查看: 2569|回复: 2
单片机程序红色部分 'WriteOneChar': missing function-prototype怎么改正
ID:747812 发表于 2020-5-11 18:57 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<stdio.h>
#define Alarm 10
sbit DQ=P2^4;
sbit Beep=P3^4;
unsigned char tempL=0, tempH=0;
unsigned char flag=0;
unsigned int temperature,negtemper;
unsigned char idataaddrdat[2]= {0x0,0x0};
unsigned char tab[]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char
tab1[]= {0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78, 0x00, 0x10} ;
unsigned char dispbuf[3]={0, 0, 0};
unsigned char warning=30;
bit on=1,off=0;
void delay (unsigned int i)
while(i--);
void beep(bit i)
Beep=i;
void Init_DS18B20(void)    //?????????
unsigned char x=0;
DQ=1;         //DQ ?????
delay(8);  //?????
DQ=0;   //?????λ????
delay(85);     //???(>480us)
DQ=1;     //??????????
delay(14);    //???(15-60us)
x=DQ;
delay (20);
ReadOneChar (void)
unsigned char i=0;    //????????????????????????
unsigned char dat=0;   //????1ms????
for(i=8;i>0;i--)   //?????????????????????
{DQ=1;      //?????????????????60us
delay(1);       //????????????lms ?????????????
DQ=0;
dat>>=1;
DQ=1;
if(DQ)
dat|=0x80;
delay(4);
return (dat);
WriteOreChar (unsigned char dat)
  unsigned char i=0;
  for(i=8;i>0;i--)
  DQ=0;
  DQ=dat&0x01;
  delay(5);
  DQ=1;
  dat>>=1;
delay(4);
Read_Temperature (void)
   Init_DS18B20();
WriteOneChar(0xcc);
   WriteOneChar(0x44);
   delaymm(125);
    Init_DS18B20();
    WriteOneChar(0xcc);                 这里总 'WriteOneChar': missing function-prototype    怎么改正
    WriteOneChar(0xbe);
   delaymm(125);
    tempL=ReadOneChar();
    tempH=ReadOneChar();
temperature=(tempH*256)+tempL;
return(temperature) ;
voidDispbuf (unsigned int temper)
   unsigned char temp;
dispbuf[2]=(temper>>4)/10;
dispbuf[1]= (temper>>4)%10;
temp=temper&0x0F;
dispbuf[0]=temp*625/1000;
unsigned char getkey()
P2=0xff;
if (P2==0xfe)
delay(12000) ;
if (P2!=0xfe);
else return P2;
if(P2==0xfd)
delay(12000) ;
if (P2!=0xfd) ;
else return P2;
if (P2-=0xfb)
delay (12000) ;
if (P2!=0xfb);
else return P2;
  Inter0_process() interrupt 2
unsigned char key ;
int i;
unsigned char dis=0x01;
unsigned int j ;
for (j=5000;j>0;j--)
key=getkey();
if (key==0xfe)
   warning++;
   delay (80) ;
if (key==0xfd)
warning-- ;
delay (80) ;
if (key==0xfb)
j=1;
for(i=0;i<2;i++)
  P1=dis;
  dis<<=1;
  if(i==0)
P0=tab[warning%10];
P0=tab[warning/10];
delay (200) ;
dis=0x01;
   main()
unsigned char i,npos=0x01;
P0=0xff;
P2=0xff;
P1=0xff;
EX1=1;
IT1=1
ET1=1;
EA=1;
if((temperature&0xf000)==0xf000)
ReadTemperature();
for(i=0;i<4;i++)  //4?LED???
negtemper=(~temperature)+1;
Dispbuf (negtemper);
P1=npos;
npos<<=1;
if(i==1)
P0=tabl[dispbuf[ i]]
delay (500);
else if(i==3)
P0=0xhf;
P0=tab[dispbuf[ i]];
delay(500);
npos=0x01;
for(i=0;i<3;i++);
ReadTemperature();
Dpispbuf(temperature);
if(((temperature>>4)&0xff)=warning)
beep (on) ;
else beep(off)
P1=npos;
npos<<=1;
if(i==1)
  P0=tabl [dispbuf[ i]];
   delay (100);
npos=0x01;
ID:213173 发表于 2020-5-12 05:59 | 显示全部楼层
ASADAA 发表于 2020-5-11 19:12
急急急,求大神帮忙    怎么声明那个函数
楼主再怎么急也得认真抄写!一百多条代码近1/4抄写错误。
ID:747812 发表于 2020-5-11 19:12 | 显示全部楼层
急急急,求大神帮忙    怎么声明那个函数
