怎么修改这个程序?
#include <AT89X52.H>
#include <string.h>
#include <stdio.h>
#include <absacc.h>
#include <math.h>
double rOut; // PID Response (Output)
double rIn; // PID Feedback (Input)
sbit P30=P3^0; // DQ=P30=P3^0,为温度总线
sbit P31=P3^1;
uchar TEMP; // 温度值的变量;
sbit P10=P1^0;
sbit P11=P1^1;
sbit P12=P1^2;
sbit P13=P1^3;
sbit P14=P1^4;
sbit P15=P1^5;
sbit P16=P1^6;
sbit P17=P1^7;
//共阴 LED
unsigned char code led[]={0x3F,0x6,0x5B,0x4F,0x66,0x6D,0x7D,0x7,0x7F,0x6F};
typedef struct PID {
double SetPoint; // 设定目标 Desired value,从拨码盘的输入值
double Proportion; // 比例常数 Proportional Const
double Integral; // 积分常数 Integral Const
double Derivative; // 微分常数 Derivative Const
double LastError; // 偏差 Error[-1]
double PrevError; // 偏差 Error[-2]
double SumError; // 偏差总和 Sums of Errors
} PID;
PID计算部分
double PIDCalc( PID *pp, double NextPoint )
double dError,Error;
Error = pp->SetPoint - NextPoint; // 偏差
pp->SumError += Error; // 积分
dError = pp->LastError - pp->PrevError; // 当前微分
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error // 比例项
+ pp->Integral * pp->SumError // 积分项
+ pp->Derivative * dError // 微分项
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
//缓冲区操作函数,初始化缓冲区中指定个数的数据字节为某一指定的字符值
Main Program
//从DS18B20数字温度传感器读取的温度值。
void delay (unsigned int count)
unsigned int i;
while (count)
i =200;
while (i>0) i--;
count--;
void tmreset (void) // 发送复位和初始化
unsigned int i;
P30 = 0;
i = 103;
while (i>0) i--; // 延时
P30 = 1;
i = 4;
while (i>0) i--;
bit tmpread (void) // 读取数据的一位
unsigned int i;
bit dat;
P30 = 0; i++;
P30 = 1; i++; i++; //延时
dat = P30;
i = 8; while (i>0) i--; // 延时
return (dat);
unsigned char tmpread2 (void) //读一个字节
unsigned char i,j,dat;
dat = 0;
for (i=1;i<=8;i++)
j = tmpread ();
dat = (j << 7) | (dat >> 1);
return (dat);
void tmpwrite (unsigned char dat) //写一个字节
unsigned int i;
unsigned char j;
bit testb;
for (j=1;j<=8;j++)
testb = dat & 0x01;
dat = dat >> 1;
if (testb)
P30 = 0; // 写0
i++; i++;
P30 = 1;
P30 = 0; // 写0
P30 = 1;
i++; i++;
void tmpchange(void) // ds1820 开始转换
tmreset (); // 复位
delay (1); // 延时
tmpwrite (0xcc); // 跳过序列号命令
tmpwrite (0x44); // 发转换命令 44H,
void tmp (void) // 读取温度
unsigned char a;
tmreset (); // 复位
delay (1); // 延时
tmpwrite (0xbe); // 发送读取命令
a = tmpread2 (); // 读取温度(ROM数字)
TEMP=a>>1; // 乘分辨率0.5,转换为十进制的温度值
double sensor (void) // Dummy Sensor Function
tmpchange(); // 开始温度转换
delay(200); // 读取延时
tmp(); // 读取温度
return(TEMP); // 返回温度值
// display 子程序
unsigned int display(viod)
unsigned int NUM;
unsigned int shi; //高位显示变量
unsigned int ge; //低位显示变量
shi=(!P17)*8+(!P16)*4+(!P15)*2+(!P14)*1;
ge=(!P13)*8+(!P12)*4+(!P11)*2+(!P10)*1;
P0=led[shi];
P2=led[ge];
rIn=shi*10+ge;
return(rIn);
void delay_1ms(int t) //设置周期为1mS,使用等脉宽PWM法。
unsigned int i;
while (t)
i =1000;
while (i>0) i--;
t--;
//输出PWM控制程序
void PWM_actuator(double rDelta) // PWM Actuator Function
unsigned int th;
unsigned int tl;
unsigned char k;
// (200/700)*1.0≈0.29
double bili=0.29; //初始化功率=200W,对应bili=1时是700W。
if (rDelta > 0)
th=1000*bili;
tl=1000*(1-bili);
bili+=0.02;
for (k=10;k>0;k--) // 加热一段时间
P31=1;
delay_1ms(th);
P31=0;
delay_1ms(tl);
bili=0;
P31=0; //不加热,让其自然冷却
void main(void)
PID sPID; // PID Control Structure
PIDInit ( &sPID ); // Initialize Structure
//P、I、D 系数的设定,以及键盘预置温度输入的读取
sPID.Proportion = 0.1;
sPID.Integral = 0.1;
sPID.Derivative = 0.1;
sPID.SetPoint=display(); // 键盘输入的温度设定值,同时送LED显示
{ // Mock Up of PID Processing
rIn = sensor (); // Read Input
rOut = PIDCalc ( &sPID,rIn ); // Perform PID Interation
PWM_actuator ( rOut ); // Effect Needed Changes
