倒计时5秒的六路抢答器
#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
uchar key,j,k,temp,daojishi=5,wei;
bit begin,end,clear,fangui;
uchar a0,b0=16;c0=16;d0=16;e0=16;f0=5;
unsigned int pp;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
void delay(unsigned char i)
for(j=i;j>0;j--)
for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
dula=0;
P0=table[a];
dula=1;
dula=0;
wela=0;
P0=0xfe;
wela=1;
wela=0;
delay(5);
P0=table[b];
dula=1;
dula=0;
P0=0xfd;
wela=1;
wela=0;
delay(5);
P0=table[c];
dula=1;
dula=0;
P0=0xfb;
wela=1;
wela=0;
delay(5);
P0=table[d];
dula=1;
dula=0;
P0=0xf7;
wela=1;
wela=0;
delay(5);
P0=table[e];
dula=1;
dula=0;
P0=0xef;
wela=1;
wela=0;
delay(5);
P0=table[f];
dula=1;
dula=0;
P0=0xdf;
wela=1;
wela=0;
delay(5);
void keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:
key=1;
wei++;
break;
case 0xde:
key=2;
wei++;
break;
case 0xbe:
key=3;
wei++;
break;
case 0x7e:
key=4;
wei++;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:
key=5;
wei++;
break;
case 0xdd:
key=6;
wei++;
break;
case 0xbd:
clear=1;
//key=7;
break;
case 0x7d:
begin=1;
//key=8;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
TMOD=0x01;
TH0=(65536-46080)/256;// óéóú¾§ÕñÎa11.0592,1êËù¼Ç′Îêyó|Îa46080£¬¼Æê±Æ÷ÿ¸ô50000΢Ãë·¢Æeò»′ÎÖD¶Ï¡£
TL0=(65536-46080)%256;//46080μÄà′àú£¬Îa50000*11.0592/12
ET0=1;
EA=1;
keyscan();
if(begin)
if(!end)
TR0=1;
//if(!daojishi) daojishi=5;
//begin=0;
//daojishi=5;
if(pp==20)
pp=0;
daojishi--;
f0=daojishi;
if(key!=0)
a0=key;
// a1=a0;
//if(a0!=0) end=1;
if(!daojishi|a0)
end=1;
TR0=0;
//daojishi=5;
// begin=0;
pp=0;
if(key!=0)
switch(wei)
case 1: a0=key;break;
case 2: b0=key;break;
case 3: c0=key;break;
case 4: d0=key;break;
case 5: e0=key;break;
//if(!fangui)
fangui=1;
beep=0;
if(clear)
a0=0;key=0;begin=0;end=0;fangui=0;beep=1;daojishi=5;f0=5;clear=0;
b0=16;c0=16;d0=16;e0=16;wei=0; P1=0xff;
display(a0,b0,c0,d0,e0,f0);
if(fangui)
beep=0;
P1=0x00;;
void time0() interrupt 1
{ TH0=(65536-46080)/256;
pp++;
