- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- #include "usart.h"
- #include "asm88xx.h"
- low range of the sensor (this will be blue on the screen)
- #define MINTEMP 15
- high range of the sensor (this will be red on the screen)
- #define MAXTEMP 29
- #define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
- const uint16_t camColors[] = {0x480F,
- 0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
- 0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
- 0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
- 0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
- 0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
- 0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
- 0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
- 0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
- 0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
- 0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
- 0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
- 0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
- 0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
- 0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
- 0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
- 0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
- 0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
- 0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
- 0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
- 0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
- 0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
- 0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
- 0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
- 0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
- 0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
- 0xF080,0xF060,0xF040,0xF020,0xF800,};
- float temp;
- float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
- uint16_t arrColor[64];
- float map(float val, float I_Min, float I_Max, float O_Min, float O_Max)
- return(val/(I_Max-I_Min)*(O_Max-O_Min) + O_Min);
- void show(uint16_t *pBuf)
- { u8 i=0;
- u8 j=0;
- u16 colorr1=0;
- for(j=0;j<8;j++)
- for(i=0;i<8;i++)
- LCD_Fill(i*40,j*40,(i*40)+40,(j*40)+40,arrColor[colorr1]);
- colorr1++;
- }void pull_color(float *pPixel)
- uint8_t i;
- for(i = 0; i < 64; i ++)
- if(pPixel[i] < 10)
- arrColor[i] = BLUE;
- else if(pPixel[i] < 20)
- else if(pPixel[i] < 25)
- arrColor[i] = GREEN;
- else if(pPixel[i] < 30)
- arrColor[i] = RED;
- else if(pPixel[i] < 35)
- arrColor[i] = BRRED;
- int main(void)
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- LED_Init(); //LED端口初始化
- LCD_Init();
- amg88xx_init();
- while(1)
- amg88xx_readPixels(pixels, 64);
- pull_color(pixels);
- show(arrColor);
- LED0=!LED0;
全部资料51hei下载地址:
AMG8833识别成功.7z
(225.07 KB, 下载次数: 319)
