查看: 1796|回复: 1
迪文显示屏串口通信
ID:539016 发表于 2020-10-28 10:28 | 显示全部楼层 |阅读模式
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f1xx_hal.h"
#include "crc.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
void PLC_Data_Wr2HMI(uint16_t HMI_start_addr,uint16_t PLC_return_data_start_addr,uint8_t len);
void WRITE_HMI(uint16_t addr,uint8_t data1,uint8_t data2,uint8_t data3,uint8_t data4,uint8_t len);
void READ_HMI(uint16_t addr,uint8_t num);
void CLOSE_OPEN_IO(uint8_t hmi_key_value);
void SCAN_KEY(uint8_t io_key_value);
void delay_ms(uint16_t nms);
extern uint16_t USART_Calc_CRC16(uint8_t *Ptr, uint8_t u8BuffLen);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
uint8_t HMI_SEND_BUF[20] = {0};
uint8_t usart1_counter = 0;
uint8_t usart1_data;
uint8_t usart1_rxBuf[50];
uint8_t usart1_txBuf[50];
uint8_t HMI_HANDLEFLAG;
uint8_t LED_FLAG[4] = {0};
uint8_t HMI_FLAG[5] = {0};
uint8_t TEMP = 25;//éÏμçζè
uint8_t VOLUME = 50;//éÏμçòôá¿
uint8_t UP_POWER_FLAG=0;
int main(void)
        uint8_t i;
        HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  while (1)
                HAL_UART_Receive_IT(&huart1,&usart1_data,1);
                if(UP_POWER_FLAG == 0)//éÏμç3õê¼»ˉ′¥ÃtÆá
                        UP_POWER_FLAG = 1;
                        HMI_SEND_BUF[0] = TEMP;
                        PLC_Data_Wr2HMI(0X1110,0,1);
                        delay_ms(100);
                        for(i=0;i<4;i++)
                                HMI_SEND_BUF[i] = 0;
                        for(i=0;i<20;i++)
                                usart1_rxBuf[i] = 0x00;
                        HMI_HANDLEFLAG = 0;
                SCAN_KEY(0);//°′¼üé¨Ãè
                if(HMI_HANDLEFLAG)//½óêÕ′¥ÃtÆáêy¾Y′|àí
                        HMI_HANDLEFLAG = 0;
                        CLOSE_OPEN_IO(0x01);
                        CLOSE_OPEN_IO(0x02);
                        CLOSE_OPEN_IO(0x03);
                        CLOSE_OPEN_IO(0x04);
                        for(i=0;i<50;i++)
                        usart1_counter = 0;
    uint8_t u8CRCHi = 0xFF ;
    uint8_t u8CRCLo = 0xFF ;
    uint16_t u16Index ;
    while (u8BuffLen--)
                        u16Index = u8CRCLo ^ *Ptr++ ;
                        u8CRCLo = u8CRCHi ^ u8CRCHTbl[u16Index] ;
                        u8CRCHi = u8CRCLTbl[u16Index] ;
    return (uint16_t)(u8CRCHi << 8) + u8CRCLo;
void PLC_Data_Wr2HMI(uint16_t HMI_start_addr,uint16_t PLC_return_data_start_addr,uint8_t len)//êy¾YD′èë′¥ÃtÆá±äῼÄ′æÆ÷
        uint8_t i;
        uint16_t CRC_tmp;
        uint8_t BUFF_ptr = 0;
        usart1_txBuf[0]=0x5a;
        usart1_txBuf[1]=0xa5;
//        usart1_txBuf[2]=len*2+3;
        usart1_txBuf[3]=0x82;
        usart1_txBuf[4]=((uint8_t)(HMI_start_addr>>8))&0XFF;
        usart1_txBuf[5]=(uint8_t)(HMI_start_addr&0XFF);
        BUFF_ptr = 6;
        for(i=0;i<len;i++)
                usart1_txBuf[BUFF_ptr++]=((HMI_SEND_BUF[i+PLC_return_data_start_addr] >>8)&0xff);
                usart1_txBuf[BUFF_ptr++]=(HMI_SEND_BUF[i+PLC_return_data_start_addr] &0xff);
        usart1_txBuf[2]=BUFF_ptr-1;
        CRC_tmp =  USART_Calc_CRC16(usart1_txBuf+3,BUFF_ptr-3);
        usart1_txBuf[BUFF_ptr++]=(uint8_t)(CRC_tmp&0xff);
        usart1_txBuf[BUFF_ptr++]=(uint8_t)((CRC_tmp>>8)&0xff);
        HAL_UART_Transmit(&huart1, usart1_txBuf, BUFF_ptr, 10);//′®¿ú·¢Ëí
void WRITE_HMI(uint16_t addr,uint8_t data1,uint8_t data2,uint8_t data3,uint8_t data4,uint8_t len)//êy¾YD′èë′¥ÃtÆá±äῼÄ′æÆ÷
        uint16_t CRC_tmp;
                usart1_txBuf[4]=(uint8_t)((addr>>8)&0xff);
                usart1_txBuf[5]=(uint8_t)(addr&0xff);
                usart1_txBuf[6]=data1;
                usart1_txBuf[7]=data2;
                usart1_txBuf[8]=data3;
                usart1_txBuf[9]=data4;
                CRC_tmp =  USART_Calc_CRC16(usart1_txBuf+3,7);
                usart1_txBuf[10]=(uint8_t)(CRC_tmp&0xff);
                usart1_txBuf[11]=(uint8_t)((CRC_tmp>>8)&0xff);
                HAL_UART_Transmit(&huart1, usart1_txBuf, 12 , 20);
void READ_HMI(uint16_t addr,uint8_t num)//¶á′¥ÃtÆá¼Ä′æÆ÷êy¾Y
        uint16_t CRC_tmp;
                usart1_txBuf[2]=0x04;
                usart1_txBuf[3]=0x83;
                usart1_txBuf[6]=num;
    CRC_tmp =  USART_Calc_CRC16(usart1_txBuf+3,4);
                usart1_txBuf[7]=(uint8_t)(CRC_tmp&0xff);
                usart1_txBuf[8]=(uint8_t)((CRC_tmp>>8)&0xff);
                HAL_UART_Transmit(&huart1, usart1_txBuf, 9 , 20);
void CLOSE_OPEN_IO(uint8_t hmi_key_value)  //¿a1ØLED
        uint8_t i;
        if(usart1_rxBuf[7] == 0x00&&usart1_rxBuf[8] == hmi_key_value)//LED1
                if(LED_FLAG[hmi_key_value-1] == 0)
                  if(hmi_key_value == 0x01)
                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_RESET);//¿aLED1
                        if(hmi_key_value == 0x02)
                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_RESET); //¿aLED2
                        if(hmi_key_value == 0x03)
                                HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_RESET); //¿aLED3
                        if(hmi_key_value == 0x04)
                                HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_RESET); //¿aLED4
                else if(LED_FLAG[hmi_key_value-1] == 1)
                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_SET);//1ØLED1
                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_SET);//1ØLED2
                                HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_SET);//1ØLED3
                                HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_SET);//1ØLED4
                        LED_FLAG[hmi_key_value-1] = 0;
                for(i=0;i<9;i++)
                        usart1_rxBuf[i] = 0xff;
                for(i=0;i<4;i++)
                        HMI_SEND_BUF[i] = LED_FLAG[i];
                PLC_Data_Wr2HMI(0X1000,0,5);//·¢ËíLED×′ì¬μ½′¥ÃtÆᣬ¸Ä±äLEDÏÔê¾í¼±ê£»
                delay_ms(50);
        uint8_t i;
                if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_11)==GPIO_PIN_RESET)//KEY1,ÆáÄ»¿a1Ø
                        delay_ms(150);//襶¶¶ˉ
                                if(HMI_FLAG[0] == 0)
                                        WRITE_HMI(0X82,0x00,0x00,0,0,1);//1ØÆáÄ»
                                        HMI_FLAG[0] = 1;
                                }else if(HMI_FLAG[0] == 1)
                                        WRITE_HMI(0X82,0X64,0x00,0,0,1);//¿aÆáÄ»
                                        HMI_FLAG[0] = 0;
                        for(i=0;i<50;i++)
                        usart1_counter = 0;
                if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_12)==GPIO_PIN_RESET)//KEY2£¬Î¶è+
                                TEMP += 1;
                        for(i=0;i<50;i++)
                        usart1_counter = 0;
                if(HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_0)==GPIO_PIN_RESET)//KEY3£¬Î¶è-
                                TEMP -= 1;
                        for(i=0;i<50;i++)
                        usart1_counter = 0;
//                        for(i=0;i<50;i++)
//                                usart1_rxBuf[i] = 0x00;
//                        usart1_counter = 0;
ID:1 发表于 2020-10-28 15:51 | 显示全部楼层
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
