设计实现24秒计时器。要求:
(1)倒计时功能
(2)24秒复位键功能
(3)启动/暂停键功能
- #include<reg51.h>
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- typedef unsigned int uint;
- uint i,j,f1=0;
- uint q=4,p=2;
- uint sum = 0;
- sbit P2_0=P2^0;
- sbit P2_1=P2^1;
- sbit P2_2=P2^2;
- sbit P2_3=P2^3;
- uint num2=0,num=24,shi=2,ge=4;
- void T1_time()interrupt 3
- TH1=(65536-49000)/256;
- TL1=(65536-49000)%256;
- num2++;
- if(num2==20){
- num2=0;
- if(!f1){
- if(num!=0)num--;
- shi=num/10;
- ge=num%10;
- void ex_int()interrupt 0
- num=24;
- void ex_int1()interrupt 2
- sum++;
- if(sum%2==1)
- f1=1;
- else
- f1=0;
- void delay()
- uint j;
- for(j=0;j<200;j++);
- void disply()
- P2&=0XF0;
- P1=table[shi];
- P2_0=1;
- delay();
- P2&=0XF0;
- P1=table[ge];
- P2_1=1;
- delay();
- P1=0;
- P2&=0XF0;
- main()
- TMOD=0X10;
- EA=1;
- EX0=1;
- IT0=1;
- EX1=1;
- IT1=1;
- ET1=1;
- TR1=1;
- while(1)
- disply();
