程序:
/******************调用头文件*******************/
#include "reg52.h"
#include "intrins.h"
/*****************定义地址**********************/
sbit KEY = P1^0; //按键
sbit ADD_C = P1^2;
sbit ADD_B = P1^3;
sbit ADD_A = P1^4; // 选输入口
sbit CLK = P1^5; // 时钟
sbit START = P1^6; // 转换启动信号
sbit EOC = P1^7; // 转换结束信号
sbit OE = P1^1; // 输出允许信号
/*****************定义全局变量********************/
int flag = 0;
/*****************数码管段码**********************/
unsigned char code DUAN[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00}; //不带小数点
unsigned char code DUAN1[] = {0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,0x80}; //带小数点
/*****************电压值区间******************/
float JS[] = {0,62.5,125,187.5,250,312.5,375,437.5,500};
/*******************读ADC*******************/
void read_adc(void)
START = 0;
_nop_();
START = 1;
_nop_();
START = 0;
while(EOC==0);
OE=1;
/*****************AD值区间计算*********************/
int LED_JS(float AD)
int t0 = 0;
int i = 0;
for(; i<8 ;i++)
if(AD >= JS[i])
if(AD <= JS[i+1])
t0 = i;
return t0+1;
/*****************不精确延时**********************/
void delay_ms(int i)
int j=0;
while(i--)
for(j=0;j<120;j++);
/*****************数码管显示**********************/
void display1(unsigned char ADC1_PORT)
int AD1 = ADC1_PORT * 500.0/255.0;
P2 = 0xFD; P0 = DUAN1[AD1/100]; delay_ms(5); // 位选:P2^1 个位
P2 = 0xFB; P0 = DUAN[(AD1/10)%10]; delay_ms(5); // 位选:P2^2 小数点后一位
P2 = 0xF7; P0 = DUAN[AD1%10]; delay_ms(5); // 位选:P2^3 小数点后两位
/*****************LED显示**********************/
void display2(unsigned char ADC2_PORT)
float AD2 = ADC2_PORT * 1.96;
P2 = 0xFF; // 清屏
switch(LED_JS(AD2))
case 1: P0 = 0xff; break;
case 2: P0 = 0xfe; break;
case 3: P0 = 0xfc; break;
case 4: P0 = 0xf8; break;
case 5: P0 = 0xe0; break;
case 6: P0 = 0xc0; break;
case 7: P0 = 0x80; break;
case 8: P0 = 0x00; break;
default:P0 = 0xef;
/*******************初始化*******************/
void init()
ADD_C=0;
ADD_B=1;
ADD_A=1; // 选择第三通道
CLK=0; //时钟
START=1; // 内部寄存器清零
EOC=1; // 转换结束
OE=0; // 使能
TMOD=0x02; // 0000_0010 8位 0~255
TH0=200;
TL0=200; // 装载初值
EA=1; // 开总中断
ET0=1; // 开定时器中断
TR0=1; // 开定时器
/****************mAin函数*******************/
init(); // 初始化
if(KEY == 0) // 检测到按键
delay_ms(5); // 防抖
if(KEY == 0)
while(!KEY); // 等松手
flag ++; // 加1
flag &= 0x01; // 与0x01相与 保证每次进入flag都为0或1
if(flag == 0)
read_adc();
display1(P3);
OE=0;
if(flag == 1)
read_adc();
display2(P3);
OE=0;
/****************中断服务程序*******************/
void TIM0_Serves() interrupt 1 // 用于产生CLK
CLK = !CLK;
01.zip
58.42 KB, 下载次数: 53, 下载积分: 黑币 -5
