代码如下,是商家那边给我的例程,我想通过改例程来使用,但是我解决不了编译器报错问题,明明代码的位操作没有问题,就是无法编译
- //Drive_IC:SSD1306
- //#include <at89x51.h>
- #include <reg52.h>
- #include "intrins.h"
- #define Uchar unsigned char
- #define Uint unsigned int
- #define Ulong unsigned long
- #define uchar unsigned char
- #define uint unsigned int
- // Pin Definition
- //#define SCL3 P3^1 // Serial Clock Input
- //#define SDA3 P3^2 // Serial Data Input
- sbit SCL3=P3^1;
- sbit SDA3=P3^2;
- code color13[]={
- ; 源文件 / 文字 : C:\Documents and Settings\Administrator\桌面\新建文件夹 (2)\logo.bmp字模
- ; 宽×高(像素): 128×64
- //0x80,0x40,0x10,//宽的像素数,高的像素数,宽的字节数,参数设置可选
- 0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x20,0x44,0x08,0x00,0x18,0x48,0x28,0xC8,0x08,0x28,0x48,0x18,0x00,
- 0x40,0x40,0xFC,0x40,0x40,0xFC,0x00,0x00,0xF8,0x00,0x00,0xFC,0x00,0x40,0x40,0xA0,
- 0x90,0x88,0x84,0x88,0x90,0x20,0x40,0x40,0x00,0x00,0x40,0x44,0xD8,0x20,0xF0,0xAC,
- 0xA8,0xE8,0xB8,0xA8,0xE0,0x00,0x00,0x00,0xC0,0x7C,0x54,0x54,0x54,0x54,0x54,0x54,
- 0x7C,0x40,0x40,0x00,0x00,0xF0,0x90,0x90,0x90,0xFC,0x90,0x90,0x90,0xF0,0x00,0x00,
- 0x00,0x80,0x88,0x88,0x88,0x88,0x88,0xE8,0xA8,0x98,0x8C,0x88,0x80,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
- 0x00,0x00,0x00,0x04,0x3E,0x01,0x10,0x11,0x09,0x05,0x3F,0x05,0x09,0x11,0x11,0x00,
- 0x08,0x18,0x0F,0x24,0x14,0x0F,0x00,0x00,0x0F,0x00,0x00,0x3F,0x00,0x20,0x22,0x2A,
- 0x32,0x22,0x3F,0x22,0x32,0x2A,0x22,0x20,0x00,0x00,0x20,0x10,0x0F,0x10,0x28,0x24,
- 0x23,0x20,0x2F,0x28,0x2A,0x2C,0x00,0x30,0x0F,0x04,0x3D,0x25,0x15,0x15,0x0D,0x15,
- 0x2D,0x24,0x24,0x00,0x00,0x07,0x04,0x04,0x04,0x1F,0x24,0x24,0x24,0x27,0x20,0x38,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0xFF,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xFF,
- 0x01,0x01,0x01,0x81,0x41,0x21,0x21,0x61,0x01,0x01,0x21,0xE1,0xE1,0x01,0xE1,0xE1,
- 0x21,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x21,0xE1,0x21,0x21,0x21,0x61,0x01,0x01,
- 0x21,0x21,0xE1,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x01,0x01,0xC1,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x21,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x00,0x00,0x00,0x0F,0x10,0x20,0x24,0x1C,0x04,0x00,0x20,0x3F,0x01,0x3E,0x01,0x3F,
- 0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x22,0x22,0x27,0x30,0x00,0x00,
- 0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x1E,0x25,0x25,0x25,0x16,0x00,0x00,0x1E,0x21,
- 0x21,0x21,0x13,0x00,0x01,0x01,0x1F,0x21,0x21,0x00,0x00,0x00,0x21,0x3F,0x22,0x21,
- 0x01,0x00,0x00,0x1E,0x21,0x21,0x21,0x1E,0x00,0x21,0x3F,0x22,0x01,0x01,0x3E,0x20,
- 0x00,0x21,0x21,0x3F,0x20,0x20,0x00,0x00,0x1E,0x21,0x21,0x21,0x13,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xF0,0x08,0x04,0x04,0x04,0x0C,0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0xFC,0x04,0x00,
- 0x00,0x00,0x00,0x00,0x0C,0x04,0xFC,0x04,0x0C,0x00,0x04,0xFC,0x04,0x04,0x08,0xF0,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x80,0x80,0x80,0x81,0x82,0x84,0x84,0x84,0x82,0x80,0x81,0x82,0x84,0x84,0x82,0x81,
- 0x80,0x80,0x86,0x86,0x80,0x80,0x80,0x80,0x80,0x85,0x83,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x84,0x87,0x84,0x84,
- 0x84,0x86,0x80,0x80,0x80,0x84,0x87,0x84,0x80,0x80,0x84,0x87,0x84,0x84,0x82,0x81,
- code color14[]={
- /*-- 调入了一幅图像:F:\工作\8051\OLED1\abcd.bmp --*/
- /*-- 宽度x高度=128x64 --*/
- 0x00,0x00,0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00,0x04,0xFC,0x04,0x00,0x00,0x00,
- 0x00,0x04,0xFC,0x44,0x44,0xE4,0x0C,0x00,0x04,0xFC,0x04,0x04,0x08,0xF0,0x00,0xA8,
- 0xAE,0x98,0xFF,0xAC,0x8A,0x10,0xFC,0x0B,0x88,0x78,0x08,0x00,0x88,0x86,0x92,0x92,
- 0x92,0x92,0xD3,0xB2,0x92,0x82,0x8A,0x86,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x82,0xF2,0x92,0x97,0x92,0xFA,0x92,0x97,0xF2,
- 0x82,0x82,0x00,0x04,0x04,0x04,0x1C,0x64,0x85,0x06,0xC4,0x3C,0x04,0x04,0x04,0x00,
- 0x00,0x80,0x3E,0x2A,0xEA,0x2A,0x2A,0xEA,0x2A,0x3F,0x82,0x00,0x00,0x00,0x10,0x12,
- 0xD2,0x12,0x12,0xF2,0x12,0x52,0x93,0x1A,0x10,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xC2,0x04,0xC4,0x02,0x81,0x40,0x44,0x47,0x84,0x04,0x04,0x06,
- 0x00,0x04,0x07,0x04,0x04,0x84,0xC6,0x00,0x04,0x07,0x84,0x44,0x42,0x41,0x80,0x08,
- 0x88,0x45,0x42,0x42,0x85,0x08,0x04,0x03,0x82,0xC4,0x08,0x00,0xC0,0x40,0x40,0x40,
- 0x40,0x08,0x8F,0x40,0x40,0xC0,0x00,0x00,0xC0,0x40,0x41,0xC2,0x46,0x00,0x80,0x40,
- 0x40,0x40,0x80,0x00,0x80,0x40,0x48,0x48,0x88,0x04,0x82,0x41,0x40,0x41,0x82,0x04,
- 0x08,0x08,0x00,0x08,0x08,0x08,0x44,0xC4,0x02,0x01,0x02,0x04,0x04,0x08,0x08,0x00,
- 0x08,0x08,0x09,0x0A,0x0F,0x48,0xC8,0x0F,0x0A,0x09,0xCC,0x08,0x00,0x04,0x42,0xC1,
- 0x40,0x40,0x88,0x0F,0x80,0x40,0x40,0x41,0xC6,0x00,0x40,0xC6,0x46,0x40,0x80,0x00,
- 0x00,0x00,0x09,0x3D,0x0B,0x3D,0x0B,0x09,0x03,0x34,0x24,0x24,0x1F,0x00,0x00,0x00,
- 0x21,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x31,0x28,0x24,0x22,0x21,0x00,
- 0x10,0x20,0x22,0x22,0x1D,0x00,0x04,0x0B,0x08,0x3F,0x28,0x00,0x13,0x22,0x22,0x22,
- 0x1C,0x00,0x1F,0x22,0x22,0x22,0x1C,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x1D,0x22,
- 0x22,0x22,0x1D,0x00,0x03,0x34,0x24,0x24,0x1F,0x00,0x1F,0x20,0x20,0x20,0x1F,0x00,
- 0x00,0x14,0x2A,0x2A,0x3C,0x20,0x00,0x3F,0x22,0x22,0x1C,0x00,0x00,0x1C,0x22,0x22,
- 0x26,0x00,0x00,0x1C,0x22,0x22,0x3F,0x20,0x20,0x3E,0x09,0x0F,0x38,0x20,0x20,0x3F,
- 0x22,0x22,0x1D,0x00,0x1F,0x20,0x20,0x20,0x10,0x00,0x20,0x3F,0x20,0x20,0x1F,0x00,
- 0x00,0x00,0x88,0xE8,0x9E,0xC8,0xBE,0x88,0x00,0x00,0x00,0x04,0xFE,0x00,0x00,0x00,
- 0x00,0xFC,0x02,0x02,0x02,0xFC,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
- 0x04,0xFE,0x00,0x00,0x00,0x00,0x0C,0x82,0x42,0x22,0x1C,0x00,0x00,0x04,0x02,0x12,
- 0x12,0xEC,0x00,0x40,0xB0,0x88,0x84,0xFE,0x00,0x00,0x00,0xBE,0x12,0x12,0x12,0xE2,
- 0x00,0x00,0xF8,0x24,0x12,0x12,0xE6,0x00,0x00,0x20,0x90,0x50,0x50,0xE0,0x00,0x02,
- 0xFE,0x10,0x10,0x10,0xE0,0x00,0x00,0xE0,0x10,0x10,0x10,0x30,0x00,0x00,0xE0,0x10,
- 0x10,0x12,0xFE,0x00,0x00,0x80,0x78,0x46,0x78,0x80,0x00,0x02,0xFE,0x12,0x12,0x12,
- 0xEC,0x00,0xF8,0x04,0x02,0x02,0x02,0x06,0x00,0x02,0xFE,0x02,0x02,0x04,0xF8,0x00,
- 0x40,0xC0,0x78,0x43,0xC0,0x7B,0x40,0x00,0x00,0x10,0x10,0xFA,0x03,0x02,0x00,0x00,
- 0x00,0x71,0x0A,0x0A,0x0A,0x89,0x70,0x00,0x00,0x03,0x03,0xC0,0xC0,0x00,0x00,0x00,
- 0x02,0x13,0x12,0xF8,0x00,0x00,0x03,0x02,0x02,0x72,0x0A,0x08,0x08,0x89,0x72,0x02,
- 0x02,0x31,0x08,0x88,0x88,0x48,0x32,0x03,0x02,0x00,0xC0,0x21,0x12,0xFA,0x02,0x01,
- 0x00,0xF8,0x09,0x8A,0x8A,0x0A,0x09,0x00,0x00,0xE1,0x12,0x8A,0x8A,0x1B,0x02,0x00,
- 0x03,0x02,0x82,0x82,0x81,0x80,0x00,0x01,0x0A,0xFA,0x02,0x81,0x80,0x00,0x01,0x02,
- 0x02,0x02,0x03,0x82,0x82,0x83,0x02,0x00,0x02,0x03,0xC2,0x3A,0xE3,0x02,0x02,0x02,
- 0x09,0xF8,0x88,0x89,0x8A,0x72,0x02,0x01,0xC0,0x32,0x0B,0x0A,0x0A,0x09,0x38,0x00,
- 0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- 0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,
- 0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
- 0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
- 0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,
- 0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,
- 0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,
- 0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,
- 0x10,0x90,0xFE,0x10,0x10,0x90,0xFE,0x10,0x00,0x00,0x00,0x04,0x04,0xFE,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0xC0,0x30,0x08,0x04,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0xFE,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x1C,0x02,0x02,0x02,0x02,0xC2,0x3C,0x00,0x00,0x00,0x1C,0x02,0x42,0x42,
- 0x62,0x9C,0x00,0x00,0x00,0x00,0x80,0x40,0x40,0x40,0x40,0x40,0x80,0x00,0x00,0x00,
- 0x02,0xFE,0x80,0x40,0x40,0x40,0x80,0x00,0x00,0x00,0x00,0x80,0x40,0x40,0x40,0x80,
- 0x00,0x00,0x00,0x00,0x00,0x80,0x78,0x06,0x78,0x80,0x00,0x00,0x00,0x00,0x02,0xFE,
- 0x42,0x42,0x42,0x62,0x9C,0x00,0x00,0x00,0xF0,0x08,0x04,0x02,0x02,0x02,0x04,0x0E,
- 0x04,0x3F,0x04,0x04,0x04,0x3F,0x04,0x04,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,
- 0x00,0x00,0x00,0x00,0x03,0x02,0x02,0x22,0x22,0x3F,0x22,0x22,0x00,0x00,0x00,0x00,
- 0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- 0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x20,0x38,0x00,0x00,0x00,0x1C,0x20,0x20,0x20,
- 0x20,0x10,0x0F,0x00,0x00,0x00,0x19,0x24,0x24,0x22,0x22,0x22,0x3F,0x20,0x30,0x00,
- 0x00,0x3F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,0x00,0x0F,0x10,0x20,0x20,0x20,0x11,
- 0x08,0x00,0x00,0x20,0x38,0x27,0x02,0x02,0x02,0x27,0x38,0x20,0x00,0x00,0x20,0x3F,
- 0x20,0x20,0x20,0x20,0x10,0x0F,0x00,0x00,0x07,0x18,0x20,0x20,0x20,0x20,0x10,0x0C,
- void delay_ms(Uint t)
- Uchar i,j;
- while(--t)
- i=50;
- j=100;
- while(--j)
- while(--i);
- void uDelay(Uchar l)
- while(l--);
- void Delay(Uchar n)
- Uchar i,j,k;
- for(k=0;k<n;k++)
- for(i=0;i<131;i++)
- for(j=0;j<15;j++)
- uDelay(203);
- // Read/Write Sequence
- void I2C_3(Uchar mcmd)
- Uchar length = 8; // Send Command
- while(length--)
- if(mcmd & 0x80)
- SDA3=1;
- else
- SDA3=0;
- // uDelay(3);
- SCL3=1;
- // uDelay(3);
- SCL3=0;
- // uDelay(3);
- mcmd = mcmd << 1;
- void I2C_Ack3()
- SDA3=1;
- // uDelay(3);
- SCL3=1;
- // uDelay(3);
- SCL3=0;
- // uDelay(3);
- void I2C_NAck3()
- SDA3=0;
- // uDelay(3);
- SCL3=1;
- // uDelay(3);
- SCL3=0;
- // uDelay(3);
- void I2C_Start3()
- SDA3=0;
- // uDelay(3);
- SCL3=1;
- // uDelay(3);
- SCL3=0;
- // uDelay(3);
- I2C_3(0x78);
- I2C_Ack3();
- void I2C_Stop3()
- SCL3=1;
- // uDelay(5);
- SDA3=0;
- // uDelay(5);
- SDA3=1;
- // uDelay(5);
- void Write_Command3(Uchar Data)
- I2C_Start3();
- I2C_3(0x00);
- I2C_Ack3();
- I2C_3(Data);
- I2C_Ack3();
- I2C_Stop3();
- void Write_Data3(Uchar Data)
- I2C_Start3();
- I2C_3(0x40);
- I2C_Ack3();
- I2C_3(Data);
- I2C_Ack3();
- I2C_Stop3();
- void LCD_Init3(void)
- //RES3=0;
- //uDelay(2);
- //RES3=1;
- //internal setting
- Write_Command3(0xae); //--turn off oled panel
- Write_Command3(0x00); //--set low column address
- Write_Command3(0x10); //--set high column address
- Write_Command3(0x40); //--set start line address
- Write_Command3(0xb0); //--set page address
- Write_Command3(0x81); //--set contrast control register
- Write_Command3(0xff);
- Write_Command3(0xa1); //--set segment re-map 127 to 0 a0:0 to seg127
- Write_Command3(0xa6); //--set normal display
- Write_Command3(0xc8); //--set com(N-1)to com0 c0:com0 to com(N-1)
- Write_Command3(0xa8); //--set multiples ratio(1to64)
- Write_Command3(0x3f); //--1/64 duty
- Write_Command3(0xd3); //--set display offset
- Write_Command3(0x00); //--not offset
- Write_Command3(0xd5); //--set display clock divide ratio/oscillator frequency
- Write_Command3(0x80); //--set divide ratio
- Write_Command3(0xd9); //--set pre-charge period
- Write_Command3(0xf1);
- Write_Command3(0xda); //--set com pins hardware configuration
- Write_Command3(0x12);
- Write_Command3(0xdb); //--set vcomh
- Write_Command3(0x8d); //--set chare pump enable/disable
- Write_Command3(0x14); //--set(0x10) disable
- //Write_Command3(0x10); //--set(0x10) disable
- Write_Command3(0xaf); //--turn on oled panel
- //-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=void LCD_Init(void)
- void pic13(void)
- Uchar i,j;
- Uint k;
- k=0;
- for(j=0;j<8;j++)
- Write_Command3(0x22);//--set page1
- Write_Command3(j);//--set start page
- Write_Command3(0x07);//--set end page
- for(i=0;i<128;i++) //显示单色数据到LCD
- Write_Data3(color13[k]);
- k=k+1;
- void pic14(void)
- Uchar i,j;
- Uint k;
- k=0;
- for(j=0;j<8;j++)
- Write_Data3(color14[k]);
- k=k+1;
- void main()
- LCD_Init3();
- while(1)
- pic13();
- delay_ms(10);
- pic14();
- delay_ms(10);
