查看: 1196|回复: 0
雨滴传感器测试程序 想加有雨滴时单片机蜂鸣器响或者流水灯警报提醒 求帮助
ID:673117 发表于 2020-1-2 02:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
???????STC89C52
???????9600
#include <reg52.h>
#include<intrins.h>  //????????????????????????????????
typedef unsigned int u16;   //?????????????????????
typedef unsigned char u8;
unsigned char date;
sbit key1=P3^3;
sbit beep=P1^5;
void delay(uint z);
void Initial_com(void);
void delay(u16 i)
   while(i--);
** ???????? ?? delay(uint z)
void unsiged(uint z  )
    uint i,j;
    for(i=z;i>0;i--)
        for(j=110;j>0;j--);
EA=1;        //?????ж?
ES=1;        //????????ж?
ET1=1;        //????????T1???ж?
TMOD=0x20;   //?????T1??????2?ж??????????
PCON=0x00;   //SMOD=0
SCON=0x50;   // ???1 ??????????
TH1=0xfd;    //???????????9600
TL1=0xfd;
TR1=1;       //???????T1???п???λ
main()
  Initial_com();
    if(key1==0)
   delay(100);   //??????
   if(key1==0)   //??????
     SBUF=0X01;
     delay(200);
beep=~beep;
delay(10); //??????100us   ??????????????????????Ч??}
    if(RI)
   date=SBUF;    //?????????
   SBUF=date;    //?????????
   RI=0;
