把主频降到几兆试试。一般来说,有读忙操作,是否延时影响不太大,可能是IO配置或初始化指令操作有误。下面是以前写的测试可用的(51,晶振12M,8线),你试下。#include<reg51.h>
#define BF P1_7
#define RS P2_0
#define RW P2_1
#define E P2_2
#define IO P1
sbit P1_7=P1^7;
sbit P2_0=P2^0;
sbit P2_1=P2^1;
sbit P2_2=P2^2;
/*****忙标志*******/
unsigned char busy(void)
unsigned char b=0;
RS=0;RW=1;E=0;
IO=255;
E=1;
if(BF){b=1;}
return(b);
/*****初始化LCD****/
void inital(void)
IO=1; /*1:(0000 0001)清屏,光标回位*/
RS=0;RW=0;E=0;
while(busy()){;}
IO=56; /*2:(0011 1000)8位总线,2行显示,5*7点阵*/
RS=0;RW=0;E=0;
while(busy()){;}
IO=15; /*3:(0000 1111)整体显示开,显示光标,光标闪烁开*/
RS=0;RW=0;E=0;
while(busy()){;}
IO=6; /*4:(0000 0110)光标右移*/
RS=0;RW=0;E=0;
