51单片机制作的函数信号发生器设计 Proteus仿真
LCD12864显示
- #include <reg52.h>
- #include <math.h>
- #include <intrins.h>
- #include <lcd12864.h>
- #define DAC_OUT P2
- sbit change_wave=P3^2; //改变波形按键
- sbit change_rate=P3^3; //改变频率按键
- uchar mode=0,rate=0,delay_time=0,k,p; //为波形发生模块提供中间变量
- uchar *which_wave,*which_wave2;
- uint rate_num;
- uchar code Sine_wave[64]= //DA输出对应电压值对应的数字量,正弦波
- 128,114,102,90,78,66,55,45,36,28,20,14,9,5,2,1,1,1,
- 3,7,11,17,24,32,41,50,61,72,84,96,108,121,133,146,
- 158,170,182,193,204,213,222,230,237,243,247,251,253,
- 254,254,252,249,245,240,234,226,218,209,199,188,176,
- 167,158,145,135
- uchar code Sawtooth_Wave[64]= //锯齿波
- 255,251,247,243,239,235,231,227,223,219,215,210,206,202,
- 198,194,190,186,182,178,174,170,166,162,158,154,150,146,
- 142,138,134,130,125,121,117,113,109,105,101,97,93,89,85,
- 81,77,73,69,61,57,53,49,45,40,36,32,28,24,20,16,12,8,4,0
- uchar code Square_wave[64]= //方波
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
- 0,0,0,0,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- uchar code Triangular_Wave[64]= //三角波
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,
- 144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,
- 136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- void wave_delay() //波形延时函数
- int a,b;
- for(a=1; a>0; a--)
- for(b=122; b>0; b--);
- void wave_init() //波形发生模块的初始化(外部中断0、1)
- EA=1;
- IT0=1; //下降沿触发
- EX0=1;
- IT1=1;
- EX1=1;
- void disp_wave(uchar *wave) //显示波形函数
- uchar page,i;
- uint date;
- select(1); //选择左屏
- for(i=32; i<64; i++)
- page=7-(wave[i]/4)/8;
- date=7-(wave[i]/4)%8;
- date=pow(2,date);
- setpos(page,i); //选择行列
- lcd_wdat(date);
- select(2); //选择右屏
- for(i=0; i<64; i++)
- date=pow(2,date);
- lcd_wdat(date);
- void main()
- lcd_init();
- clr_screen();
- which_wave=&Sine_wave[0];
- disp_chinese();
- disp_function(chinese_sine);
- disp_rate(400);
- disp_xy();
- disp_wave(which_wave);
- wave_init();
- while(1)
- delay_time=rate; //rate=0时,12mhz下,为400hz的波形。循环一次的时间为0.00025ms
- DAC_OUT=*(which_wave+k);
- k++;
- if(k==64)
- k=0;
- while(delay_time)
- delay_time--;
- void int0() interrupt 0 //波形选择中断服务程序
- EX0=0;
- wave_delay();
- mode++;
- if(mode==4)
- mode=0;
- switch(mode)
- case 0 : //显示正弦波
- which_wave2=&chinese_sine[0];
- break;
- case 1 : //显示三角波
- which_wave=&Triangular_Wave[0];
- which_wave2=&chinese_triangular[0];
- break;
- case 2 : //显示方波
- which_wave=&Square_wave[0];
- which_wave2=&chinese_square[0];
- break;
- case 3 : //显示锯齿波
- which_wave=&Sawtooth_Wave[0];
- which_wave2=&chinese_sawtooth[0];
- break;
- wave_delay();
- clr_screen();
- disp_chinese();
- disp_rate(400/rate);
- disp_function(which_wave2);
- disp_xy();
- while(!change_wave);
- EX0=1;
- void int1() interrupt 2 //频率选择
- EX1=0;
- wave_delay();
- p++;
- if(p==50)
- p=0;
- rate=p;
- wave_delay();
- rate_num=1/((0.000036+0.000006*rate)*64);
- clc_rate();
- disp_rate(rate_num);
- while(!change_rate);
- EX1=1;
仿真代码.7z
(88.44 KB, 下载次数: 85)
