查看: 2051|回复: 0
51单片机3路DHT11采集程序与Proteus仿真 串口上传
ID:486153 发表于 2021-4-3 17:36 | 显示全部楼层 |阅读模式
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include "Delay.h"
  4. #include <ds18b20mul.h>
  5. #include <uart.h>
  6. sbit beep=P1^7;
  7. sbit key1=P2^3;
  8. sbit key2=P2^4;
  9. sbit key3=P2^5;
  10. sbit key4=P2^6;
  11. int8u temp_date[16]="max:xx min:xx\r\n";
  12. unsigned int temp_1,temp_2,temp_3;
  13. unsigned int temp_max=50;
  14. unsigned int temp_min=30;
  15. unsigned char mode_flag=0;
  16. void delay_us(unsigned int us)
  17. {
  18.         while(us--);
  19. }
  20. void key_scan()
  21. {
  22.         if(key1==0)
  23.         {
  24.                 delay_us(10);
  25.                 if(key1==0)
  26.                 {
  27.                         sendstring("Start set,Change mode!\r\n");
  28.                         mode_flag++;
  29.                         if(mode_flag>3)
  30.                                 mode_flag=1;
  31.                 }
  32.                 while(!key1);
  33.         }
  34.
  35.         if(key2==0)
  36.         {
  37.                 delay_us(10);
  38.                 if(key2==0)
  39.                 {
  40.                         if(mode_flag==1)
  41.                                 temp_max+=2;
  42.                         if(mode_flag==2)
  43.                                 temp_min+=2;
  44.                         sendstring(temp_date);
  45.                 }
  46.                 while(!key2);
  47.         }
  48.
  49.         if(key3==0)
  50.         {
  51.                 delay_us(10);
  52.                 if(key3==0)
  53.                 {
  54.                         if(mode_flag==1)
  55.                                 temp_max-=2;
  56.                         if(mode_flag==2)
  57.                                 temp_min-=2;
  58.                         sendstring(temp_date);
  59.                 }
  60.                 while(!key3);
  61.         }
  62.
  63.         if(key4==0)
  64.         {
  65.                 delay_us(10);
  66.                 if(key4==0)
  67.                 {
  68.                         mode_flag=0;
  69.                         sendstring("Set OK!\r\n");
  70.                 }
  71.                 while(!key4);
  72.         }
  73. }
  74. void main()
  75. {
  76. UARTinit();//串口初始化
  77.         beep=0;
  78. while(1) //空等
  79. {
  80.          if(mode_flag==0)
  81.          {
  82.            Delay_Xms(1000);//每秒上传一次温度
  83.            GetData(1); //读取温度放入dispBuf中,1指P1.0引脚,2指P1.1引脚
  84.            sendstring("*1:");
  85.            sendstring(dispBuf);sendstring("\r\n");//主动上传温度
  86.
  87.            GetData(2); //
  88.            sendstring("*2:");
  89.            sendstring(dispBuf);sendstring("\r\n");//主动上传温度
  90.
  91.            GetData(3); //
  92.            sendstring("*3:");
  93.            sendstring(dispBuf);sendstring("\r\n");//主动上传温度
  94.          }
  95.                 temp_date[4]=temp_max/10+'0';
  96.                 temp_date[5]=temp_max%10+'0';
  97.
  98.                 temp_date[11]=temp_min/10+'0';
  99.                 temp_date[12]=temp_min%10+'0';
  100.
  101.          key_scan();
  102.
  103.          if(temp_1>temp_max||temp_1<temp_min||temp_2>temp_max||temp_2<temp_min||temp_3>temp_max||temp_3<temp_min)
  104.                         beep=1;
  105.                 else
  106.                         beep=0;
  107. }
  108. }
仿真程序51hei提供下载:
多路温度采集上传 (2).zip (108.51 KB, 下载次数: 40)
