查看: 1658|回复: 0
TM1637 STM32F103配置
ID:730478 发表于 2020-4-16 13:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "TM1637.h"
uint8_t  dpFlag = 0;//主函数有说明
unsigned char  Data[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char  DataDp[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
struct {
        char shi;
        char ge;
}Hour;
struct {
        char shi;
        char ge;
}Min;
  *@breif GPIO_INIT
  *@note  no
void SysTick_Delay_Us(unsigned int i)
   for(;i>0;i--);
void GPIO_Config(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        TM1637_RCC_Cmd(TM_DIO_CLK|TM_CLK_CLK,ENABLE);
        GPIO_InitStructure.GPIO_Pin = TM_DIO_PIN | TM_CLK_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//éè???aí?íìê?3?
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(TM_DIO_PORT,&GPIO_InitStructure);
时钟线为高时,数据线由高变低
void I2C_Start(void)
        CLK_1;
        DIO_1;
        SysTick_Delay_Us(140);
        DIO_0;
        CLK_0;
*时钟线为高时,数据线由低变高
void I2C_stop(void)
        CLK_0;
  DIO_0;
  CLK_1;
        DIO_1;
   //写一个比特位
    void TM1637_WriteBit(unsigned char mBit)
             CLK_0;
         if(mBit)
                   DIO_1;
                   DIO_0;
         CLK_1;
//写一个字节
    void TM1637_WriteByte(unsigned char Byte)
              char loop = 0;
              for(loop = 0;loop<8;loop++)
           TM1637_WriteBit((Byte>>loop) & 0x01);//先写低位
                    CLK_0;
        DIO_1;
        CLK_1;
        while(GPIO_ReadInputDataBit(TM_DIO_PORT ,TM_DIO_PIN) == 0x01);
                    //等待应答信号
*写指令函数
*B7:B6 =01  数据命令控制
*            11地址命令控制
*            10显示命令控制
void TM1637_WriteCommand(unsigned char mData)
        I2C_Start();
        TM1637_WriteByte(mData);
        I2C_stop();
*@note  写入地址和数据
void TM1637_WriteData(unsigned char addr,unsigned char mData)
        I2C_Start();
        TM1637_WriteByte(addr);
        I2C_stop();
   控制显示,配置好数据结构体之后,直接调用该函数就可以显示
    void Time_Display(void)
            TM1637_WriteCommand(0x40);
            if(dpFlag)
        TM1637_WriteData(0xc1,DataDp[Hour.ge]);
        TM1637_WriteData(0xc1,Data[Hour.ge]);
        TM1637_WriteData(0xc0,Data[Hour.shi]);
        TM1637_WriteData(0xc2, Data[Min.shi]);
        //TM1637_WriteData(0xc1, Data[Min.ge]);
        TM1637_WriteData(0xc3, Data[Min.ge]);
        TM1637_WriteCommand(0x8a);
