stm32+3.2寸屏显示音乐频谱!
- #include "stm32f10x.h"
- #include "./lcd/bsp_ili9341_lcd.h"
- #include "./usart/bsp_usart.h"
- #include <stdio.h>
- #include "fft.h"
- #include "timer.h"
- #include "adc.h"
- #include "bsp_led.h"
- #include "bsp_SysTick.h"
- #include "set.h"
- #include "./key/bsp_key.h"
- u16 count;
- u32 voltage_val[256];
- extern float32_t InputData[512];//输入复数数据
- extern float32_t OutputData[256];//输出复数数据
- extern float32_t maxValue;//存储变换后的最大值
- uint16_t point[128]={0};
- uint16_t lcd_w = 0;
- uint16_t color_mode = 0;
- extern u32 time_us;
- * @brief 主函数
- * @param 无
- * @retval 无
- int main ( void )
- int i = 0;
- lcd_w = 2;
- color_mode = 1;
- ILI9341_Init(); //LCD 初始化
- USART_Config();
- SysTick_Init();
- time_us = 0;
- ILI9341_GramScan ( 1 );
- LCD_SetFont(&Font8x16);
- LCD_SetColors(RED,BLACK);
- ILI9341_Clear(0,0,LCD_X_LENGTH,LCD_Y_LENGTH); /* 清屏,显示全黑 */
- LED_GPIO_Config();
- Key_GPIO_Config();
- Adc_Init();
- TIM2_Int_Init(4,359);//200kHz计数频率,40kHz中断频率(采样频率)
- while ( 1 )
- if(count == 256)
- TIM_ITConfig(TIM2,TIM_IT_Update,DISABLE );//关定时器中断
- //LED2_TOGGLE;
- count = 0;
- if(KEY_ON == Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_PIN))
- lcd_w++;
- lcd_w %= 5;
- lcd_w++;
- if(KEY_ON == Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_PIN))
- color_mode++;
- color_mode %= 3;
- for(i=0;i<256;i++)//装载256点复数数据
- InputData[i*2]=(float)voltage_val[i];//实部
- InputData[i*2+1]=0.0;//虚部
- if(DO_FFT())
- for(i=0;i < 300/(lcd_w+1);i++)
- uint32_t temp = (u32)OutputData[i+1]/30;
- if(temp >= point[i])
- if(temp >= 239)
- point[i] = 239;
- else
- point[i] = temp;
- else
- if(point[i] >= lcd_w )
- point[i]-=lcd_w;
- else
- point[i] = 0;
- set_color(temp);
- if(lcd_w != 1)
- m_line(i,temp);
- else
- ILI9341_OpenWindow ( (lcd_w + 1)*i, 0, (lcd_w+1), LCD_Y_LENGTH );
- ILI9341_FillColor ( (lcd_w + 1) * LCD_Y_LENGTH, BLACK );
- m_point(i,point[i]);
- SysTick_Delay_Ms(60);
- TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );//开定时器中断
