51单片机蜂鸣器演奏《学猫叫》
- #include <REGX52.H>
- #define RldTmr(fr) 65536 - (11059200 /12) / (fr << 1)
- #define FuDian(n) (n << 1) / 3 //附点n分音符的换算
- typedef unsigned char UCHAR;
- typedef unsigned int UINT;
- typedef unsigned long ULONG;
- sbit BUZZ = P2^5;
- UINT code noteFreq[] = { //中音 1-7 和高音 1-7对应的频率列表
- 523, 587, 659, 698, 784, 880, 988,
- 1047, 1175, 1319, 1397, 1568, 1760, 1976 ,2,494,
- UINT code tmrRld[] = { //中音 1-7 和高音 1-7对应的定时器重载值
- RldTmr(523), RldTmr(587), RldTmr(659), RldTmr(698), RldTmr(784), RldTmr(880), RldTmr(988),
- RldTmr(1047), RldTmr(1175), RldTmr(1319), RldTmr(1397), RldTmr(1568), RldTmr(1760), RldTmr(1976),
- UCHAR code musicNote[] = { //音名
- 15,15,15,8,9,
- 10,5,8,10,10,15,9,8,
- 9,12,12,12,12,15,8,7,
- 8,8,8,8,8,15,7,8,
- 7,8,7,6,5,15,5,5,
- 6,6,6,6,6,15,5,3,
- 5,3,5,9,8,15,5,
- 10,10,10,11,12,8,8,9,10,
- // 10,15,
- // 0,5,5,5,5,5,
- // 6,5,3,5,15,16,1,1,
- // 3,3,3,4,3,1,1,2,
- // 3,0,3,2,1,
- // 1,1,1,0,1,1,1,
- UCHAR code noteDuration[] = { //音名对应的时值,4表示4分音符,8表示8分音符,16表示16分音符
- 4,4,4,8,8,
- 8,8,8,8,8,8,8,8,
- 8,8,8,8,8,8,8,8,
- 8,8,8,8,8,8,8,8,
- 8,8,8,8,8,8,8,8,
- 8,8,8,8,8,8,8,8,
- 8,8,8,8,4,8,8,
- 8,8,8,8,8,8,16,32,32,
- // FuDian(4),4,
- // 4,8,8,4,8,8,
- // 8,8,8,8,8,8,8,8,
- // 4,16,32,32,8,8,8,8,
- // 2,8,8,8,8,
- // 8,4,8,8,8,8,8,
- bit enable = 1, tmrFlg = 0;
- UCHAR T0RH = 0XFF, T0RL = 0X00;
- void Delay(UINT n);
- void PlayMusic(UCHAR speed); //固定标准为4分音符的速度:例如speed = 108 表示一分钟扫过108个4分音符
- void main() {
- EA = 1;
- TMOD = 0X01;
- TH0 = T0RH;
- TL0 = T0RL;
- ET0 = 1;
- TR0 = 1;
- while (1) {
- PlayMusic(55);
- Delay(40000u);
- void Delay(UINT n) {
- UINT i;
- for (i = 0; i < n; i++) ;
- void PlayMusic(UCHAR speed) {
- UCHAR i;
- UCHAR idx;
- UINT cnt = 0;
- UINT durationCnt = 0; //当前音符的时值对应的定时器计数
- UINT soundCnt = 0; //当前音符的发声时值对应的计数值
- for (i = 0; i < sizeof (musicNote); ) {
- while (!tmrFlg) ;
- tmrFlg = 0;
- if (cnt == 0) {
- idx = musicNote[i] - 1;
- T0RH = tmrRld[idx] >> 8;
- T0RL = tmrRld[idx];
- durationCnt = (ULONG)240 * (ULONG)noteFreq[idx] / ((ULONG)noteDuration[i] * (ULONG)speed);
- soundCnt = durationCnt - (durationCnt >> 2); //当前音符时值的前3/4发声,后1/4静音
- enable = 1;
- cnt++;
- else {
- if (cnt == durationCnt) {
- cnt = 0;
- i++;
- else {
- cnt++;
- if (cnt == soundCnt) {
- enable = 0;
- void InterruptTmr0() interrupt 1 {
- TH0 = T0RH;
- TL0 = T0RL;
- tmrFlg = 1;
- if (enable)
- BUZZ = ~BUZZ;
- else
- BUZZ = 1;
复制代码 |
