#include "main.h"
#include "HX711.h"
#include "uart.h"
#include "LCD1602.h"
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
long Weight_Shiwu = 0;
unsigned char flag = 0;
bit Flag_ERROR = 0;
sbit speak= P1^7;
//校准参数
//因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。
//当发现测试出来的重量偏大时,增加该数值。
//如果测试出来的重量偏小时,减小改数值。
//该值可以为小数
#define GapValue 400
//主函数
Uart_Init();
Send_Word("Welcome to use!\n");
Send_Word("Made by Beetle Electronic Technology!\n");
Init_LCD1602();
LCD1602_write_com(0x80);
LCD1602_write_word("Welcome to use!");
Delay_ms(1000); //延时,等待传感器稳定
Get_Maopi(); //称毛皮重量
EA = 0;
Get_Weight(); //称重
EA = 1;
Scan_Key();
//显示当前重量
if( Flag_ERROR == 1)
Send_Word("ERROR\n");
LCD1602_write_com(0x80+0x40);
LCD1602_write_word("ERROR ");
speak=0;
speak=1;
Send_ASCII(Weight_Shiwu/1000 + 0X30);
Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
Send_ASCII(Weight_Shiwu%100/10 + 0X30);
Send_ASCII(Weight_Shiwu%10 + 0X30);
Send_Word(" g\n");
LCD1602_write_data(Weight_Shiwu/1000 + 0X30);
LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
LCD1602_write_data(Weight_Shiwu%10 + 0X30);
LCD1602_write_word(" g");
//扫描按键
void Scan_Key()
if(KEY1 == 0)
Delay_ms(5);
if(KEY1 == 0)
while(KEY1 == 0);
Get_Maopi(); //去皮
//称重
void Get_Weight()
Weight_Shiwu = HX711_Read();
Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取净重
if(Weight_Shiwu > 0)
Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue); //计算实物的实际重量
if(Weight_Shiwu > 5000) //超重报警
Flag_ERROR = 1;
Flag_ERROR = 0;
Weight_Shiwu = 0;
// Flag_ERROR = 1; //负重报警
//获取毛皮重量
void Get_Maopi()
Weight_Maopi = HX711_Read();
//MS延时函数(12M晶振下测试)
void Delay_ms(unsigned int n)
unsigned int i,j;
for(i=0;i<n;i++)
for(j=0;j<123;j++);
