查看: 3618|回复: 2
基于STM32F407,输出双路互补的SPWM波,AD采集用DMA DAC的方式,具有PID调节
ID:499190 发表于 2019-10-21 08:17 | 显示全部楼层 |阅读模式
基于STM32F407,输出双路互补的SPWM波,AD采集用DMA DAC的方式,具有PID调节,代码注释详细
spwm数组生成软件:http://www.51hei.com/bbs/dpj-171674-1.html
  1. #include "stm32f4xx.h"
  2. #include        "string.h"
  3. #include "usart.h"
  4. #include "delay.h"
  5. #include "bsp_advance_tim.h"
  6. #include "bsp_spwm.h"
  7. #include "ShuangLu.h"
  8. #include "PID.h"
  9. #include "bsp_adc.h"
  10. #include "SD_io.h"
  11. #include "oled.h"
  12. #include "filter.h"
  13. #include "bsp_spwm.h"
  14. #include "led.h"
  15. #define   current_threshold  3  //阈值电流为3A
  16. u8 DispADBuff[2][30];          //用于存放字符
  17. extern u16 ADC_ConvertedValue[NOFCHANEL];//DAC_DMA传值处
  18. extern PID pid_voltage;         //存放电压PID的参数
  19. extern float ADC_Final_DisplayValue[NOFCHANEL];        //用于存放最终显示值
  20. extern u16 ADC_filter_Value[NOFCHANEL];        //用于存放滤波后值
  21. extern u8  AD_Flag;
  22. u32 Display_flag=0;//是否显示,PID是否更新
  23. int main(void)
  24. {
  25.
  26.         delay_init(168);
  27.         //ShuangLu_Init();
  28.         ADC_X_Init();
  29.         TIMx_Configuration();
  30.         LED_Init();                                //初始化LED端口
  31.         OLED_Init();
  32.         PID_init(1,1,0,0.5);
  33.         OLED_ShowNum(0,0,22,3,16);
  34.         OLED_Display_On();
  35.    TIM3_Int_Init(3360-1,0);
  36. while(1)
  37.         {
  38.
  39.
  40.                 if(Display_flag%1000==0)
  41.                 {
  42.                         AD_Flag=AD_voltage;  ADC_filter_Value[0]=middleValueFilter();
  43.                         AD_Flag=AD_current;  ADC_filter_Value[1]=middleValueFilter();
  44.                         ADC_Final_DisplayValue[0] =(float) ADC_filter_Value[0]/4096*3.3*6+0.2;   //电压检测
  45.                         ADC_Final_DisplayValue[1] =(float) ADC_filter_Value[1]/4096*3300*1.448-18;         //电流检测
  46.                         //PID电压计算输出,设定值24V,输入电压检测值
  47.                         PID_Calc(ADC_Final_DisplayValue[0],24,0.7,0.2);     //24是设定值,0.7是上限.0.2是下限
  48.
  49.                 }
  50.                 if((Display_flag>10000)||(Display_flag==1))
  51.                 {
  52.                    sprintf(DispADBuff[0],"V=%.2fV\0",ADC_Final_DisplayValue[0]);//电压显示
  53.                    sprintf(DispADBuff[1],"I1=%.3fA\0",ADC_Final_DisplayValue[1]);//电流显示
  54.                     OLED_ShowString(0,0,DispADBuff[0]);
  55.                OLED_ShowString(0,2,DispADBuff[1]);
  56.                         OLED_Display_Off();
  57.                         Display_flag=2;
  58.                 }
  59.
  60.                 if(ADC_Final_DisplayValue[1]>current_threshold)
  61.                 {
  62.                         GPIO_SetBits(SD_io_PORT,SD_io_I1|SD_io_I2);
  63.                         delay_ms(1000);delay_ms(1000);delay_ms(1000);delay_ms(1000);delay_ms(1000);delay_ms(1000);
  64.                         pid_voltage.SEk=0;
  65.               GPIO_ResetBits(SD_io_PORT,SD_io_I1|SD_io_I2);
  66.                 }
  67.
  68.         }
  69. }
互补SPWM 模拟死区开关方波 PID ADC (双极性) - 副本.7z (308.7 KB, 下载次数: 167)
ID:630228 发表于 2019-12-23 15:56 | 显示全部楼层
请问这对应的两路输出对应的引脚是哪两个?
ID:216383 发表于 2022-12-7 23:37 来自手机 | 显示全部楼层
什么东西了没有参考性
