查看: 7521|回复: 0
51单片机简易波形发生器Proteus仿真程序,产生方波、正弦波、锯齿波、三角波
1.可实现方波、正弦波、锯齿波、三角波四种波形
2.通过LCD1602显示频率、步进值
3.可用按键调整频率
  1. #include<reg52.h>                                           //包含头文件
  2. #include<intrins.h>
  3. #define uchar unsigned char                           //宏定义
  4. #define uint unsigned int
  5. sbit s1=P3^5;                                                    //定义按键的接口
  6. sbit s2=P3^6;
  7. sbit s3=P3^7;
  8. sbit s4=P3^4;
  9. sbit led0=P3^0;                                                        //定义四个LED,分别表示不同的波形
  10. sbit led1=P3^1;
  11. sbit led2=P3^2;
  12. sbit led3=P3^3;
  13.
  14. sbit lcdrs=P2^7;                                           //液晶控制引脚,还有一个控制脚是RW,因为我们只需要向液晶里写数据系那是就好了,所以,我们直接将RW引脚接地
  15. sbit lcden=P2^6;
  16. char num,boxing,u;                                           //定义全局变量
  17. int pinlv=100,bujin=1,bujin1=1;                   //频率初始值是10Hz,步进值默认是0.1,显示步进值变量
  18. uchar code table[]="0123456789";                //定义显示的数组
  19. uchar code table1[]="Fout=     Wave form:";        //初始化显示字符
  20. unsigned long int m;                                   //定义长整形变量 m
  21. int a,b,h,num1;                                                        //定义全局变量
  22. //自定义字符
  23. uchar code zifu[]={                   //此数组内数据为液晶上显示波形符号的自定义字符
  24.                                                 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
  25.                                                 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00,          //正弦波           0  1
  26.                                                 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
  27.                                                 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00,          //矩形波           2  3
  28.                                                 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
  29.                                                 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,          //三角波           4  5
  30.                                                 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00,            //锯齿波           6
  31. };
  32. uchar code sin[64]={           //此数组内的数据为,da输出对应电压值对应的数字量,0是0V,255是5V
  33. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  34. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  35. };                                          //正弦波取码
  36. uchar code juxing[64]={                //一个周期是采样64个点, 所以数组内是64个数据
  37. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  38. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  39. };                                          //矩形波取码
  40. uchar code sanjiao[64]={
  41. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  42. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  43. };                                                //三角波取码
  44. uchar code juchi[64]={
  45. 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
  46. 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
  47. };                                          //锯齿波取码
  48. void delay(uint xms)         //延时函数
  49. {
  50.         int a,b;
  51.         for(a=xms;a>0;a--)
  52.                 for(b=110;b>0;b--);
  53. }
  54. void write_com(uchar com)                //写命令函数
  55. {
  56.         lcdrs=0;
  57.         P0=com;
  58.         delay(1);
  59.         lcden=1;
  60.         delay(1);
  61.         lcden=0;
  62. }
  63. void write_date(uchar date)                //写数据函数
  64. {
  65.         lcdrs=1;
  66.         P0=date;
  67.         delay(1);
  68.         lcden=1;
  69.         delay(1);
  70.         lcden=0;
  71. }
  72. //自定义字符集
  73. void Lcd_ram()
  74. {
  75.         uint i,j,k=0,temp=0x40;
  76.         for(i=0;i<7;i++)
  77.         {
  78.            for(j=0;j<8;j++)
  79.            {
  80.             write_com(temp+j);
  81.             write_date(zifu[k]);
  82.             k++;
  83.            }
  84.            temp=temp+8;
  85.         }
  86. }
  87. void init_lcd()                                        //初始化函数
  88. {
  89.         uchar i;
  90.         lcden=0;                                        //默认开始状态为关使能端,见时序图
  91.         Lcd_ram();
  92.         write_com(0x0f);
  93.         write_com(0x38);                        //显示模式设置,默认为0x38,不用变。
  94.         write_com(0x01);                        //显示清屏,将上次的内容清除,默认为0x01.
  95.         write_com(0x0c);                        //显示功能设置0x0f为开显示,显示光标,光标闪烁;0x0c为开显示,不显光标,光标不闪
  96.         write_com(0x06);                        //设置光标状态默认0x06,为读一个字符光标加1.
  97.         write_com(0x80);                        //设置初始化数据指针,是在读指令的操作里进行的
  98.         for(i=10;i<20;i++)                           //显示初始化
  99.         {
  100.                 write_date(table1[i]);                   //显示第一行字符
  101.         }
  102.         write_com(0x80+0x40);                           //选择第二行
  103.         for(i=0;i<9;i++)
  104.         {
  105.                 write_date(table1[i]);                   //显示第二行字符
  106.         }
  107.         write_com(0x80+10);                                   //选择第一行第十个位置
  108.         write_date(0);
  109.         write_date(1);
  110.         write_date(0);
  111.         write_date(1);
  112.         write_date(0);
  113.         write_date(1);                                           //显示自定义的波形图案
  114.         write_com(0x80+0x40+0x09);                   //选择第二行第九个位置
  115.         write_date(' ');
  116.         write_date('1');
  117.         write_date('0');
  118.         write_date('.');
  119.         write_date('0');
  120.         write_date('H');
  121.         write_date('z');                                   //显示初始的频率值
  122. }
  123. void initclock()                           //定时器初始化函数
  124. {
  125.         TMOD=0x01;                                   //定时器的工作方式
  126.         TH0=a;
  127.         TL0=b;                                           //定时器赋初值
  128.         EA=1;                                           //打开中断总开关
  129.         ET0=1;                                           //打开定时器允许中断开关
  130.         TR0=1;                                           //打开定时器定时开关
  131. }
全部资料51hei下载地址:
51黑论坛_1、函数发生器.rar (7.53 MB, 下载次数: 119)
参与人数 1黑币 +12 收起 理由
1134549525 + 12 很给力!
收藏收藏4 分享淘帖 顶 踩
