新人发帖,有错误请指教!
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit s1=P3^2;
- sbit s2=P3^3;
- sbit s3=P3^4;
- sbit s4=P3^5; //矩阵键盘 公共
- sbit EP = P2^2; //使能端
- sbit RW = P2^1; //数据/命令选择端
- sbit RS = P2^0; //读写选择端
- sbit KEY_1 = P3^2; //按键设置模式选择
- sbit KEY_2 = P3^3; //按键
- static uint code table1[] = {0, 31, 59, 90, 120, 151,181, 212, 242, 273, 303, 334};
- static uchar code *Week[7] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
- uchar sec = 0, hour = 12, minu = 0;
- uchar count = 0, week = 0; month = 1, day = 1
- void T0_Init()
- ET0 = 1;
- TMOD = 0x01;
- TH0 = (65536 - 46071)/256;
- TL0 = (65536 - 46071)%256;
- TR0 = 1;
- void delay(uint ms)
- uint i, j;
- for(i=ms; i>0; i--)
- for(j=110; j>0; j--);
- void Write_Cmd(uchar cmd) //写入命令
- // Lcd_Ready();
- RS = 0;
- RW = 0;
- EP = 0;
- P0 = cmd;
- delay(5);
- EP = 1;
- delay(5);
- EP = 0;
- void Write_Dat(uchar dat) //写入数据
- // Lcd_Ready(); //LCD1602 不忙则跳出
- RS = 1;
- RW = 0;
- EP = 0;
- P0 = dat;
- delay(5);
- EP = 1;
- delay(5);
- EP = 0;
- void Write_Week(uchar day, uchar month) //星期与日期同步
- week = (table1[(month - 1)] + day - 1);
- week = week % 7;
- Write_Cmd(0x80 + 12);
- while(*Week[week] != '\0')
- Write_Dat(*Week[week]++);
- void Write_Num(uchar x, uchar y, uchar num) //将时分秒和日期写入1602
- uchar unit, decad;
- unit = num % 10;
- decad = num /10;
- if(y == 1)
- Write_Cmd(0x80 + 0x40 + x);
- Write_Dat(0x30 + decad); //即加48,将数字转换为ASC||字符数字
- Write_Dat(0x30 + unit);
- else
- Write_Cmd(0x80 + x);
- void Lcd_Init() //LCD初始化设定
- Write_Cmd(0x38); // 16*2显示,5*7点阵,8位数据
- Write_Cmd(0x0c); // 显示开,关光标
- Write_Cmd(0x06); // 读写地址自动加1,光标加1
- Write_Cmd(0x01); //清除屏幕
- Write_Cmd(0x80);
- void Display() //
- Write_Week(day, month);
- Write_Num(9, 0, day);
- Write_Num(6, 0, month);
- Write_Num(4, 1, hour);
- Write_Num(7, 1, minu);
- Write_Num(10, 1, sec);
- Write_Cmd(0x80 + 0x40 + 6);
- Write_Dat(':');
- Write_Cmd(0x80 + 0x40 + 9);
- Write_Dat(':');
- void TimerCount()
- if(count == 20)
- count = 0;
- sec++;
- if(sec == 60)
- sec = 0;
- minu++;
- if(minu == 60)
- minu = 0;
- hour++;
- if(hour == 24)
- hour = 0;
- day++;
- week++;
- if(week == 7)
- week = 0;
- switch(month)
- case 1:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 2:
- if(day == 29)
- day = 0;
- month++;
- break;
- case 3:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 4:
- if(day == 31)
- day = 0;
- month++;
- break;
- case 5:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 6:
- if(day == 31)
- day = 0;
- month++;
- break;
- case 7:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 8:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 9:
- if(day == 31)
- day = 0;
- month++;
- break;
- case 10:
- if(day == 32)
- day = 0;
- month++;
- break;
- case 11:
- if(day == 31)
- day = 0;
- month++;
- break;
- case 12:
- if(day == 32)
- day = 0;
- month = 1;
- break;
- Display();
- void KeyScan()
- static uchar key1cnt = 0; //KEY_1按下的次数
- if(KEY_1 == 0)
- delay(10);
- if(KEY_1 == 0)
- key1cnt++;
- while(!KEY_1);
- switch(key1cnt)
- case 1:
- TR0 = 0;
- Write_Cmd(0x80 + 0x40 + 5);
- Write_Cmd(0x0F); //显示光标且光标闪烁
- break;
- case 2:
- Write_Cmd(0x80 + 0x40 + 8);
- break;
- case 3:
- Write_Cmd(0x80 + 0x40 + 11);
- break;
- case 4:
- Write_Cmd(0x80 + 7);
- break;
- case 5:
- Write_Cmd(0x80 + 10);
- break;
- case 6:
- TR0 = 1;
- Write_Cmd(0x0C); //不显示光标
- key1cnt = 0;
- break;
- if(key1cnt != 0)
- if(KEY_2 == 0)
- delay(10);
- if(KEY_2 == 0)
- while(!KEY_2);
- switch(key1cnt)
- case 1:
- hour++;
- if(hour == 24)
- hour = 0;
- break;
- case 2:
- minu++;
- if(minu == 60)
- minu = 0;
- break;
- case 3:
- sec++;
- if(sec == 60)
- sec = 0;
- break;
- case 4:
- month++;
- if(month == 13)
- month = 1;
- break;
- case 5:
- day++;
- if(day == 32)
- day = 1;
- break;
- void main()
- uchar i = 0;
- uchar code table[] = {"2019-01-01 Sun"};
- EA = 1;
- Lcd_Init(); //1602初始化
- T0_Init(); //定时器0初始化
- Write_Cmd(0x80 + 1);
- while(table[i] != '\0')
- Write_Dat(table[i]);
- i++;
- while(1)
- KeyScan();
- void Timer0() interrupt 1
- count++;
- TimerCount();
