基于单片机的全球定位系统(仅供参考)
电路原理图如下:
- unsigned char data data_item=0
- unsigned int rece_num=0
- *函数名称:void receive()interrupt 4
- *函数功能:时间提取
- *入口函数:无
- *出口函数:无
- void receive()interrupt 4 //串行中断
- unsigned char temp;
- RI=0;
- temp=SBUF;
- rece_num++;
- switch (data_item)
- case 0: if(temp==$)
- data_item++;
- break;
- case 1: if(temp=='G')
- data_item++;
- else
- data_item=0;
- break;
- case 2: if(temp=='P')
- data_item++;
- else
- data_item=0;
- break;
- case 3: if(temp=='R')
- data_item++;
- else
- data_item=0;
- break;
- case 4: if(temp=='M')
- data_item++;
- else
- data_item=0;
- break;
- case 5: if(temp=='C')
- data_item++;
- else
- data_item=0;
- break;
- case 6: if(temp==',')
- data_item++;
- g_Ptr=0;
- g_Class=0;
- g_DataVari=1;
- else
- data_item=0;
- break;
- case 7: if(temp==',')
- g_Ptr=0;
- g_Class++;
- break;
- if(temp=='
- data_item=1;
- break;
- switch(g_Class)
- case 0: //提取时间数据
- if(g_Ptr<6)
- g_DisTime[g_Ptr++]=temp;
- break;
- default:
- break;
基于单片机的全球定位系统.zip
(5.75 KB, 下载次数: 9)
