单片机源程序如下:- #include "adis16203.h"
- #include "halmain.h"
- #include "stm32f4xx_hal_spi.h"
- #include "stm32f4xx_hal_gpio.h"
- extern SPI_HandleTypeDef hspi2;
- ADIS16203_DATA_Typedef ADIS16203_DATA; //定义ADIS16203数据结构体
- //bool write;
- //SPI2口初始化
- //这个spi初始化可以丢其他地方
- //hspi2在halmian.h有声明
- void SPI2_Init(void)
- hspi2.Instance = SPI2; //SPI2
- hspi2.Init.Mode = SPI_MODE_MASTER; //设置SPI工作模式,设置为主模式
- hspi2.Init.Direction = SPI_DIRECTION_2LINES; //设置SPI单向或者双向的数据模式:SPI设置为双线模式
- hspi2.Init.DataSize = SPI_DATASIZE_16BIT; //设置SPI的数据大小:SPI发送接收16位帧结构
- hspi2.Init.CLKPolarity = SPI_POLARITY_HIGH; //串行同步时钟的空闲状态为高电平
- hspi2.Init.CLKPhase = SPI_PHASE_2EDGE; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
- hspi2.Init.NSS = SPI_NSS_SOFT; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
- hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64; //定义波特率预分频的值:波特率预分频值为64
- hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
- hspi2.Init.TIMode = SPI_TIMODE_DISABLE; //关闭TI模式
- hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; //关闭硬件CRC校验
- hspi2.Init.CRCPolynomial = 7; //CRC值计算的多项式
- // HAL_SPI_Init(&hspi2); //初始化
- if (HAL_SPI_Init(&hspi2) != HAL_OK)
- Error_Handler();
- __HAL_SPI_ENABLE(&hspi2); //使能SPI2
- /*SPI2底层驱动,时钟使能,引脚配置
- void MY_SPI_MspInit(SPI_HandleTypeDef *hspi)
- GPIO_InitTypeDef GPIO_Initure;
- __HAL_RCC_GPIOB_CLK_ENABLE(); //使能GPIOB时钟
- __HAL_RCC_GPIOC_CLK_ENABLE(); //使能GPIOB时钟
- __HAL_RCC_SPI2_CLK_ENABLE(); //使能SPI2时钟
- //PC3,PC2,PB10
- GPIO_Initure.Pin = GPIO_PIN_2 | GPIO_PIN_3;
- GPIO_Initure.Mode = GPIO_MODE_AF_PP; //复用推挽输出
- GPIO_Initure.Pull = GPIO_PULLUP; //上拉
- GPIO_Initure.Speed = GPIO_SPEED_FAST; //快速
- GPIO_Initure.Alternate = GPIO_AF5_SPI2; //复用为SPI2
- HAL_GPIO_Init(GPIOC, &GPIO_Initure);
- GPIO_Initure.Pin = GPIO_PIN_10;
- HAL_GPIO_Init(GPIOB, &GPIO_Initure);
- //SPI速度设置函数
- //SPI速度=fAPB1/分频系数
- //@ref SPI_BaudRate_Prescaler:SPI_BAUDRATEPRESCALER_2~SPI_BAUDRATEPRESCALER_2 256
- //fAPB1时钟一般为42Mhz:
- void SPI2_SetSpeed(uint8_t SPI_BaudRatePrescaler)
- assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler)); //判断有效性
- __HAL_SPI_DISABLE(&hspi2); //关闭SPI
- hspi2.Instance->CR1 &= 0XFFC7; //位3-5清零,用来设置波特率
- hspi2.Instance->CR1 |= SPI_BaudRatePrescaler; //设置SPI速度
- void ADIS16203_IO_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- __HAL_RCC_GPIOA_CLK_ENABLE(); //使能GPIOA时钟
- __HAL_RCC_GPIOC_CLK_ENABLE(); //使能GPIOA时钟,复位引脚
- GPIO_InitStructure.Pin = SPI2_NSS_PIN; //定义spi2_cs片选引脚
- GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStructure.Pull = GPIO_PULLUP;
- GPIO_InitStructure.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(SPI2_NSS_IOPORT, &GPIO_InitStructure);
- //初始为高电平,模块为低电平有效,所以置高则不会被选取
- HAL_GPIO_WritePin(SPI2_NSS_IOPORT, SPI2_NSS_PIN, GPIO_PIN_SET);
- GPIO_InitStructure.Pin = ADIS16203_RST_PIN; //定义模块复位引脚
- HAL_GPIO_Init(ADIS16203_RST_IOPORT, &GPIO_InitStructure);
- //模块为低电平复位,先置高
- HAL_GPIO_WritePin(ADIS16203_RST_IOPORT, ADIS16203_RST_PIN, GPIO_PIN_SET);
- //官方库自己已经定义好了,在f4xx_hal_msp.c中关于msio,mosi,sck的引脚配置。关于中断修改优先级即可
- HAL_SPI_MspInit(hspi2);
- //模块初始化
- void ADIS16203_Init(void)
- SPI2_Init(); //SPI2初始化
- ADIS16203_IO_Init() ; //IO初始化
- //模块复位函数
- void ADIS16203Reset(void)
- HAL_GPIO_WritePin(ADIS16203_RST_IOPORT, ADIS16203_RST_PIN, GPIO_PIN_RESET);
- DelayMs(1);
- DelayMs(6);
- //TxData:要写入字节
- //返回值:读出的字节
- //一次传输量为16bit,所以只传输一次
- uint16_t SPI2_ReadWriteByte(uint8_t COM, bool write)
- uint16_t TxData, Rxdata;
- if (write == true)
- TxData = (COM << 8) + (1 << 15);
- else
- TxData = (COM << 8) + 0;
- HAL_SPI_TransmitReceive(&hspi2, (uint8_t *)(&TxData), (uint8_t *)(&Rxdata), 1, 1000);
- return Rxdata;
- void ADIS16203_CS_LOW(void) //片选信号拉低,片选有效
- HAL_GPIO_WritePin(SPI2_NSS_IOPORT, SPI2_NSS_PIN, GPIO_PIN_RESET);
- void ADIS16203_CS_HIGH(void) //片选信号拉高,片选无效
- //取读模块数据(无返回值类型)
- void READ_ADIS16203_DATA(uint8_t COM, ADIS16203_DATA_Typedef *ADIS_DATA, bool wr)
- ADIS16203_CS_LOW();
- SPI2_ReadWriteByte(COM, wr);
- ADIS16203_CS_HIGH();
- delay_us(10);
- switch (COM)
- case SUPPLY_OUT:
- ADIS_DATA->SUPPLY_OUT_DATA = ((SPI2_ReadWriteByte(COM, wr) & 0xfff) * 1.22);
- break;
- case AUX_ADC:
- ADIS_DATA->AUX_ADC_DATA = ((SPI2_ReadWriteByte(COM, wr) & 0xfff) * 0.61);
- break;
- case TEMP_OUT:
- ADIS_DATA->TEMP_OUT_DATA = ((SPI2_ReadWriteByte(COM, wr) & 0xfff) * -0.47); //这个要注意下
- break;
- case INCL_OUT:
- ADIS_DATA->INCL_OUT_DATA = ((SPI2_ReadWriteByte(COM, wr) & 0x3fff) * 0.025);
- break;
- case INCL_180_OUT:
- ADIS_DATA->INCL_180_OUT_DATA = ((SPI2_ReadWriteByte(COM, wr) & 0x3fff) * 0.025);
- break;
- default:
- break;
- //取读模块数据(有返回值类型),还得进一步处理
- uint16_t READ_ADIS16203_DATA2(uint8_t COM, bool wr)
- uint16_t ret;
- delay_us(10);
- ret = SPI2_ReadWriteByte(COM, wr);
- return ret;
- uint16_t
全部资料51hei下载地址:
ADIS16203.zip
(3.55 KB, 下载次数: 22)
