使用的原工程是野火资料提供的,在此基础上 我将FIFO中发往LCD的RGB565数据通过usart串口输送到上位机,再利用山外调试助手显示出来。
单片机源程序如下:- #include "stm32f10x.h"
- #include "./ov7725/bsp_ov7725.h"
- #include "./lcd/bsp_ili9341_lcd.h"
- #include "./led/bsp_led.h"
- #include "./usart/bsp_usart.h"
- #include "./key/bsp_key.h"
- #include "./systick/bsp_SysTick.h"
- extern uint8_t Ov7725_vsync;
- unsigned int Task_Delay[NumOfTask];
- extern OV7725_MODE_PARAM cam_mode;
- * @brief 主函数
- * @param 无
- * @retval 无
- int main(void)
- float frame_count = 0;
- uint8_t retry = 0;
- /* 液晶初始化 */
- ILI9341_Init();
- ILI9341_GramScan ( 3 );
- LCD_SetFont(&Font8x16);
- LCD_SetColors(RED,BLACK);
- ILI9341_Clear(0,0,LCD_X_LENGTH,LCD_Y_LENGTH); /* 清屏,显示全黑 */
- /********显示字符串示例*******/
- ILI9341_DispStringLine_EN(LINE(0),"BH OV7725 Test Demo");
- USART_Config();
- LED_GPIO_Config();
- Key_GPIO_Config();
- SysTick_Init();
- // printf("\r\n ** OV7725摄像头实时液晶显示例程** \r\n");
- /* ov7725 gpio 初始化 */
- OV7725_GPIO_Config();
- LED_BLUE;
- /* ov7725 寄存器默认配置初始化 */
- while(OV7725_Init() != SUCCESS)
- retry++;
- if(retry>5)
- printf("\r\n没有检测到OV7725摄像头\r\n");
- ILI9341_DispStringLine_EN(LINE(2),"No OV7725 module detected!");
- while(1);
- /*根据摄像头参数组配置模式*/
- OV7725_Special_Effect(cam_mode.effect);
- /*光照模式*/
- OV7725_Light_Mode(cam_mode.light_mode);
- /*饱和度*/
- OV7725_Color_Saturation(cam_mode.saturation);
- /*光照度*/
- OV7725_Brightness(cam_mode.brightness);
- /*对比度*/
- OV7725_Contrast(cam_mode.contrast);
- /*特殊效果*/
- /*设置图像采样及模式大小*/
- OV7725_Window_Set(cam_mode.cam_sx,
- cam_mode.cam_sy,
- cam_mode.cam_width,
- cam_mode.cam_height,
- cam_mode.QVGA_VGA);
- /* 设置液晶扫描模式 */
- // ILI9341_GramScan( cam_mode.lcd_scan );
- // ILI9341_DispStringLine_EN(LINE(2),"OV7725 initialize success!");
- // printf("\r\nOV7725摄像头初始化完成\r\n");
- Ov7725_vsync = 0;
- while(1){
- /*接收到新图像进行显示*/
- if( Ov7725_vsync == 2 )
- USART_SendBits(DEBUG_USARTx,0x01);
- USART_SendBits(DEBUG_USARTx,0xFE);
- frame_count++;
- FIFO_PREPARE; /*FIFO准备*/
- ImagDisp(cam_mode.lcd_sx,
- cam_mode.lcd_sy,
- cam_mode.cam_height); /*采集并显示*/
- Ov7725_vsync = 0;
- LED1_TOGGLE;
- /*检测按键*/
- if( Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_PIN) == KEY_ON )
- /*LED反转*/
- LED2_TOGGLE;
- /*检测按键*/
- if( Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_PIN) == KEY_ON )
- /*LED反转*/
- LED3_TOGGLE;
- /*动态配置摄像头的模式,
- 有需要可以添加使用串口、用户界面下拉选择框等方式修改这些变量,
- 达到程序运行时更改摄像头模式的目的*/
- cam_mode.QVGA_VGA = 0, //QVGA模式
- cam_mode.cam_sx = 0,
- cam_mode.cam_sy = 0,
- cam_mode.cam_width = 320,
- cam_mode.cam_height = 240,
- cam_mode.lcd_sx = 0,
- cam_mode.lcd_sy = 0,
- cam_mode.lcd_scan = 3, //LCD扫描模式,本横屏配置可用1、3、5、7模式
- //以下可根据自己的需要调整,参数范围见结构体类型定义
- cam_mode.light_mode = 0,//自动光照模式
- cam_mode.saturation = 0,
- cam_mode.brightness = 0,
- cam_mode.contrast = 0,
- cam_mode.effect = 1, //黑白模式
- /*根据摄像头参数写入配置*/
- /*光照模式*/
- /*饱和度*/
- /*光照度*/
- /*对比度*/
- /*特殊效果*/
- /*设置图像采样及模式大小*/
- cam_mode.cam_sy,
- /* 设置液晶扫描模式 */
- ILI9341_GramScan( cam_mode.lcd_scan );
- /*每隔一段时间计算一次帧率*/
- if(Task_Delay[0] == 0)
- // printf("\r\nframe_ate = %.2f fps\r\n",frame_count/10);
- frame_count = 0;
- Task_Delay[0] = 10000;
- /*********************************************END OF FILE**********************/
提供源码参考:
液晶实时显示.7z
(762.76 KB, 下载次数: 90)
