LCD1602 时间显示 Proteus
AT89C51单片机源程序如下: main.c
- * @file main.c
- * @author Kiyotaka
- * @brief Unix timestamp on LCD1602
- * @version 0.1
- * @date 2019-12-08
- * @copyright Copyright (c) 2019
- #include "main.h"
- #include "lcd1602.h"
- void Delay1000ms(void);
- unsigned long int timestamp = 157579655;
- int main(void) {
- LCD1602_Init();
- LCD1602_Printf(0, 0, "Unix timestamp:");
- while (1) {
- LCD1602_Printf(0, 1, "%ld", timestamp++);
- Delay1000ms();
- void Delay1000ms(void) { //@12.000MHz
- unsigned char i = 8;
- unsigned char j = 154;
- unsigned char k = 122;
- _nop_();
- do {
- do {
- while (--k);
- } while (--j);
- } while (--i);
lcd1602.c - /**
- * @file lcd1602.c
- * @brief LCD1602 driver
- * @version 0.1
- typedef enum { GPIO_PIN_RESET = 0, GPIO_PIN_SET } GPIO_PinState;
- #define RS_CMD GPIO_PIN_RESET
- #define RS_DATA GPIO_PIN_SET
- * @brief 延时函数
- * @param us 延时时间
- * @return None
- static void Delay(int us) {
- while (us-- > 0) {
- _nop_();
- * @brief 液晶I/O 口复位
- * @return None
- static void PinReset(void) {
- LCD1602_E_Pin = GPIO_PIN_RESET;
- LCD1602_RS_Pin = GPIO_PIN_RESET;
- LCD1602_RW_Pin = GPIO_PIN_RESET;
- LCD1602_Port = 0xFF;
- * @brief LCD1602 等待液晶空闲
- *@return None
- static void WaitIdleTime(void) {
- LCD1602_RS_Pin = RS_CMD;
- LCD1602_RW_Pin = GPIO_PIN_SET;
- LCD1602_Port = 0x00;
- LCD1602_E_Pin = GPIO_PIN_SET;
- do {
- Delay(100);
- } while ((LCD1602_Port & 0x80) >> 7);
- PinReset();
- * @brief LCD1602 写数据/指令函数
- * @param val 8位数据
- * @param is_data true 是数据, false 是指令
- * @return None
- static void Write(unsigned char val, bit is_data) {
- bit interrupt_stat = EA;
- EA = 0;
- WaitIdleTime();
- LCD1602_RS_Pin = is_data;
- LCD1602_Port = val;
- Delay(100);
- PinReset();
- EA = interrupt_stat;
- * @brief LCD1602 初始化
- * @return None
- void LCD1602_Init(void) {
- PinReset();
- Write(0x38, RS_CMD);
- Write(0x0C, RS_CMD);
- Write(0x06, RS_CMD);
- Write(0x01, RS_CMD);
- * @brief LCD1602 显示函数
- * @param addr_x (0~15) 横坐标
- * @param addr_y (0~1) 纵坐标
- * @param fmt 格式化字符串
- * @param ...
- * @return int
- int LCD1602_Printf(int addr_x, int addr_y, const char *fmt, ...) {
- char buf[20] = {0};
- char *p = buf;
- int ret = 0;
- va_list args;
- va_start(args, fmt);
- ret = vsprintf(p, fmt, args);
- va_end(args);
- Write(0x80 + 0x40 * addr_y + addr_x, RS_CMD);
- while (*p != '\0') {
- if (*p == '\f') {
- } else if (isprint(*p) != 0) {
- Write(*p, RS_DATA);
- p++;
- return ret;
驱动程序(Keil + Proteus)
lcd1602.zip
(47.8 KB, 下载次数: 24)
如果注释为乱码,Keil的Encoding设置成UTF-8
