stm控制W5100S的程序
- #include "socket.h"
- static uint16 local_port;
- extern uint16 sent_ptr;
- #define __MACRAW__
- @brief This Socket function initialize the channel in perticular mode, and set the port and wait for W5200 done it.
- @return 1 for sucess else 0.
- void setkeepalive(SOCKET s);
- uint8 socket(SOCKET s, uint8 protocol, uint16 port, uint8 flag) // 2017-07-17
- uint8 ret;
- if (
- ((protocol&0x0F) == Sn_MR_TCP) ||
- ((protocol&0x0F) == Sn_MR_UDP) ||
- ((protocol&0x0F) == Sn_MR_IPRAW) ||
- ((protocol&0x0F) == Sn_MR_MACRAW)
- close(s);
- if((protocol&0x0F)==Sn_MR_TCP)
- setkeepalive(s);
- IINCHIP_WRITE(W5100S_Sn_MR(s) ,protocol | flag);
- if (port != 0) {
- IINCHIP_WRITE( W5100S_Sn_PORT0(s) ,(uint8)((port & 0xff00) >> 8));
- IINCHIP_WRITE( W5100S_Sn_PORT1(s) ,(uint8)(port & 0x00ff));
- } else {
- local_port++; // if don't set the source port, set local_port number.
- IINCHIP_WRITE(W5100S_Sn_PORT0(s) ,(uint8)((local_port & 0xff00) >> 8));
- IINCHIP_WRITE(W5100S_Sn_PORT1(s) ,(uint8)(local_port & 0x00ff));
- IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_OPEN); // run sockinit Sn_CR
- /* wait to process the command... */
- while( IINCHIP_READ(W5100S_Sn_CR(s)) )
- ret = 1;
- else
- ret = 0;
- return ret;
- @brief This function close the socket and parameter is "s" which represent the socket number
- void close(SOCKET s)
- IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_CLOSE); //SOCKET关闭
- while( IINCHIP_READ(W5100S_Sn_CR(s) ) )
- /* all clear */
- IINCHIP_WRITE( W5100S_Sn_IR(s) , 0xFF);
- @brief This function established the connection for the channel in passive (server) mode. This function waits for the request from the peer.
- @return 1 for success else 0.
- uint8 listen(SOCKET s) //设置为等待客户端发出请求模式
- uint8 ret;
- if (IINCHIP_READ( W5100S_Sn_SR(s) ) == Sn_SR_INIT) //指示SOCKET打开并处于TCP模式
- IINCHIP_WRITE(W5100S_Sn_CR(s) ,Sn_CR_LISTEN); //设置为等待客户端发出请求模式
- while( IINCHIP_READ(W5100S_Sn_CR(s) ) ) //等待设置完成
- ret = 1;
- else
- ret = 0;
- return ret;
- @brief This function established the connection for the channel in Active (client) mode.
- This function waits for the untill the connection is established.
- uint8 connect(SOCKET s, uint8 * addr, uint16 port)
- uint8 ret; // ret定义为是否连接的标志位,ret=0 连接中断;ret=1连接成功
- if
- ((addr[0] == 0xFF) && (addr[1] == 0xFF) && (addr[2] == 0xFF) && (addr[3] == 0xFF)) ||
- ((addr[0] == 0x00) && (addr[1] == 0x00) && (addr[2] == 0x00) && (addr[3] == 0x00)) ||
- (port == 0x00)
- ret = 0; // 如果IP地址和Port无法获取,则连接中断
- else // 如果目的IP和Port未设置,则进行设置
- ret = 1;
- IINCHIP_WRITE( W5100S_Sn_DIPR0(s), addr[0]);
- IINCHIP_WRITE( W5100S_Sn_DIPR1(s), addr[1]);
- IINCHIP_WRITE( W5100S_Sn_DIPR2(s), addr[2]);
- IINCHIP_WRITE( W5100S_Sn_DIPR3(s), addr[3]);
- IINCHIP_WRITE( W5100S_Sn_DPORT0(s), (uint8)((port & 0xff00) >> 8));
- IINCHIP_WRITE( W5100S_Sn_DPORT1(s), (uint8)(port & 0x00ff));
- IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_CONNECT); // Sn_CR数值设为0x04,并执行TCP连接请求命令
- while ( IINCHIP_READ(W5100S_Sn_CR(s) ) ) ; // MCU读取Sn_CR(s)的数值
- while ( IINCHIP_READ(W5100S_Sn_SR(s)) != Sn_SR_SYNSEND ) // 此时Sn_SR(s)寄存器应该处于SOCK_SYNSENT,下面排除不在该状态的几种情况
- if(IINCHIP_READ(W5100S_Sn_SR(s)) == Sn_SR_ESTABLISHED) // Socket连接已经建立,正常连接
- break;
- if (getSn_IR(s) & Sn_IR_TIMEOUT) // 当ARPto或TCPto超时,异常
- IINCHIP_WRITE(W5100S_Sn_IR(s), (Sn_IR_TIMEOUT)); // 通知MCU该中断,并清中断
- ret = 0; // ret置0,连接中断
- break;
- return ret;
- @brief This function used for disconnect the socket and parameter is "s" which represent the socket number
- void disconnect(SOCKET s)
- IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_DISCON);
- @brief This function used to send the data in TCP mode
- uint16 send(SOCKET s, const uint8 * buf, uint16 len)
- uint8 status=0;
- uint16 ret=0;
- uint16 freesize=0;
- if (len > getSn_TXBUF_SIZE( s)*1024)
- ret = getSn_TXBUF_SIZE( s)*1024;
- else ret = len;
- do
- freesize = getSn_TX_FSR(s);
- status = IINCHIP_READ(W5100S_Sn_SR(s));
- if ((status != Sn_SR_ESTABLISHED) && (status != Sn_SR_CLOSE_WAIT))
- printf("status break\r\n");
- ret = 0;
- break;
- while (freesize < ret);
- send_data_processing(s, (uint8 *)buf, ret);
- …………限于本文篇幅 余下代码请从51黑下载附件…………
复制代码 网络调试助手:http://www.51hei.com/bbs/dpj-201792-1.html
STM32F407通过W5100S进行网络通信.7z
(5.15 MB, 下载次数: 58)
