查看: 13529|回复: 1
51单片机蜂鸣器演奏小星星
ID:531311 发表于 2019-11-19 18:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己用蜂鸣器做的小星星,有用的小伙伴拿去看看吧
#include <reg52.h>
sbit beep=P2^0;
uchar m,n;                                         //定义4个八度每八度12分音律共48个音律
uchar code T[49][2]={{0,0},{0xF8,0x8B},                                        //定义音律为49个二维数组
        {0xF8,0xF2},{0xF9,0x5B},
        {0xF9,0xB7},{0xFA,0x14},
        {0xFA,0x66},{0xFA,0xB9},
        {0xFB,0x03},{0xFB,0x4A},
        {0xFB,0x8F},{0xFB,0xCF},
        {0xFC,0x0B},{0xFC,0x43},
        {0xFC,0x78},{0xFC,0xAB},
        {0xFC,0xDB},{0xFD,0x08},
        {0xFD,0x33},{0xFD,0x5B},
        {0xFD,0x81},{0xFD,0xA5},
        {0xFD,0xC7},{0xFD,0xE7},
        {0xFE,0x05},{0xFE,0x21},
        {0xFE,0x3C},{0xFE,0x55},
        {0xFE,0x6D},{0xFE,0x84},
        {0xFE,0x99},{0xFE,0xAD},
        {0xFE,0xC0},{0xFE,0x02},
        {0xFE,0xE3},{0xFE,0xF3},
        {0xFF,0x02},{0xFF,0x10},
        {0xFF,0x1D},{0xFF,0x2A},
        {0xFF,0x36},{0xFF,0x42},
        {0xFF,0x4C},{0xFF,0x56},
        {0xFF,0x60},{0xFF,0x69},
        {0xFF,0x71},{0xFF,0x79},
        {0xFF,0x81}};
uchar code music[][2]={{0,4},{13,8},                                //定义曲谱数组,前数为音律,后数为音符节拍
        {13,8},{20,8},
        {20,8},{22,8},
        {20,8},{20,16},
        {18,8},{18,8},
        {17,8},{17,8},
        {15,8},{15,8},
        {13,16},{20,8},
        {20,8},{18,8},
        {18,8},{17,8},
        {17,8},{15,16},
        {20,8},{20,8},
        {18,8},{18,8},
        {17,8},{17,8},
        {15,16},{13,8},
        {13,8},{20,8},
        {20,8},{22,8},
        {20,8},{20,16},
        {18,8},{18,8},
        {17,8},{17,8},
        {15,8},{15,8},
        {13,16},{0xFF,0xFF}};
void delay(uchar p)
    uchar i,j;
    for(;p>0;p--)
    for(i=181;i>0;i--)
    for(j=181;j>0;j--);                                                //181*181个机器周期约25ms,即1/16个节拍
void pause()
    uchar i,j;
    for(i=200;i>0;i--)
    for(j=200;j>0;j--);
void T0_int() interrupt 1
        beep=!beep;
        TH0=T[m][0];
        TL0=T[m][1];                                                //音律延时周期次数码表赋给定时寄存器作为计数初始值,每TH0TL0个机器周期触发蜂鸣器端口翻转,演奏出不同音符
        uchar i=0;
        TMOD=0x01;                 //定时器T0
        EA=1;
        ET0=1;
        m=music[i][0];
                n=music[i][1];                        //将音律号赋值给m, 将节拍号赋值给n
                if(m==0x00)                                 //如果音律号为0
                        TR0=0;
                        delay(n);
                        i++;                                //关闭定时器,延迟n拍,将循环数I加1 ,准备读下一个音符
           else if(m==0xFF)                         //如果音律号为1
        TR0=0;
        delay(30);
        i=0;                //开启节拍延时30个1/16节拍,歌曲停顿2秒,将循环数I置0
           else if(m==music[i+1][0])                  // 否则如果把下一个音律号数给变量m
        TR0=1;
        delay(n);
        TR0=0;
        pause();
        i++;                //定时器0打开延迟n拍,关闭定时器T0,读下一个音符,循环数加1读下一个音律
           else        //音符若不为零
        TR0=1;
        delay(n);
        i++;                //打开定时器,延时n个1/16拍,循环数I加1 ,准备演奏下一个音符
收藏收藏1 分享淘帖 顶 踩
ID:911807 发表于 2021-4-25 13:57 | 只看该作者
你好,请问以下49个二维数组是怎么得出的
