基于stm32的智能家居系统模拟电路 Altium Designer画的原理图和PCB图如下:(51hei附件中可下载工程文件)
- /*************端口信息********************
- * 接线说明
- LD3320接口 STM32接口
- * RST PB11
- * CS PB10
- * WR/SPIS PB12
- * P2/SDCK PB13
- * P1/SDO PB14
- * P0/SDI PB15
- * IRQ PA15
- * A0 PA8
- #include "includes.h"
- /* Private function prototypes -----------------------------------------------*/
- void RCC_Configuration(void);
- //void NVIC_Configuration(void);
- void USART_Configuration(void);
- void PrintCom(USART_TypeDef* USARTx, uint8_t *Data);
- void PrintComBit(USART_TypeDef* USARTx, uint8_t Data);
- extern void LD3320_main(void);
- * 名 称: 主函数
- * 功 能: 程序入口
- * 入口参数: 无
- * 出口参数: 无
- * 说 明: 无
- * 调用方法: 无
- int main(void)
- /* System Clocks Configuration */
- RCC_Configuration(); //外设时钟配置
- delay_init(72); //延时函数初始化
- USART_Configuration();//USART 配置
- PrintCom(USART1," USART Init OK!\r\n");
- LD3320_main(); //LD3320 主函数函数
- while(1)
- * 名 称: void USART_Configuration(void)
- * 功 能: 串口配置
- * 入口参数:
- * 出口参数:
- * 说 明:
- * 调用方法:
- USART_InitTypeDef USART_InitStructure;
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitStructure.USART_BaudRate = 9600;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- /* Configure USART1 */
- USART_Init(USART1, &USART_InitStructure); //类似与GPIO口,配置完后初始化一次
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //使能接收 中断
- USART_ITConfig(USART1, USART_IT_TXE, ENABLE); //使能发送 中断
- USART_Cmd(USART1, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
- GPIO_Init(GPIOA, &GPIO_InitStructure); //A端口
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //复用开漏输入
- * 名 称:void PrintCom(USART_TypeDef* USARTx, uint8_t *Data)
- * 功 能:串口数据打印
- * 入口参数:
- * 出口参数:
- * 说 明:
- * 调用方法:
- while(*Data)
- USART_SendData(USARTx, *Data++); /*发送单个数据 */
- while(USART_GetFlagStatus(USARTx, USART_FLAG_TC)==RESET);/* 检查指定的USART标志位即RESET=1时发送完成*/
- USART_SendData(USARTx, Data); /*发送单个数据 */
- * 名 称:void RCC_Configuration(void)
- * 功 能:配置外设时钟
- * 入口参数:
- * 出口参数:
- * 说 明:
- * 调用方法:
- SystemInit();
- /* Enable USART1, GPIOA, GPIOx and AFIO clocks */
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
- RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO|
- RCC_APB2Periph_GPIOE, ENABLE); //开启相关的AHP外设时钟
- /* Enable USART2 clock */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
- * @brief Configures the different GPIO ports.
- * @param None
- * @retval : None
pcb+原理图+程序.7z
(1.54 MB, 下载次数: 184)
