#include"reg511.h"
typedef unsigned int uint16; //对数据类型进行声明定义
typedef unsigned char uint8;
sbit cs=P1^3;
sbit msio=P0^0;
sbit clk=P1^4;
sbit mosi=P0^1;
sbit led=P1^5;
uint8 we_d;
uint8 Temp1=0X12;
void delay_ms(uint16 x)
uint16 j,i;
for(j=0;j<x;j++)
for(i=0;i<1100;i++);
void SPI_WriteByte(uint8 date)
uint8 temp,i;
temp = date;
for (i = 0; i < 8; i++)
clk=0;
if((temp&0x80)==0x80)
{ mosi=1; }
{ mosi=0; }
clk=1 ;
temp <<= 1;
mosi=0;
uint8 SPI_ReadByte(void)
uint8 temp=0;
uint8 i;
for(i = 0; i < 8; i++)
temp <<= 1;
clk=0 ;
if(msio)
{temp++; }
clk=1 ;
return(temp);
uint16 W25QXX_ReadID(void)
uint16 Temp = 0;
uint8 Temp1 = 0;
uint8 Temp2 = 0;
cs=0;
SPI_WriteByte(0x90); //发送读取ID命令
SPI_WriteByte(0x00);
Temp1|=SPI_ReadByte();
Temp2|=SPI_ReadByte();
Temp = Temp1*256+Temp2;
cs=1;
return Temp;
void UartInit(void) //9600bps@33.1776MHz
PCON &= 0x7F; //波特率不倍速
SCON = 0x50; //8位数据,可变波特率
AUXR |= 0x40; //定时器1时钟为Fosc,即1T
AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
TMOD &= 0x0F; //清除定时器1模式位
TMOD |= 0x20; //设定定时器1为8位自动重装方式
TL1 = 0x94; //设定定时初值
TH1 = 0x94; //设定定时器重装值
ET1 = 0; //禁止定时器1中断
TR1 = 1; //启动定时器1
ES=1; //打开接收中断
EA=1; //打开总中断
void main(void)
{ uint16 Temp;
uint8 Temp2;
P1M1=0X00;P1M0=0X00;
P0M1 &= 0xE1; P0M0 &= 0xE1;
cs=1; //设置P1为推挽输出
UartInit(); // 串口初始化
delay_ms(600);
Temp=W25QXX_ReadID();
Temp1=(uint8)(Temp/256);
Temp2=(uint8)Temp;
void Usart() interrupt 4
uint8 receiveData;
receiveData=SBUF;//出去接收到的数据
RI = 0;//清除接收中断标志位
SBUF=Temp1;//将接收到的数据放入到发送寄存器
while(!TI); //等待发送数据完成
TI=0; //清除发送完成标志位
