- @file NelsonsLog_FDC2214.cpp
- @author dlsc
- #include "Arduino.h"
- #include <Wire.h>
- #include "FDC2214.h"
- FDC2214::FDC2214(uint8_t i2caddr) {
- _i2caddr = i2caddr;
- //_i2caddr = FDC2214_I2C_ADDRESS;
- // Checking for chip ID, if OK, calls chip init
- boolean FDC2214::begin(uint8_t chanMask, uint8_t autoscanSeq, uint8_t deglitchValue) {
- Wire.begin();
- int devId = read16FDC(FDC2214_DEVICE_ID);
- if (devId != 0x3054) {
- if (devId != 0x3055) {
- //two valid device ids for FDC2214 0x3054 and 0x3055
- return false;
- loadSettings(chanMask, autoscanSeq, deglitchValue);
- // setGain();
- return true;
- //Internal routine to do actual chip init
- void FDC2214::loadSettings(uint8_t chanMask, uint8_t autoscanSeq, uint8_t deglitchValue) {
- //Configuration register
- // Active channel Select: b00 = ch0; b01 = ch1; b10 = ch2; b11 = ch3;
- // |Sleep Mode: 0 - device active; 1 - device in sleep;
- // ||Reserved, reserved, set to 1
- // |||Sensor Activation Mode: 0 - drive sensor with full current. 1 - drive sensor with current set by DRIVE_CURRENT_CHn
- // ||||Reserved, set to 1
- // |||||Reference clock: 0 - use internal; 1 - use external clock
- // ||||||Reserved, set to 0
- // |||||||Disable interrupt. 0 - interrupt output on INTB pin; 1 - no interrupt output
- // ||||||||High current sensor mode: 0 - 1.5mA max. 1 - > 1.5mA, not available if Autoscan is enabled
- // ||||||||| Reserved, set to 000001
- // CCS1A1R0IH000000 -> 0001 1110 1000 0001 -> 0x1E81
- write16FDC(FDC2214_CONFIG, 0x1E81); //set config
- //If channel 1 selected, init it..
- if (chanMask & 0x01) {
- //settle count maximized, slow application
- write16FDC(FDC2214_SETTLECOUNT_CH0, 0x64);
- //rcount maximized for highest accuracy
- write16FDC(FDC2214_RCOUNT_CH0, 0xFFFF);
- //no offset
- write16FDC(FDC2214_OFFSET_CH0, 0x0000);
- // Set clock dividers
- // Reserved
- // | Sensor Frequency Select. b01 = /1 = sensor freq 0.01 to 8.75MHz; b10 = /2 = sensor freq 0.01 to 10 or 5 to 10 MHz
- // | | Reserved
- // | | | Reference divider. Must be > 1. fref = fclk / this register`
- // 00FF00RRRRRRRRRR -> 0010000000000001 -> 0x2001
- write16FDC(FDC2214_CLOCK_DIVIDERS_CH0, 0x2001);
- //set drive register
- write16FDC(FDC2214_DRIVE_CH0, 0xF800);
- // Init chan2, if selected by channel init mask
- if (chanMask & 0x02) {
- write16FDC(FDC2214_SETTLECOUNT_CH1, 0x64);
- write16FDC(FDC2214_RCOUNT_CH1, 0xFFFF);
- write16FDC(FDC2214_OFFSET_CH1, 0x0000);
- write16FDC(FDC2214_CLOCK_DIVIDERS_CH1, 0x2001);
- write16FDC(FDC2214_DRIVE_CH1, 0xF800);
- if (chanMask & 0x04) {
- if (chanMask & 0x08) {
- // Autoscan: 0 = single channel, selected by CONFIG.ACTIVE_CHAN
- // | Autoscan sequence. b00 for chan 1-2, b01 for chan 1-2-3, b02 for chan 1-2-3-4
- // | | Reserved - must be b0001000001
- // | | | Deglitch frequency. b001 for 1 MHz, b100 for 3.3 MHz, b101 for 10 Mhz, b111 for 33 MHz
- // ARR0001000001DDD -> b0000 0010 0000 1000 -> h0208
- uint16_t muxVal = 0x0208 | ((uint16_t)autoscanSeq << 13) | deglitchValue;
- write16FDC(FDC2214_MUX_CONFIG, muxVal); //set mux config for channels
- // @brief Given a reading calculates the sensor frequency
- //long long NelsonsLog_FDC2214::calculateFsensor(unsigned long reading){
- //// Serial.println("reading: "+ String(reading));
- // //fsensor = (CH_FIN_SEL * fref * data) / 2 ^ 28
- // //should be mega hz so can truncate to long long
- // Serial.println("FDC reading: " + String(reading));
- // unsigned long long temp;
- // temp = 1 * 40000000 * reading;
- // temp = temp / (2^28);
- //// Serial.println("frequency: " + String((long)temp));
- // return temp;
- // @brief Given sensor frequency calculates capacitance
- //double NelsonsLog_FDC2214::calculateCapacitance(long long fsensor){
- // //differential configuration
- // //c sensor = 1 - (Cboard + Cparacitic)
- // // / (L * (2*pi * fsensor)^2)
- // double pi = 3.14159265359;
- // double L = 18; //uH
- // double Cboard = 33; //pf
- // double Cparacitic = 3; //pf
- // double temp = 2 * pi * fsensor;
- // temp = temp * temp;
- // temp = temp / 1000000; //uH
- // temp *= L;
- //// Serial.println("capacitance: " + String(temp));
- // return temp;
- // Gets 28bit reading for FDC2212 and FDC2214
- // Takes in channel number, gives out the formatted 28 bit reading.
- unsigned long FDC2214::getReading28(uint8_t channel) {
- int timeout = 100;
- unsigned long reading = 0;
- long long fsensor = 0;
- int status = read16FDC(FDC2214_STATUS);
- uint8_t addressMSB;
- uint8_t addressLSB;
- uint8_t bitUnreadConv;
- switch (channel){
- case (0):
- addressMSB = FDC2214_DATA_CH0_MSB;
- addressLSB = FDC2214_DATA_CH0_LSB;
- bitUnreadConv = FDC2214_CH0_UNREADCONV;
- break;
- case (1):
- addressMSB = FDC2214_DATA_CH1_MSB;
- addressLSB = FDC2214_DATA_CH1_LSB;
- bitUnreadConv = FDC2214_CH1_UNREADCONV;
- break;
- case (2):
- break;
- case (3):
- break;
- default: return 0;
- while (timeout && !(status & FDC2214_CH0_UNREADCONV)) {
- status = read16FDC(FDC2214_STATUS);
- timeout--;
- if (timeout == 100) {
- // There was this weird double read, as "first readout could be stale" in Nelsons file.
- // I have not confirmed the existence of this silicon bug.
- // I suspect that it might be due to crappy breadboard or rats nest wiring or lack of signal integrity for other reason
- // On the other hand, I have done far too little testing to be sure, so I am leaving that bit in for now.
- //could be stale grab another //could it really it? ?????
- //read the 28 bit result
- reading = (uint32_t)(read16FDC(addressMSB) & FDC2214_DATA_CHx_MASK_DATA) << 16;
- reading |= read16FDC(addressLSB);
- timeout--;
- if (timeout) {
- return reading;
- } else {
- // Could not get data, chip readynes flag timeout
- return 0;
- // Gets 16bit reading for FDC2112 and FDC2114
- unsigned long FDC2214::getReading16(uint8_t channel) {
- switch (channel){
- case (0):
- break;
- case (1):
- break;
- case (2):
- break;
- case (3):
- break;
- timeout--;
- timeout--;
- if (timeout) {
- //read the 16 bit result
- return reading;
- } else {
- return 0;
- // @brief Takes a reading and calculates capacitance from it
- //double NelsonsLog_FDC2214::readCapacitance() {
- // int timeout = 100;
- // unsigned long reading = 0;
- // long long fsensor = 0;
- // int status = read16FDC(FDC2214_STATUS_REGADDR);
- // while (timeout && !(status & FDC2214_CH0_UNREADCONV)) {
- //// Serial.println("status: " + String(status));
- // status = read16FDC(FDC2214_STATUS_REGADDR);
- // timeout--;
- // if (timeout) {
- // //read the 28 bit result
- // reading = read16FDC(FDC2214_DATA_CH0_REGADDR) << 16;
- // reading |= read16FDC(FDC2214_DATA_LSB_CH0_REGADDR);
- // fsensor = calculateFsensor(reading);
- // return calculateCapacitance(fsensor);
- // } else {
- // //error not reading
- // Serial.println("error reading fdc");
- // return 0;
- @brief Scans various gain settings until the amplitude flag is cleared.
- WARNING: Changing the gain setting will generally have an impact on the
- reading.
- //void NelsonsLog_FDC2214::setGain(void) {
- // //todo
- @brief I2C low level interfacing
- // Read 1 byte from the FDC at 'address'
- uint8_t FDC2214::read8FDC(uint16_t address) {
- uint8_t data;
- Wire.beginTransmission(_i2caddr);
- Wire.write(address >> 8);
- Wire.write(address);
- Wire.endTransmission(false);
- Wire.requestFrom(_i2caddr, (uint8_t) 1);
- uint8_t r = Wire.read();
- return r;
- // Read 2 byte from the FDC at 'address'
- uint32_t FDC2214::read32FDC(uint16_t address) {
- uint32_t retVal = 0;
- uint8_t data;
- // Wire.write(address >> 8);
- Wire.requestFrom(_i2caddr, (uint8_t) 2);
- while (!Wire.available());
- data = Wire.read();
- retVal |= (uint32_t)data << 24;
- retVal |= (uint32_t)data << 16;
- retVal |= (uint32_t)data << 8;
- retVal |= data;
- return retVal;
- uint16_t FDC2214::read16FDC(uint16_t address) {
- uint16_t data;
- Wire.endTransmission(false); //restart
- data <<= 8;
- data |= Wire.read();
- Wire.endTransmission(true); //end
- return data;
- // write 1 byte to FDC
- void FDC2214::write8FDC(uint16_t address, uint8_t data) {
- Wire.write(data);
- Wire.endTransmission();
- // write 2 bytes to FDC
- void FDC2214::write16FDC(uint16_t address, uint16_t data) {
- Wire.write(address & 0xFF);
- Wire.write(data >> 8);
- Wire.write(data);
