红外接收头收到红外码后马上发送一个一样的红外码出去,需要做万能遥控的自行保存红外码再发出去即可
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "Infrared.h"
- int main(void)
- u8 t;
- u8 len;
- u16 times=0;
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2
- uart_init(9600); //串口初始化为9600
- TIM2_PWM_Init(1895,0);
- Infrared_GPIO_Configuration();
- Infrared_EXTI_Configuration();
- while(1)
复制代码- /***************************************************************************************
- * FileName : Infrared.c
- * CopyRight :
- * ModuleName :
- * CPU :
- * RTOS :
- * Create Data : 2015/04/21
- * Author/Corportation : Ray
- * Abstract Description :
- *--------------------------------Revision History--------------------------------------
- * No version Data Revised By Item Description
- * 1 v1.0 2015/4/21 Ray Create this file
- * 2 v2.0 2015/4/23 Ray Sucessfully control the air conditioner
- * 3 v2.1 2015/4/24 Ray Packaging the Infrared Module
- * Debug switch Section
- * Include File Section
- * Macro Define Section
- //debug调试宏定义,根据表达式a的真假执行has_bug或no_bug
- #define BUG_DETECT_PRINT(a,has_bug,no_bug) { if(a) \
- printf("%s",has_bug); \
- else \
- printf("%s",no_bug);}
- * Struct Define Section
- * Prototype Declare Section
- * Global Variable Declare Section
- u8 Flag_LearnState = 0;
- u16 PulseTab[MAX_PULSE_LEN];
- * File Static Variable Define Section
- * Function Define Section
- #ifdef INFRARED_RECEIVE
- * @name void Infrared_GPIO_Configuration()
- * @description 红外接收端GPIO口设置
- * @param PA.01 作外部中断接收口
- * @return
- * @notice
- void Infrared_GPIO_Configuration()
- GPIO_InitTypeDef GPIO_InitType;
- RCC_APB2PeriphClockCmd(INFRARED_RCC_GPIOx,ENABLE);
- GPIO_InitType.GPIO_Mode = GPIO_Mode_IPU; //上拉输入
- GPIO_InitType.GPIO_Pin = INFRARED_GPIO_Pinx;
- GPIO_InitType.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(INFRARED_GPIOx,&GPIO_InitType);
- GPIO_EXTILineConfig(INFRARED_EXTI_GPIOx,INFRARED_EXTI_Line);
- * @name void Infrared_EXTI_Configuration()
- * @description 红外线接受端外部中断初始化设置,设置为 线路1,使用PA.1作为外部中断的输入端
- * @param
- * @return
- * @notice 若改变外部中断的输入端,此函数内的线路设置也需改变s
- void Infrared_EXTI_Configuration()
- EXTI_InitTypeDef EXTI_InitType;
- NVIC_InitTypeDef NVIC_InitType;
- EXTI_InitType.EXTI_Line = EXTI_Line1;
- EXTI_InitType.EXTI_Mode = EXTI_Mode_Interrupt;
- EXTI_InitType.EXTI_Trigger = EXTI_Trigger_Falling;
- EXTI_InitType.EXTI_LineCmd = ENABLE;
- EXTI_Init(&EXTI_InitType);
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //NVIC 中断设置
- NVIC_InitType.NVIC_IRQChannel = EXTI1_IRQn;
- NVIC_InitType.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitType.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitType.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitType);
- * @name void EXTI1_IRQHandler()
- * @description 外部中断1中断处理程序,用于采集红外波形
- * @param
- * @return 全局变量Flag_LearnState可以用于返回是否有学习到波形
- * @notice
- void EXTI1_IRQHandler()
- u16 pulseWidth = 0;
- u16 i = 0;
- Flag_LearnState = 0;
- //中断指示
- while(1)
- if(IR_RDATA) //有高脉冲出现,代表空闲信号
- pulseWidth = 0;
- while(IR_RDATA)
- pulseWidth++;
- delay_us(19);
- if(pulseWidth >= 2000) // >40ms 则结束记录
- break;
- if(pulseWidth<=15 || pulseWidth>=2000) // >40ms || <300us 则结束记录
- break;
- PulseTab[i] = pulseWidth*20;
- i++;
- else //载波信号,偶数位为低电平(载波),奇数位为高电平(空闲)
- pulseWidth = 0;
- while(IR_RDATA == 0)
- pulseWidth++;
- delay_us(19);
- if(pulseWidth<=15 || pulseWidth>=2000) // >40ms || <300sus 则结束记录
- break;
- i++;
- PulseTab[i++] = pulseWidth;
- PulseTab[i] = 0xffff;
- Flag_LearnState = 1;
- Infrared_Send();
- EXTI_ClearITPendingBit(EXTI_Line1);
- return;
- #endif
- #ifdef INFRARED_SEND
- * @name void Infrared_Send()
- * @description 红外发射,根据 PulseTab[]内的数据发波形
- * @param
- * @return
- * @notice
- void Infrared_Send()
- u16 i;
- EXTI->IMR &= ~(0x00000002); //关中断,避免发送的红外线被自己接受
- for(i=0; i<MAX_PULSE_LEN && PulseTab[i]!=0xffff; i++)
- if(i%2 == 0)
- TIM_Cmd(TIM2,ENABLE);
- delay_us(PulseTab[i]);
- TIM_Cmd(TIM2,DISABLE);
- GPIO_SetBits(GPIOA,GPIO_Pin_0);
- else
- GPIO_ResetBits(GPIOA,GPIO_Pin_0);
- EXTI->IMR |= (0x00000002); //开中断
- * @name void TIM2_PWM_Init(u16 arr,u16 psc)
- * @description 初始化定时器2的设置,将定时器2用于PWM调制,PWM输出口为 PA.0
- * @param arr -- u16,定时器重装值
- psc -- u16,定时器分频值
- * @return
- * @notice PWM频率 = 72M/((arr+1)*(psc+1)),这里用作红外发射的载波,需要生成38kHz的方波,故取arr = 1895,psc = 0。
- void TIM2_PWM_Init(u16 arr,u16 psc)
- /* 初始化结构体定义 */
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* 使能相应端口的时钟 */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能定时器2时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能GPIO外设时钟
- /* GPIOA.0初始化 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; // TIM2 CH1
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // PA.0 复用推挽输出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* TIM2 初始化*/
- TIM_TimeBaseInitStructure.TIM_Period = arr; //下一个更新事件装入活动的自动重装载寄存器周期的值
- TIM_TimeBaseInitStructure.TIM_Prescaler = psc; //作为TIMx时钟频率除数的预分频值
- TIM_TimeBaseInitStructure.TIM_ClockDivision = 0; //时钟分割:TDTS = Tck_tim
- TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseInitStructure);
- /* 定时器TIM2 Ch1 PWM模式初始化 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //选择定时器模式:TIM PWM1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
- //TIM_OCInitStructure.TIM_Pulse = (arr+1)/2; //占空比 50%
- TIM_OCInitStructure.TIM_Pulse = (arr+1)/3; //占空比1:3
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高
- TIM_OC1Init(TIM2, &TIM_OCInitStructure);
- /* 使能TIM2在CCR1上的预装载寄存器 */
- TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
- /* 使能定时器 */
- // TIM_Cmd(TIM2,ENABLE);
- #endif
- * @name
- * @description
- * @param
- * @return
- * @notice
- #ifdef DEBUG
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert_param error line source number
- * Output : None
- * Return : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- #endif
空调.7z
(195.4 KB, 下载次数: 129)
