查看: 4131|回复: 3
我的这个单片机程序为什么按键按下后没有作用?
ID:521078 发表于 2019-10-19 20:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
25黑币
Keil4编写环境:A/D数模转换和按键应用操作显示到Lcd1602上,子程序Lcd1602.c,keyboard.c,I2C.c程序略,跪求主程序
程序要求实现:按上键查询设定的电压值上下限
                      按下键查询当前的电压值(当前电压值是滑动变阻器所配置的电压值)
                      数据采集器件用的是PCF8591测AIN0的值
为什么我的主函数这样写,在51液晶上按上下键没有任何显示,跪求主函数,开发板是金三角开发板
是Lcd如何通过按键进行翻页操作,这个程序应该怎么写,跪求来个大神,写下这个程序
#include <reg52.h>
sbit BUZZ = P1^6;
bit flag300ms = 1;
bit enBuzz = 0;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
unsigned int CountDown = 0;
void ConfigTimer0(unsigned int ms);
unsigned char GetADCValue(unsigned char chn);
void ValueToString(unsigned char *str, unsigned char val);
extern void I2CStart();
extern void I2CStop();
extern void KeyScan();
extern void KeyDriver();
extern unsigned char I2CReadACK();
extern unsigned char I2CReadNAK();
extern bit I2CWrite(unsigned char dat);
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
    EA = 1;
   ConfigTimer0(10);
   InitLcd1602();
   LcdShowStr (0, 0, "moli");
     KeyDriver();
unsigned char GetADCValue (unsigned char chn)
      unsigned char val;
     I2CStart();
    if (!I2CWrite (0x48<<1))
        I2CStop();
        return 0;
I2CWrite (0x40 | chn);
I2CStart();
I2CWrite ((0x48<<1) | 0x01);
I2CReadACK();
val = I2CReadNAK();
I2CStop();
return val;
  val = (val * 25) / 55;
  str[0] = (val/10) + '0';
  str[1] = '.';   //С????
  str[2] = (val%10) + '0';
  str[3] = 'V';
  str[4] = '\0';
void KeyTaAction()
    unsigned char val;
    unsigned char str[10];
    InitLcd1602();
    LcdShowStr (0, 0, "TABANXINHAO");
     while (1)
         if (flag300ms)
         flag300ms = 0;
        val = GetADCValue(0);
        ValueToString(str, val);
        LcdShowStr(0, 1, str);
      if (val >= 200)
         enBuzz = 1;
        if (enBuzz)
           BUZZ = ~BUZZ;
          BUZZ = 1;
void KeyAction (unsigned char keycode)
   if(keycode == 0x26)
      KeyTaAction();
  else if (keycode == 0x28)
     LcdShowStr (0, 0, "MAX");
     LcdShowStr (0, 1, 2^5);
     LcdShowStr (6, 0, "MIN");
     LcdShowStr (6, 1, 0^0);
    unsigned long tmp;
tmp = 11059200 / 12;
tmp = (tmp * ms) / 1000;
tmp = 65536 - tmp;
tmp = tmp + 12;
T0RH = (unsigned char)(tmp >> 8);
T0RL = (unsigned char)tmp;
TMOD &= 0xF0;
TMOD |= 0x01;
TH0 = T0RH;
TL0 = T0RL;
ET0 = 1;
TR0 = 1;
void InterruptTimer0() interrupt 1
    static unsigned char tmr300ms = 0;
TH0 = T0RH;
TL0 = T0RL;
tmr300ms++;
if (tmr300ms >= 30)
     tmr300ms = 0;
  flag300ms = 1;
LCD程序
#include <reg52.h>
#define LCD1602_DB P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^5;
void LcdWaitReady()
  unsigned char sta;
  LCD1602_DB = 0xFF;
  LCD1602_RS = 0;
  LCD1602_RW = 1;
  do{
      LCD1602_E = 1;
   sta = LCD1602_DB;
   LCD1602_E = 0;
  }while (sta & 0x80);
void LcdWriteCmd (unsigned char cmd)
   LcdWaitReady();
   LCD1602_RS = 0;
   LCD1602_RW = 0;
   LCD1602_DB = cmd;
   LCD1602_E = 1;
   LCD1602_E = 0;
void LcdWriteDat(unsigned char dat)
  LcdWaitReady();
  LCD1602_RS = 1;
  LCD1602_RW = 0;
  LCD1602_DB = dat;
  LCD1602_E = 1;
  LCD1602_E = 0;
void LcdSetCursor(unsigned char x, unsigned char y)
  unsigned char addr;
  if (y == 0)
     addr = 0x00 + x;
     addr = 0x40 + x;
   LcdWriteCmd(addr | 0x80);
void LcdShowStr (unsigned char x, unsigned char y,
                 unsigned char *str)
  LcdSetCursor(x, y);
  while (*str != '\0')
    LcdWriteDat (*str++);
void LcdAreaClear(unsigned char x,unsigned char y, unsigned char len)
  LcdSetCursor(x, y);
  while (len--)
    LcdWriteDat(' ');
void LcdFullClear()
  LcdWriteCmd(0x01);
void InitLcd1602()
  LcdWriteCmd(0x38);
  LcdWriteCmd(0x0C);
  LcdWriteCmd(0x06);
  LcdWriteCmd(0x01);
keyboard程序
#include <reg52.h>
sbit KEY_IN_1 = P2^4;
sbit KEY_IN_2 = P2^5;
sbit KEY_IN_3 = P2^6;
sbit KEY_IN_4 = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char code KeyCodeMap[4][4] = {
    { '1',  '2',  '3', 0x26 },
    { '4',  '5',  '6', 0x25 },
    { '7',  '8',  '9', 0x28 },
    { '0', 0x1B, 0x0D, 0x27 }
unsigned char pdata KeySta[4][4] = {
  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
extern void KeyAction(unsigned char keycode);
void KeyDriver()
    unsigned char i, j;
static unsigned char pdata backup[4][4] = {
for (i=0; i<4; i++)
    for (j=0; j<4; j++)
    if (backup[ i][j] != KeySta[ i][j])
        if (backup[ i][j] != 0)
        KeyAction(KeyCodeMap[ i][j]);
     backup[ i][j] = KeySta[ i][j];
void KeyScan()
    unsigned char i;
static unsigned char keyout = 0;
static unsigned char keybuf[4][4] = {
    {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
for (i=0; i<4; i++)
     if ((keybuf[keyout][ i] & 0x0F) == 0x00)
     KeySta[keyout][ i] = 0;
  else if ((keybuf[keyout][ i] & 0x0F) == 0x0F)
     KeySta[keyout][ i] = 1;
keyout++;
keyout &= 0x03;
switch(keyout)
     case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
  case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
  case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
  case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
  default: break;
I2C程序
#include <reg52.h>
#include <intrins.h>
#define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^7;
sbit I2C_SDA = P3^6;/
void I2CStart()
    I2C_SDA = 1;
I2C_SCL = 1;
I2CDelay();
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 0;
void I2CStop()
    I2C_SCL = 0;
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SDA = 1;
I2CDelay();
bit I2CWrite (unsigned char dat)
    bit ack;
unsigned char mask;
for (mask=0x80; mask!=0; mask>>=1)
    if ((mask&dat) == 0)
       I2C_SDA = 0;
       I2C_SDA = 1;
  I2CDelay();
  I2C_SCL = 1;
  I2CDelay();
  I2C_SCL = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
ack = I2C_SDA;
I2CDelay();
I2C_SCL = 0;
return (~ack);
    unsigned char mask;
unsigned char dat;
I2C_SDA = 1;
     I2CDelay();
  I2C_SCL = 1;
  if(I2C_SDA == 0)
      dat &= ~mask;
      dat |= mask;
  I2CDelay();
  I2C_SCL = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SCL = 0;
return dat;
     unsigned char mask;
  unsigned char dat;
  I2C_SDA = 1;
      I2CDelay();
   I2C_SCL = 1;
   if (I2C_SDA == 0)
       dat &= ~mask;
       dat |= mask;
   I2CDelay();
   I2C_SCL = 0;
   I2C_SDA = 0;
   I2CDelay();
   I2C_SCL = 1;
   I2CDelay();
   I2C_SCL = 0;
   return dat;
ID:616759 发表于 2019-10-20 13:17 | 只看该作者
你的KeyScan()函数在主程序中都没有出现,这个函数的意思是按键扫描,一般是用来检测按键是否被按下的,同时一般的按键扫描是放在一个大概1s的for循环中的,当然,写在while循环里就不用这个1s的for循环了。
ID:521078 发表于 2019-10-20 14:25 | 只看该作者
bai_yun_123 发表于 2019-10-20 13:17
你的KeyScan()函数在主程序中都没有出现,这个函数的意思是按键扫描,一般是用来检测按键是否被按下的, ...
嗯嗯,谢谢大哥的解答,我也发现了没写按键扫描了,我把按键扫描加上,现在lcd可以进行翻页操作,电压值都可以查询,但按上键我查当前值的时候,每次进去都进入了KeyTaAction()这个函数的while死循环,但再摁下键查询最大最小值就没有任何反应,我想过把while改成do while 还是实现不了这个电压值每300ms要检测,所以,我想问下这个问题怎么解答,谢谢,万分感谢
ID:616759 发表于 2019-10-20 17:30 | 只看该作者
不是while和do while的问题,这两个循环只是执行条件的先后问题,我看了keytaaction的函数,while(1)是个死循环,只要进去了,没有break,continue这种跳出循环的语句,那么就出不来,即死循环。把while括号里的条件改成你需要的条件, 比如:
while (flag300ms)
         flag300ms = 0;
      if (val >= 200)
         enBuzz = 1;
        if (enBuzz)
           BUZZ = ~BUZZ;
          BUZZ = 1;
当然,条件不一定对,因为后面有个flag300ms置零,所以这个循环只执行一次,至于执行多少次就得看你的条件了,还有,你的程序很多不对齐,也没有注释,看起来很麻烦
