查看: 4056|回复: 5
单片机+ADS8685驱动程序
ID:659046 发表于 2019-12-8 19:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADS8685驱动,添加到工程即可使用,亲测无误!
  1. #include "ads8685.h"
  2. #include "delay.h"
  3. void Ads8685_RESET(void)
  4. {
  5.         ADS8685_RST=0;
  6.         delay_ms(30);
  7.         ADS8685_RST=1;
  8.         delay_ms(30);
  9. }
  10. void Ads8685_WriteData(u8 data)
  11. {
  12.         u8 index=0;
  13.         ADS8685_SCLK =0;
  14.         delay_us(2);
  15.         for(index=0;index<8;index++)
  16.         {
  17.                 if(data&0x80)
  18.                 {
  19.                         ADS8685_SDI=1;
  20.                 }
  21.                 else
  22.                 {
  23.                         ADS8685_SDI=0;
  24.                 }
  25.                 ADS8685_SCLK =1;
  26.                 delay_us(2);
  27.                 ADS8685_SCLK =0;
  28.                 delay_us(2);
  29.                 data=data<<1;
  30.         }
  31.         ADS8685_SCLK =0;
  32.         delay_us(2);
  33. }
  34. void Ads8685_WriteReg(u8 reg,u16 data)
  35. {
  36.         u16 retry=0;
  37.         ADS8685_CS=0;
  38.         while(ADS8685_RVS)//此引脚为低电平才可以操作ADS8685
  39.         {
  40.                 retry++;
  41.                 if(retry>=0xfffe)
  42.                 {
  43.                         break;
  44.                 }
  45.         }
  46.         Ads8685_WriteData(0xd0);//input command ,datesheet P43
  47.         Ads8685_WriteData(reg);
  48.         Ads8685_WriteData(data>>8);//写高8位
  49.         Ads8685_WriteData((u8)(data&0xff));//写低8位
  50.         ADS8685_CS=1;
  51. }
  52. void Ads8685_Init(void)
  53. {
  54.         GPIO_InitTypeDef  GPIO_InitStructure;
  55.
  56.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能PB,PE端口时钟
  57.
  58.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  59.
  60.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  61.
  62.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;                                 //LED0-->PB.5 端口配置
  63.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
  64.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度为50MHz
  65.         GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根据设定参数初始化GPIOB.5
  66.
  67.
  68.
  69.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;                                 //LED0-->PB.5 端口配置
  70.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                  //上拉输入
  71.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  72.
  73.         ADS8685_SCLK=0;
  74.         ADS8685_RST=0;
  75.         Ads8685_RESET();
  76.         Ads8685_WriteReg(0x14,0x000b);//使用内部参考电压源并且设置输入电压范围为0~5.12V    1.5*Vref  内部参考电压4.096V
  77. }
  78. u16 Ads8685_Readdata(void)
  79. {
  80.         u16 retry=0;
  81.         u8 index=0;
  82.         u32 read_data=0;
  83.         delay_us(10);
  84.
  85.         ADS8685_CS=1;
  86.         retry=0;
  87.         while(!ADS8685_RVS)
  88.         {
  89.                 retry++;
  90.                 if(retry>=0xfffe)
  91.                 {
  92.                         break;
  93.                 }
  94.         }
  95.
  96.         ADS8685_CS=0;
  97.         retry=0;
  98.         while(ADS8685_RVS)
  99.         {
  100.                 retry++;
  101.                 if(retry>=0xfffe)
  102.                 {
  103.                         break;
  104.                 }
  105.         }
  106.
  107.         for(index=0;index<32;index++)
  108.         {
  109.                 delay_us(2);
  110.                 ADS8685_SCLK=1;
  111.                 delay_us(2);   //时间大于15ns即可
  112.
  113.                 read_data = read_data << 1;
  114.                 if(ADS8685_SDO_0)  //串行通信  数据输出0 读SD0_0,如果有数据1,则加到read_data末尾
  115.                 {
  116.                         read_data=read_data+1;
  117.                 }
  118.                 ADS8685_SCLK=0;
  119.                 delay_us(1);
  120.         }
  121.         delay_us(2);
  122.         ADS8685_CS=1;
  123.
  124.         return (read_data>>16);
  125. }
ads8685驱动.zip (1.64 KB, 下载次数: 78)
收藏收藏2 分享淘帖 顶 踩
ID:297557 发表于 2020-4-21 17:18 | 只看该作者
非常好,谢谢分享
ID:87499 发表于 2021-7-20 13:54 | 只看该作者
正在研究,希望有用
ID:955625 发表于 2021-7-25 10:38 | 只看该作者
亲测可用,只是模拟的spi不能完全利用芯片的采样速率
ID:1033476 发表于 2022-8-18 15:19 | 只看该作者
亲测可用,好铁
ID:1075271 发表于 2024-6-21 10:29 | 只看该作者
请问有这个回读的波形么
