查看: 4301|回复: 1
51单片机+L298按键控制双直流电机正反转+时间显示+蜂鸣器 Proteus仿真程序
ID:447468 发表于 2020-6-21 15:30 | 显示全部楼层 |阅读模式
proteus仿真图+源程序
  1. #include<AT89X52.H>                  //包含51单片机头文件,内部有各种寄存器定义
  2. #include<lcd.h>
  3. uchar n='0',num0=0,num1=0;
  4. char zuo_pwm=50,you_pwm=50 ;
  5. sbit keyopen = P1^0;         //按键
  6. sbit keyclose = P1^1;         //按键
  7. sbit keyleft = P1^2;         //按键
  8. sbit keyright = P1^3;         //按键
  9. sbit keybeep = P1^4;         //按键
  10. sbit kkey = P2^5;         //按键
  11. sbit beep = P1^7;
  12. unsigned char dj1=0;
  13. unsigned char dj2=0;
  14. unsigned char  s=0;
  15. sbit ENA=P3^7;          //PWM输入
  16. sbit ENB=P2^7;
  17. sbit IN5=P3^0;          //电机
  18. sbit IN6=P3^1;
  19. sbit IN7=P1^5;
  20. sbit IN8=P1^6;
  21. void delay(uint z)//延时1ms函数
  22. {
  23. uint x,y;
  24. for(x=0;x<z;x++)
  25.      for(y=0;y<110;y++);
  26. }
  27. //前速前进
  28. void  run(void)
  29. {
  30.         IN5=1;
  31.         IN6=0;
  32.         IN7=1;
  33.         IN8=0;
  34.         zuo_pwm=20;
  35.         you_pwm=20;
  36. }
  37.   //左转
  38. void  left(void)
  39. {
  40.         IN5=1;
  41.         IN6=0;
  42.         IN7=0;
  43.         IN8=1;
  44.         zuo_pwm=15;
  45.         you_pwm=15;
  46. }
  47. //右转
  48. void  right(void)
  49. {
  50.         IN5=0;
  51.         IN6=1;
  52.         IN7=1;
  53.         IN8=0;
  54.         zuo_pwm=15;
  55.         you_pwm=15;
  56. }
  57. void fbeep(void)
  58. {        char j,k;
  59.         j=250;
  60.         while(j--)
  61.         {
  62.         beep=~beep;
  63.         for(k=0;k<28;k++);                //0.24ms半周期=2083Hz
  64.         }
  65.         beep=1;
  66.         delay(250);
  67. }
  68. //停止
  69. void  stop(void)
  70. {
  71.             IN5=0;
  72.         IN6=0;
  73.         IN7=0;
  74.         IN8=0;
  75.         zuo_pwm=0;
  76.         you_pwm=0;
  77. }
  78. void init()          //time0
  79. {
  80.         SCON=0x50;
  81.         TMOD |= 0x01;                  //设置定时器模式
  82.             TL0 = 0x91;                    //设置定时初值
  83.         TH0 = 0xFF;                    //设置定时初值
  84.         EA=1;                          //打开总中断
  85.         ET0=1;                         //打开定时器0中断允许
  86. }
  87. //主函数
  88. void main(void)
  89. {
  90.         init();
  91.         InitLcd1602();
  92.         beep=1;
  93.         while(1)
  94.         {
  95.                 if(kkey == 0)
  96.                 {
  97.                         Lcd1602_Write_Cmd(0x01);    //清屏
  98.                         while(1)                                        //无限循环
  99.                         {
  100.                             display_str();
  101.                                 display_time();
  102.                                 if(keyopen==0)
  103.                                 {
  104.                                         delay(50);
  105.                                         if(keyopen==0)
  106.                                                 run();
  107.                                                 while(!keyopen);
  108.                                 }
  109.                                 if(keyclose==0)
  110.                                 {
  111.                                         if(keyclose==0)
  112.                                                         stop();
  113.                                                 while(!keyclose);
  114.                                         //break;
  115.                                 }
  116.                                 if(keyleft==0)
  117.                                 {
  118.                                         if(keyleft==0)
  119.                                                         left();
  120.                                                 while(!keyleft);
  121.                                 }
  122.                                 if(keyright==0)
  123.                                 {
  124.
  125.                                         if(keyright==0)
  126.                                                         right();
  127.                                                 while(!keyright);
  128.                                 }
  129.                                 if(keybeep==0)
  130.                                 {
  131.                                         fbeep();
  132.                                 }
  133.                          }
  134.                  }
  135.                  else
  136.                  {
  137.                       display_school();
  138.                           stop();
  139.                  }
  140.         }
  141. }
  142. void Timer1Interrupt(void) interrupt 1
  143. {
  144.             TL0 = 0x91;                //设置定时初值
  145.         TH0 = 0xFF;                //设置定时初值
  146.
  147.         num0++;                             //PWM调占空比
  148.         num1++;
  149.         if(num0<=zuo_pwm)
  150.         {
  151.                         ENB=1;
  152.                 }
  153.         else
  154.                 {
  155.             ENB=0;
  156.                 }
  157.         if(num0>=40)
  158.         {
  159.                 //ENB=~ENB;
  160.             num0=0;
  161.         }
  162.         if(num1<=you_pwm)
  163.         {
  164.                 ENA=1;
  165.         }
  166.         else
  167.                 {
  168.                 ENA=0;
  169.                 }
  170.         if(num1>=40)
  171.         {
  172.                         //ENA=~ENA;
  173.                         num1=0;
  174.                 }
  175.
  176. }
仿真.rar (101.81 KB, 下载次数: 112)
ID:1025125 发表于 2022-5-11 14:05 | 显示全部楼层
请问在keil编译过后显示以下情况,该怎么解决 *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL     SYMBOL:  ?C_START     MODULE:  STARTUP.obj (?C_STARTUP) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL     SYMBOL:  ?C_START     MODULE:  STARTUP.obj (?C_STARTUP)     ADDRESS: 080AH Program Size: data=9.0 xdata=0 code=15 creating hex file from "fz"... "fz" - 0 Error(s), 2 Warning(s).
