查看: 1703|回复: 0
单片机lcd1602液晶显示秒表精确到0.01s,注释部分我懒得修改了,已经可....
ID:652868 发表于 2020-4-14 08:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit en=P3^4;
sbit rs=P3^5;
sbit rd=P3^7;
sbit s4=P3^6;
uchar fen,miao,s4num,count,mm;
uchar code table[]="    00:00:00 ";
void delay(uint z)//ÑÓʱº¯Êý
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
    rs=0;
    en=0;
    P0=com;
    delay(1);
    en=1;
    delay(1);
    en=0;
void write_data(uchar date)
    rs=1;
    en=0;
    P0=date;
    delay(1);
    en=1;
    delay(1);
    en=0;
void init()//³õʼ»¯
    uchar num;
    fen=00;
    miao=00;
    mm=00;
    write_com(0x38);
    delay(1);
    write_com(0x38);
    delay(1);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x80+0x40);
    for(num=0;num<12;num++)
            write_data(table[num]);
            delay(1);
        TMOD=0x10;
        TH1=(65536-10000)/256;
        TL1=(65536-10000)%256;
        EA=1;
        ET1=1;
        TR1=0;
void write_jishi(uchar add,uchar date)
    uchar shi,ge;
    shi=date/10;
    ge=date%10;
    write_com(0x80+0x40+add);
    write_data(0x30+shi);
    write_data(0x30+ge);
void keyscan()
    rd=0;
    if(s4==0)
        delay(1);
        if(s4==0)
            s4num++;
            while(!s4);
            if(s4num==1)
                TR1=1;
                mm++;
                if(mm==100)
                    mm=0;
                    miao++;
                    if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                            TR1=0;
                            write_jishi(4,fen);
                            write_com(0x80+0x40+5);
                    write_jishi(7,miao);
                    write_com(0x80+0x40+8);
                write_jishi(10,mm);
                write_com(0x80+0x40+11);
            if(s4num==2)
                TR1=0;
            if(s4num==3)
                s4num=0;
                write_com(0x0c);
                init();
    init();
        keyscan();
void timer0() interrupt 3
    count++;
    if(count!=0)
        mm++;
        if(mm==100)
            mm=0;
            miao++;
            if(miao==60)
                miao=0;
                fen++;
                if(fen==60)
                    TR1=0;
                write_jishi(4,fen);
        write_jishi(10,mm);
