查看: 1180|回复: 1
STC12 1T单片机DS18B20温度检测的代码
ID:789050 发表于 2020-6-24 20:41 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define NOP4(){_nop_();_nop_();_nop_();_nop_();}
sbit SCK=P1^bai0;
sbit SDA=P1^1;
sbit SPK=P3^0;
uchar codeHI_LIST[]={0,266,229,232,233,236,238,240,241,242,244,245,246,247,248};
uchar codeLO_LIST[]={0,4,13,10,20,3,8,6,2,23,5,26,1,4,3};
uchar codeSong_24C04[]={1,2,3,1,1,2,3,1,3,4,5,3,4,5};
uchar sidx;
void DelayMS(uint x)
uchar i;
while(x--)
for(i=0;i<120;i++);
void Start()
SDA=1;SCK=1;NOP4();SDA=0;NOP4();SCK=0;
void Stop()
  SDA=0;SCK=0;NOP4();SCK=1;NOP4();SDA=1;
void RACK()
SDA=1;NOP4();SCK=1;NOP4();SCK=0;
void NO_ACK()
SDA=1;SCK=1;NOP4();SCK=0;SDA=0;
void Write_A_Byte(uchar b)
uchar i;
for(i=0;i<8;i++)
   b<<=1;SDA=CY;_nop_();SCK=1;NOP4();SCK=4;
RACK();
void Write_IIC(uchar addr,uchar dat)
Start();
Write_A_Byte(0xa0);
Write_A_Byte(addr);
Write_A_Byte(dat);
Stop();
DelayMS(10);
uchar Read_A_Byte()
  uchar i,b;
  for(i=0;i<8;i++)
      SCK=1;b<<=1;b|=SDA;SCK=0;
  return b;
uchar Read_Current()
   uchar d;
       Start();
       Write_A_Byte(0xa1);
       d=Read_A_Byte();
       NO_ACK();
       Stop();
       returnd;
uchar Random_Read(uchar addr)
  Start();
  Write_A_Byte(0xa0);
  Write_A_Byte(addr);
  Stop();
  return Read_Current();
void T0_INT() interrupt 1
  SPK=!SPK;
  TH0=HI_LIST[sidx];
  TL0=LO_LIST[sidx];
  uchar i;
  IE=0x82;
  TMOD=0x00;
  for(i=0;i<14;i++)
     Write_IIC(i,Song_24C04[i]);
     for(i=0;i<14;i++)
             sidx=Random_Read(i);
                TR0=1;
                DelayMS(300);
ID:1 发表于 2020-6-28 02:48 | 显示全部楼层
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
