay_init(168); //初始化延时函数
uart_init(115200);//初始化串口波特率为115200
TIM2_Configuration();
NVIC_Configuration();
4、串口打印结果如下:
IC2Value is 2.000000
pulse is 1.000000
pulse is 0.000000
pulse is 0.000000
pulse is 1.000000
pulse is 1.000000
pulse is 1.000000
pulse is 1.000000
(每进入10000次中断,再串口打印消息)
其他未做任何设置,端口也没有输入PWM信号,但是不断进入TIM2_IRQHandler中断,请帮忙分析分析。
