ad9833部分资料
- #include "stm32f10x.h"
- #include "systemconfig.h"
- #include "common.h"
- #include "ad9833.h"
- #define LED1 BIT_ADDR(GPIOB_ODR_Addr,0)
- #define LED2 BIT_ADDR(GPIOB_ODR_Addr,1)
- #define KEY BIT_ADDR(GPIOB_IDR_Addr,2)
- #define CLK BIT_ADDR(GPIOB_ODR_Addr,14)
- int main(void)
- u8 i;
- SystemConfiguration(); //系统初始化
- LED1=0; //灭
- LED2=1; //亮
- AD9833_Init_GPIO(); //AD9833 GPIO 初始化
- // AD9833_WaveSeting(8000000.5,0,TRI_WAVE,0 );//1.0005KHz,频率寄存器0,三角波输出 ,初相位0
- /* AD9833_WaveSeting(5000,0,SQU_WAVE,90); //5KHz, 频率寄存器0,方波输出 ,初相位90 */
- /* AD9833_WaveSeting(100000,0,SIN_WAVE,0 );//100KHz, 频率寄存器0,正弦波输出 ,初相位0 */
- AD9833_WaveSeting(1000.1,0,TRI_WAVE,0);
- AD9833_AmpSet(200); //设置幅值,幅值最大 255
- while(1)
- LED1 = !LED1_READ; //LED1 取反
- Delay_ms(300); //延时 300ms
- // Pin assign
- // STM32 AD9833
- // GPIOB_Pin_15 ---> FSYNC
- // GPIOB_Pin_14 ---> SCK
- // GPIOB_Pin_13 ---> DAT
- // GPIOB_Pin_12 ---> CS
- /*端口定义 */
- #define PORT_FSYNC GPIOB
- #define PIN_FSYNC GPIO_Pin_15
- #define PORT_SCK GPIOB
- #define PIN_SCK GPIO_Pin_14
- #define PORT_DAT GPIOB
- #define PIN_DAT GPIO_Pin_13
- #define PORT_CS GPIOB
- #define PIN_CS GPIO_Pin_12 //数字电位器片选
- #define FSYNC_0() GPIO_ResetBits(PORT_FSYNC, PIN_FSYNC)
- #define FSYNC_1() GPIO_SetBits(PORT_FSYNC, PIN_FSYNC)
- #define SCK_0() GPIO_ResetBits(PORT_SCK, PIN_SCK)
- #define SCK_1() GPIO_SetBits(PORT_SCK, PIN_SCK)
- #define DAT_0() GPIO_ResetBits(PORT_DAT, PIN_DAT)
- #define DAT_1() GPIO_SetBits(PORT_DAT, PIN_DAT)
- #define CS_0() GPIO_ResetBits(PORT_DAT, PIN_CS)
- #define CS_1() GPIO_SetBits(PORT_DAT, PIN_CS)
- //初始化AD9833 GPIO
- void AD9833_Init_GPIO()
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = PIN_FSYNC|PIN_SCK|PIN_DAT|PIN_CS;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(PORT_SCK, &GPIO_InitStructure);
- * 函 数 名: AD9833_Delay
- * 功能说明: 时钟延时
- * 形 参: 无
- * 返 回 值: 无
- static void AD9833_Delay(void)
- uint16_t i;
- for (i = 0; i < 1; i++);
- * 函 数 名: AD9833_Write
- * 功能说明: 向SPI总线发送16个bit数据
- * 形 参: TxData : 数据
- * 返 回 值: 无
- void AD9833_Write(unsigned int TxData)
- unsigned char i;
- SCK_1();
- //AD9833_Delay();
- FSYNC_1();
- //AD9833_Delay();
- FSYNC_0();
- //AD9833_Delay();
- for(i = 0; i < 16; i++)
- if (TxData & 0x8000)
- DAT_1();
- else
- DAT_0();
- AD9833_Delay();
- SCK_0();
- AD9833_Delay();
- SCK_1();
- TxData <<= 1;
- FSYNC_1();
- * 函 数 名: AD9833_AmpSet
- * 功能说明: 改变输出信号幅度值
- * 形 参: 1.amp :幅度值 0- 255
- * 返 回 值: 无
- void AD9833_AmpSet(unsigned char amp)
- unsigned char i;
- unsigned int temp;
- CS_0();
- temp =0x1100|amp;
- for(i=0;i<16;i++)
- SCK_0();
- if(temp&0x8000)
- DAT_1();
- else
- DAT_0();
- temp<<=1;
- SCK_1();
- AD9833_Delay();
- CS_1();
- * 函 数 名: AD9833_WaveSeting
- * 形 参: 1.Freq: 频率值, 0.1 hz - 12Mhz
- 2.Freq_SFR: 0 或 1
- 3.WaveMode: TRI_WAVE(三角波),SIN_WAVE(正弦波),SQU_WAVE(方波)
- 4.Phase : 波形的初相位
- * 返 回 值: 无
- void AD9833_WaveSeting(double Freq,unsigned int Freq_SFR,unsigned int WaveMode,unsigned int Phase )
- int frequence_LSB,frequence_MSB,Phs_data;
- double frequence_mid,frequence_DATA;
- long int frequence_hex;
- /*********************************计算频率的16进制值***********************************/
- frequence_mid=268435456/25;//适合25M晶振
- //如果时钟频率不为25MHZ,修改该处的频率值,单位MHz ,AD9833最大支持25MHz
- frequence_DATA=Freq;
- frequence_DATA=frequence_DATA/1000000;
- frequence_DATA=frequence_DATA*frequence_mid;
- frequence_hex=frequence_DATA; //这个frequence_hex的值是32位的一个很大的数字,需要拆分成两个14位进行处理;
- frequence_LSB=frequence_hex; //frequence_hex低16位送给frequence_LSB
- frequence_LSB=frequence_LSB&0x3fff;//去除最高两位,16位数换去掉高位后变成了14位
- frequence_MSB=frequence_hex>>14; //frequence_hex高16位送给frequence_HSB
- frequence_MSB=frequence_MSB&0x3fff;//去除最高两位,16位数换去掉高位后变成了14位
- Phs_data=Phase|0xC000; //相位值
- AD9833_Write(0x0100); //复位AD9833,即RESET位为1
- AD9833_Write(0x2100); //选择数据一次写入,B28位和RESET位为1
- if(Freq_SFR==0) //把数据设置到设置频率寄存器0
- frequence_LSB=frequence_LSB|0x4000;
- frequence_MSB=frequence_MSB|0x4000;
- //使用频率寄存器0输出波形
- AD9833_Write(frequence_LSB); //L14,选择频率寄存器0的低14位数据输入
- AD9833_Write(frequence_MSB); //H14 频率寄存器的高14位数据输入
- AD9833_Write(Phs_data); //设置相位
- //AD9833_Write(0x2000); /**设置FSELECT位为0,芯片进入工作状态,频率寄存器0输出波形**/
- if(Freq_SFR==1) //把数据设置到设置频率寄存器1
- frequence_LSB=frequence_LSB|0x8000;
- frequence_MSB=frequence_MSB|0x8000;
- //使用频率寄存器1输出波形
- AD9833_Write(frequence_LSB); //L14,选择频率寄存器1的低14位输入
- AD9833_Write(frequence_MSB); //H14 频率寄存器1为
- //AD9833_Write(0x2800); /**设置FSELECT位为0,设置FSELECT位为1,即使用频率寄存器1的值,芯片进入工作状态,频率寄存器1输出波形**/
- if(WaveMode==TRI_WAVE) //输出三角波波形
- AD9833_Write(0x2002);
- if(WaveMode==SQU_WAVE) //输出方波波形
- AD9833_Write(0x2028);
- if(WaveMode==SIN_WAVE) //输出正弦波形
- AD9833_Write(0x2000);
AD9833_资料.7z
(4.43 MB, 下载次数: 51)
