查看: 1256|回复: 0
stc12c5a单片机串口通信问题
回帖奖励 80 黑币 回复本帖可获得 20 黑币奖励! 每人限 3 次(中奖概率 80%)
ID:505833 发表于 2020-5-26 09:03 | 显示全部楼层 |阅读模式
该项目是基于stc12c5a 与tfmini通信以及bh1750通信。是在tfmini例程上改写,写得我有点懵了。之前好像还可以用串口2接受到tfmini传来的数据。现在不行了,不知道怎么回事,求助大佬们,拜托!若需要完整程序测试也可以私我,感谢!!
#include <stdio.h>
#include "stc12c5a60s2.h"        //the file come from stc-sip V6.86
#include <BH1750.c>
#define FOSC 11059200L        //System frequency
unsigned char Sensor_Data[5]={0x00,0x00,0x00,0x00,0x00};
typedef struct {
        int distance;
        int strength;
        char receiveComplete;
}TFmini;
TFmini tfmini = {0, 0, 0};
to get the light value from bh1750.c
void conversion(uint temp_data)  //  êy?Y×a??3? ??£?ê?£?°ù£??§£?íò
    Sensor_Data[0]=temp_data/10000+0x30 ;
    temp_data=temp_data%10000;   //è?óà????
          Sensor_Data[1]=temp_data/1000+0x30 ;
    temp_data=temp_data%1000;    //è?óà????
    Sensor_Data[2]=temp_data/100+0x30   ;
    temp_data=temp_data%100;     //è?óà????
    Sensor_Data[3]=temp_data/10+0x30    ;
    temp_data=temp_data%10;      //è?óà????
    Sensor_Data[4]=temp_data+0x30;
TFmini 9 bytes output:
[0x59, 0x59, distanceL, distanceH, strengthL, strengthH, Mode, 0x00, checksum]
void getTFminiData(TFmini *tfmini) {
        static unsigned char i = 0 ;
        unsigned char j = 0;
        unsigned int b=0;
        unsigned int checksum = 0;
        static unsigned char rx[9];
        if(S2CON & 0x01) {        //uart2 receive interrupt flag
                S2CON &= ~(0x01);        //clear uart2 receive interrupt flag
                rx[ i] = S2BUF;        //uart2 buf
                if(rx[0] != 0x59) {
                        i = 0;
                } else if(i == 1 && rx[1] != 0x59) {
                        i = 0;
                } else if(i == 8) {
                        tfmini->receiveComplete = 1;
                        //printf("\r\n");
                        for(j = 0; j < 8; j++) {
                                checksum += rx[j];
                        if(rx[8] == (checksum % 256)) {
                                tfmini->distance = rx[2] + rx[3] * 256;
                                tfmini->strength = rx[4] + rx[5] * 256;
                        i = 0;
                } else {
                        i++;
Timer2 as baudtare generator.
When FOSC = 11059200L, baudrate <= 345600(11059200/32)
void Uart_Init(unsigned long baudrate1, unsigned long baudrate2) {
        //Uart1 Init. Uart1 can select Timer1 or BRT as baudrate generator
        SCON = 0x50;            //8-bit variable UART
        //AUXR |= 0x01;                        //selectBRT as baudrate generator
        AUXR |= 0x40;                        //Set Timer1 1T Mode
        TMOD |= 0x20;                   //Set Timer1 as 8-bit auto reload mode
        TH1 = TL1 = -(FOSC/32/baudrate1); //Set auto-reload vaule
        TR1 = 1;                //Timer1 start run
        //ES = 1;
        //Uart2 Init. Uart2 can only select BRT as baudrate generator
        //AUXR &=0XF7;
        S2CON = 0x50;           //8-bit variable UART
        BRT = -(FOSC/32/baudrate2);  //Set auto-reload vaule of baudrate generator
        AUXR |= 0x14;            //Baudrate generator work in 1T mode
        IE2 = 0x01;             //Enable UART2 interrupt
        EA = 1;
        SBUF = '\n';        //It's needed to give SBUF a random character if printf is used.
                   usart1·¢?íò???×??ú
void SendByte(unsigned char dat)
SBUF = dat;
while(!TI);
      TI = 0;
                    ·¢?íò???×?·?′?
void SendStr(unsigned char *s)
while(*s!='\0')// \0 ±íê?×?·?′??áê?±ê??£?             //í¨1y?ì2aê?·?×?·?′????2
  if(*s=='*')
  SendByte(0x22);
  SendByte(*s);
  s++;
void main() {
  unsigned int b;
        Uart_Init(9600, 115200);
        Init_BH1750();//initialize the bh1750
        printf("Hello, TFmini!\r\n");
        b=getlx();//set b the result of bh1750
        conversion(b);//get the light value store in Sensor_data
        while(1) {
  if(tfmini.receiveComplete == 1) {
  tfmini.receiveComplete = 0;
  printf("(%d, %d)\r\n", tfmini.distance, tfmini.strength);
  SendStr(Sensor_Data);
/*void Uart() interrupt 4 using 1 {
void Uart2() interrupt 8 using 1 {
        getTFminiData(&tfmini);
