实现了一个stm32 上LCD屏幕的菜单选择
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "lcd.h"
- #include "led.h"
- #include "key.h"
- #include "malloc.h"
- #include "sdio_sdcard.h"
- #include "w25qxx.h"
- #include "ff.h"
- #include "exfuns.h"
- #include "text.h"
- #include "pyinput.h"
- #include "touch.h"
- #include "string.h"
- #include "usmart.h"
- u16 kbdxsize; //虚拟键盘按键宽度
- u16 kbdysize;//虚拟键盘按键高度
- u8 aaa;//一级菜单翻转位
- vu8 key=0;
- u16 i;
- //数字表
- const u8* kbd_tbl[9]={"LED1","LED2","LED3","LED4","LED5","LED6","set","fun","close"};
- //字符表
- const u8* kbs_tbl[9]={"灯1","灯2","灯3","灯4","灯5","灯6","设置","功能","关闭"};
- void first_meau_1(void)
- POINT_COLOR=RED;
- Show_Str(30,5,200,16,"led灯管控制",16,0);
- Show_Str(30,20,200,16,"all点亮所有",16,0);
- Show_Str(30,35,200,16,"fun进入功能",16,0);
- Show_Str(30,50,200,16,"close关闭当前",16,0);
- Show_Str(30,65,200,16,"circle1:校准 KEY0:切换",16,0);
- Show_Str(30,90,200,16,"输入:",16,0);
- Show_Str(30,110,200,32,"结果:",16,0);
- void first_meau_2(void)
- POINT_COLOR=RED;
- Show_Str(30,5,200,16,"led control",16,0);
- Show_Str(30,20,200,16,"all lights on",16,0);
- Show_Str(30,35,200,16,"function",16,0);
- Show_Str(30,50,200,16,"close now",16,0);
- Show_Str(30,65,200,16,"circle1:adjust KEY0:change",16,0);
- Show_Str(30,90,200,16,"in:",16,0);
- Show_Str(30,110,200,32,"out:",16,0);
- void Init_all(void)
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- usmart_dev.init(72); //初始化USMART
- KEY_Init(); //初始化按键
- LCD_Init(); //初始化LCD
- W25QXX_Init(); //初始化W25Q128
- tp_dev.init(); //初始化触摸屏
- my_mem_init(SRAMIN); //初始化内部内存池
- exfuns_init(); //为fatfs相关变量申请内存
- f_mount(fs[0],"0:",1); //挂载SD卡
- f_mount(fs[1],"1:",1); //挂载FLASH.
- POINT_COLOR=RED;
- while(font_init()) //检查字库
- LCD_ShowString(30,50,200,16,16,"Font Error!");
- delay_ms(200);
- LCD_Fill(30,50,240,66,WHITE);//清除显示
- void secondMeau(void)
- //加载键盘界面
- //x,y:界面起始坐标
- void py_load_ui(u16 x,u16 y,u8 flag)
- POINT_COLOR=BLACK;
- LCD_DrawRectangle(x,y,x+kbdxsize*3,y+kbdysize*3);
- LCD_DrawRectangle(x+kbdxsize,y,x+kbdxsize*2,y+kbdysize*3);
- LCD_DrawRectangle(x,y+kbdysize,x+kbdxsize*3,y+kbdysize*2);
- POINT_COLOR=BLUE;
- if(flag)
- first_meau_2();
- for(i=0;i<9;i++)
- Show_Str_Mid(x+(i%3)*kbdxsize,y+4+kbdysize*(i/3),(u8*)kbd_tbl[i],16,kbdxsize); //Chinese
- else
- first_meau_1();
- for(i=0;i<9;i++)
- Show_Str_Mid(x+(i%3)*kbdxsize,y+kbdysize/2+kbdysize*(i/3),(u8*)kbs_tbl[i],16,kbdxsize); //English
- //按键状态设置
- //x,y:键盘坐标
- //key:键值(0~8)
- //sta:状态,0,松开;1,按下;
- void py_key_staset(u16 x,u16 y,u8 keyx,u8 sta)
- u16 i=keyx/3,j=keyx%3;
- if(keyx>8)
- return;
- if(sta)
- LCD_Fill(x+j*kbdxsize+1,y+i*kbdysize+1,x+j*kbdxsize+kbdxsize-1,y+i*kbdysize+kbdysize-1,GREEN);
- else
- LCD_Fill(x+j*kbdxsize+1,y+i*kbdysize+1,x+j*kbdxsize+kbdxsize-1,y+i*kbdysize+kbdysize-1,WHITE);
- //得到触摸屏的输入
- //x,y:键盘坐标
- //返回值:按键键值(1~9有效;0,无效)
- u8 py_get_keynum(u16 x,u16 y)
- u16 i,j;
- static u8 key_x=0;//0,没有任何按键按下;1~9,1~9号按键按下
- u8 key=0;
- tp_dev.scan(0);
- if(tp_dev.sta&TP_PRES_DOWN) //触摸屏被按下
- for(i=0;i<3;i++)
- for(j=0;j<3;j++)
- if(tp_dev.x[0]<(x+j*kbdxsize+kbdxsize)&&tp_dev.x[0]>(x+j*kbdxsize)&&tp_dev.y[0]<(y+i*kbdysize+kbdysize)&&tp_dev.y[0]>(y+i*kbdysize))
- key=i*3+j+1;
- break;
- if(key)
- if(key_x==key)key=0;
- else
- py_key_staset(x,y,key_x-1,0);
- key_x=key;
- py_key_staset(x,y,key_x-1,1);
- break;
- else if(key_x)
- key_x=0;
- return key; //得到key值
- int main(void)
- u8 i=0;
- u8 circle1,circle2,circle3;//按键标志位
- u8 inputstr[100]; //最大输入100个字符+结束符
- u8 inputlen; //输入长度
- u8 ok=0;
- Init_all();
- if(lcddev.id==0X5310){kbdxsize=86;kbdysize=43;}//根据LCD分辨率设置按键大小
- else if(lcddev.id==0X5510||lcddev.id==0X1963){kbdxsize=140;kbdysize=70;}
- else {kbdxsize=60;kbdysize=40;}
- memset(inputstr,0,7); //全部清零
- inputlen=0; //输入长度为0
- while(1)
- circle1=KEY_Scan(0);
- circle2 = circle1;
- while(circle2==KEY0_PRES)
- circle2=KEY_Scan(0);
- if(circle1==KEY0_PRES)
- ok =~ok;
- LCD_Clear(WHITE);
- i++;
- delay_ms(10);
- if(aaa==1)
- secondMeau();
- circle3=KEY_Scan(0);
- if(circle3==KEY1_PRES)
- aaa=0;
- else
- py_load_ui(30,195,ok);
- key=py_get_keynum(30,195);
- if(key)
- if(key==9)//删除
- Show_Str(30,130,200,16,"关闭当前",16,0);
- delay_ms(1000);
- LCD_Fill(30,130,30+100,140+16,WHITE);
- if(inputlen)
- inputstr[inputlen-1]=' ';//添加结束符
- inputlen--;
- else
- if(key==8)
- Show_Str(30,130,200,16,"进入下一功能",16,0);
- delay_ms(1000);
- LCD_Fill(30+40,90,30+40+48,110+16,WHITE); //清除之前的显示
- delay_ms(1000);
- LCD_Fill(0,0,2000,2000,WHITE);
- Show_Str(30+40,90,200,16," ",16,0);
- aaa=1;
- if(key==7)
- Show_Str(30,130,200,16,"设置地址",16,0);
- delay_ms(1000);
- inputstr[inputlen]=key+'0';//输入字符
- if(inputlen<100)
- inputlen++;
- if(key!=8&&key!=7)
- Show_Str(30+40,90,200,16,inputstr,16,0); //显示有效的数字串
LCD显示.7z
(1.39 MB, 下载次数: 41)
