RS485仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
- #include <reg51.h>
- #include <absacc.h>
- #define TR 1
- #define uchar unsigned char
- #define uint unsigned int
- //uchar idata buf[10]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09};
- uchar data1,data2;
- uchar pf;
- uchar flag,flag1;
- sbit key1=P1^0;
- sbit key2=P2^0;
- /************延时程序************/
- void delay(uchar k)
- uchar j;
- while((k--)!=0)
- for(j=0;j<125;j++)
- void init(void)
- TMOD=0x20;
- TH1=0xe8;
- TL1=0xe8;
- PCON=0x00; //本次调节发现485通信而言,波特率对传输信息有很
- TR1=1; //重要的作用,因为波特率低的话,不是传输速度慢,
- SCON=0x90; //而是无法传输数据,这是调试时发现的致命错误。
- } //还有在485通信中无论是单机通信,还是多机通信,
- //串行通信的方式必须是-----方式2或者是方式3,不能是方式0或者方式1,这一点特别的重要。
- void send(void)
- key2=1;
- SBUF=0x01;
- while(TI==0)
- TI=0;
- key2=0;
- while(RI==0)
- data1=SBUF;
- RI=0;
- key2=1;
- if(data1!=0x01)
- SBUF=0x0f;
- while(TI==0)
- TI=0;
- else{
- SBUF=0x09;
- while(TI==0)
- TI=0;
- void main(void)
- //delay(500);
- init();
- while(1)
- //keyscan();
- send();
- delay(100);
复制代码- #include <reg51.h>
- uchar dat1,dat2;
- uchar pf;
- uchar flag,flag1;
- sbit key1=P1^0;
- sbit key2=P2^0;
- uchar j;
- while((k--)!=0)
- void init(void)
- TMOD=0x20;
- TH1=0xe8;
- TL1=0xe8;
- PCON=0x00;
- TR1=1;
- SCON=0x90;
- void receive(void)
- key2=0;
- RI=0;
- while(RI==0)
- dat1=SBUF;
- RI=0;
- key2=1;
- if(dat1==0x01)
- SBUF=0x01;
- while(TI==0)
- TI=0;
- key2=0;
- while(RI==0)
- dat2=SBUF;
- RI=0;
- void main(void)
- //delay(500);
- init();
- while(1)
- receive();
- delay(100);
- P1=dat2;
485单数据通信.rar
(36.27 KB, 下载次数: 112)
