查看: 7221|回复: 2
单片机+LCD1602显示℃ 这种自定义符号
ID:390416 发表于 2020-12-29 12:29 | 显示全部楼层 |阅读模式
  1. #include "all.h"
  2. u8 xdata LCD1602_Write_Buffer1[16];
  3. u8 xdata LCD1602_Write_Buffer2[16];
  4. u8 code LCD1602_5x8[8]={0x08,0x00,0x07,0x08,0x08,0x08,0x08,0x07};
  5. u8 xdata LCD1602_Write_Cursor_Add;
  6. void LCD1602_Delay(u8 len)
  7. {
  8.         u8 idata i;
  9.         while(len--)
  10.         {
  11.                 i=15;
  12.                 while(i--);
  13.         }
  14. }
  15. void LCD1602_Write_Add(u8 Add)                //写地址命令
  16. {
  17.         LCD1602_RS=0;
  18.         LCD1602_E=0;
  19.         LCD1602_Delay(10);
  20.         LCD1602_E=1;
  21.         HC595_Write_Buffer[0]=Add;
  22.         HC595_Write_Buffer[1]=0;
  23.         HC595_Write_Data_Drive();
  24.         LCD1602_E=0;
  25. }
  26. void LCD1602_Write_Dat(u8 Dat)                //写内容
  27. {
  28.         LCD1602_RS=1;
  29.         LCD1602_E=0;
  30.         LCD1602_Delay(10);
  31.         LCD1602_E=1;
  32.         HC595_Write_Buffer[0]=Dat;
  33.         HC595_Write_Buffer[1]=0;
  34.         HC595_Write_Data_Drive();
  35.         LCD1602_E=0;
  36. }
  37. void LCD1602_Init()
  38. {
  39.         u8 i;
  40.         P4M0&=0x9f;
  41.         P4M1&=0x9f;//P4.6  P4.5 准双向口模式
  42.         LCD1602_Write_Add(0x38);
  43.         LCD1602_Delay(250);
  44.         LCD1602_Write_Add(0x01);
  45.         LCD1602_Delay(250);
  46.         LCD1602_Write_Add(0x02);
  47.         LCD1602_Delay(250);
  48.         LCD1602_Write_Add(0x06);
  49.         LCD1602_Delay(250);
  50.         LCD1602_Write_Add(0x0C);
  51.         LCD1602_Delay(250);
  52.         LCD1602_Write_Add(0x14);
  53.         LCD1602_Delay(250);
  54.         LCD1602_Write_Add(0x40);//自定义存储空间起始地址
  55.         for(i=0;i<8;i++)
  56.         {
  57.                 LCD1602_Write_Dat(LCD1602_5x8[i]);
  58.         }
  59. }
  60. void LCD1602_Display_Ser()
  61. {
  62.         u8 i;
  63.         LCD1602_Write_Add(0x80);
  64.         for(i=0;i<16;i++)
  65.         {
  66.                 LCD1602_Write_Dat(LCD1602_Write_Buffer1[i]);
  67.         }
  68.         LCD1602_Write_Add(0xC0);
  69.         for(i=0;i<16;i++)
  70.         {
  71.                 LCD1602_Write_Dat(LCD1602_Write_Buffer2[i]);
  72.         }
  73.         switch(LCD1602_Write_Cursor_Add)
  74.         {
  75.                 case 0:LCD1602_Write_Add(0x0C);break;//不显示也不闪烁光标
  76.                 case 1:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCa);break;
  77.                 case 2:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCd);break;
  78.                 case 3:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC7);break;
  79.                 case 4:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC4);break;
  80.                 case 5:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC1);break;
  81.                 case 6:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCf);break;
  82.                 case 7:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x89);break;
  83.                 case 8:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x86);break;
  84.                 case 9:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x83);break;
  85.         }
  86. }
一、以上代码,主函数大循环前面初始化P4IO口为准双向口
二、主函数大循环前面需要初始化LCD1602_Init();
三、我们是使用595转换给LCD的D0~D7。你们可以直接用P2口赋值给LCD。
四、主函数每500ms 调用LCD1602_Display_Ser()函数。实现数据每半秒刷新一次即可。省掉读忙的过程。
五、两个LCD1602_Write_Buffer[];数组,分别是上下两行的显存。其他地方有需要,就往里面丢ASCII值就可以了。比如0x30+5.液晶显示数字5
六、以上代码由《人人学会单片机》视频教程原创书写。其他地方引用请注明出处!
15 03 18 02 ASCII与GB2312汉字码表.zip (6.89 MB, 下载次数: 14)
ID:102963 发表于 2020-12-29 22:29 | 显示全部楼层
摄氏度符号可以拆成2部分,一个是圈,一个是C。圈就是写数据0xdf,C就是写数据C,这样就能显示出来了。
ID:390416 发表于 2020-12-30 11:34 | 显示全部楼层
这样拆分 肯定很丑啊 ,再说了 也不一定有空间多显示一个字符。没必要为了一个字符。去执行移屏操作。那样很不直观了。
