程序代码分为12864.c文件、12864.h头文件、main.c文件,3个文件程序代码如下
(1)12864.c文件程序代码
#include"lcd12864.h"
#include"reg52.h"
sbit CS=P1^0; //RS(CS)数据/命令选择端(H/L)(串片选)
sbit SID=P1^1; //R/W(SID)读/写命令选择端(H/L)(串数据口)
sbit SCLK=P1^2; //E(SLCK)使能信号(串同步时钟信号端)
/* 延时函数 */
void delayms(unsigned int xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
/* 发送一个字节 */
void lcd_sent_beyt(unsigned char date)
uchar k=0;
for(k=0;k<8;k++)
if((date<<k)&0x80)
SID=1;
SID=0;
SCLK=0;
SCLK=1;
delayms(2);
/* 写数据 */
void lcd_write_data(unsigned char date)
CS=1;
lcd_sent_beyt(0xfa);
lcd_sent_beyt(date&0xf0);
lcd_sent_beyt((date<<4)&0xf0);
delayms(1);
CS=0;
/* 写命令 */
void lcd_write_cmd(unsigned char date)
CS=1;
lcd_sent_beyt(0xf8);
delayms(1);
CS=0;
/* 坐标函数 */
void lcd_pos(unsigned char X,unsigned Y)
uchar pos;
if(X==0)
{X=0x80;}
else if(X==1)
{X=0x90;}
else if(X==2)
{X=0x88;}
else if(X==3)
{X=0x98;}
pos=X+Y;
lcd_write_cmd(pos);
/* 12864液晶初始化 */
void lcd_init()
lcd_write_cmd(0x30);
delayms(1);
lcd_write_cmd(0x0c);
delayms(1);
lcd_write_cmd(0x01);
delayms(1);
/* 中英文字符显示函数 */
void writestring(unsigned char X,unsigned Y,unsigned char *p)
lcd_pos(X,Y);
while(*p!='\0')
lcd_write_data(*p);
p++;
(2)lcd12864.h头文件代码如下,要完全参照模块化编程所需格式书写
#ifndef LCD12864_H
#define LCD12864_H
extern void delayms(unsigned int xms);
extern void lcd_write_cmd(unsigned char date);
extern void lcd_write_data(unsigned char date);
extern void lcd_sent_beyt(unsigned char date);
extern void lcd_pos(unsigned char X,unsigned Y);
extern void lcd_init();
extern void writestring(unsigned char X,unsigned Y,unsigned char *p);
#endif
(3)main.c文件代码
#include"reg52.h"
void lcd_init();
void testring(unsigned char *p);
char keyscan(); //定义独立按键函数
sbit key1=P2^0; //声明单片机口P3口的第5位
sbit key2=P2^1; //声明单片机口P3口的第4位
sbit key3=P2^2; //声明单片机口P3口的第3位
sbit key4=P2^3; //声明单片机口P3口的第2位
uchar a,key,b;
/* 主函数,按键控制显示 */
lcd_init();
a=keyscan();
if(a==1)
writestring(0,0,"202011205555");
a=keyscan();
if(a==2)
writestring(1,0,"51电子黑论坛");
a=keyscan();
if(a==3)
writestring(2,0,"12846液晶显示");
a=keyscan();
if(a==4)
writestring(3,0,"串行通信");
/* 独立按键控制 */
char keyscan() //定义独立按键函数,设计有返回值的函数更加方便,
{ //注意有返回值函数的类型为返回值的类型
if(key1==0) //当key1按下时
{ //软件防抖动
delayms(10);
if(key1==0)
key=1;
while(!key1); //等待按键释放/***若按键没有释放则key1始终为0,那么!key1始终为1。
if(key2==0) //当key2按下时
delayms(10); //软件防抖动
if(key2==0)
key=2;
while(!key2); //等待按键释放/***若按键没有释放则key2始终为0,那么!key2始终为1。
if(key3==0) //当key3按下时
if(key3==0)
key=3;
while(!key3); //等待按键释放/***若按键没有释放则key3始终为0,那么!key3始终为1。
if(key4==0) //当key3按下时
if(key4==0)
key=4;
while(!key4); //等待按键释放/***若按键没有释放则key3始终为0,那么!key3始终为1。
return key;
