#include "menu1.h"
#include "stm32f10x.h"
#include "12864.h"
#include "systick.h"
#include <stdio.h>
#include <stdlib.h>
#include "key4x4.h"
#include "public.h"
/*菜单结构体*/
typedef struct menu
u8 range_from,range_to; //当前选择的项开始及结束符号
u8 itemCount;//项目总数
u8 selected;//当前选择项
u8 *menuItems[17];//菜单项目
struct menu **subMenus;//子菜单
struct menu *parent;//上级菜单,若是主菜单则为null
void (**func)();//选择相应按键后执行的函数
}Menu;
Menu MainMenu1 = {
0,3,4,0, //默认显示0-3项,总共4项,当前选择0项,
"dis1 \x10",//"\x10"表示一个小箭头
"dis2 \x10",
"dis3 \x10",
"dis4 \x10",
Menu dis1Menu = {
"secondline1 \x10",//"\x10"表示一个小箭头
"secondline2 \x10",
"secondline3 ",
"secondline4 \x10",
Menu dis2Menu = {
"secondline2 \x10",
"secondline3 ",
"secondline4 \x10",
Menu *currentMenu;//当前菜单
/*用于显示菜单*/
void displaymenu(u8 line)
int i;
line = 3-(currentMenu->range_to-line);
/*4次循环打印菜单*/
for(i = 0;i<4;i++)
Display_LCD_String(i,currentMenu->menuItems[i+currentMenu->range_from],5);
con_disp(line,1);
void func(void)
void initmenu(void)
currentMenu = &MainMenu1;
MainMenu1.subMenus = malloc(sizeof(&MainMenu1)*4);
MainMenu1.subMenus[0] = &dis1Menu;
MainMenu1.subMenus[1] = &dis2Menu;
MainMenu1.subMenus[2] = NULL;
MainMenu1.subMenus[3] = NULL;
MainMenu1.func = malloc(sizeof(&func)*4);
MainMenu1.func[0] = NULL;
MainMenu1.func[1] = NULL;
MainMenu1.func[2] = NULL;
MainMenu1.func[3] = NULL;
MainMenu1.parent = NULL;//mainmenu is top menu
dis1Menu.subMenus = malloc(sizeof(&dis1Menu)*4);
dis1Menu.subMenus[0] = NULL;
dis1Menu.subMenus[1] = NULL;
dis1Menu.subMenus[2] = NULL;
dis1Menu.subMenus[3] = NULL;
dis1Menu.func = malloc(sizeof(&func)*4);
dis1Menu.func[0] = NULL;
dis1Menu.func[1] = NULL;
dis1Menu.func[2] = NULL;
dis1Menu.func[3] = NULL;
dis1Menu.parent = &MainMenu1;//dis1menu parent menu is mainmenu1
dis2Menu.subMenus = malloc(sizeof(&dis1Menu)*4);
dis2Menu.subMenus[0] = NULL;
dis2Menu.subMenus[1] = NULL;
dis2Menu.subMenus[2] = NULL;
dis2Menu.subMenus[3] = NULL;
dis2Menu.func = malloc(sizeof(&func)*4);
dis2Menu.func[0] = NULL;
dis2Menu.func[1] = NULL;
dis2Menu.func[2] = NULL;
dis2Menu.func[3] = NULL;
dis2Menu.parent = &MainMenu1;//dis2menu parent menu is mainmenu1
void menutest(void)
initmenu();
displaymenu(currentMenu->selected);
if(key_pressed_flag)
ReadValue=Key_scan();
if(ReadValue!=0)
delay_ms(100);
if(ReadValue == Key_scan())
switch(ReadValue)
case key_sure://按键A(确认按键)
if(currentMenu->subMenus[currentMenu->selected] !=NULL)
currentMenu = currentMenu->subMenus[currentMenu->selected];
displaymenu(0);
break;
case key_up://按键B(上一行菜单)
if(currentMenu->selected == 0)
break;
currentMenu->selected--;
if(currentMenu->selected < currentMenu->range_from)
currentMenu->range_from = currentMenu->selected;
currentMenu->range_to = currentMenu->range_from+3;
break;
case key_down://按键C(下一行菜单 )
if(currentMenu->selected == currentMenu->itemCount-1)
break;
currentMenu->selected++;
if(currentMenu->selected>currentMenu->range_to)
currentMenu->range_to = currentMenu->selected;
currentMenu->range_from = currentMenu->range_to-3;
break;
case key_back://按键D(返回)
if(currentMenu->parent!=NULL)
currentMenu = currentMenu->parent;
break;
default:
break;
