- #include<reg52.h>
- #include<74HC595.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code table_L[]={0xff,0x7f, 0xff,0xbf, 0xff,0xdf, 0xff,0xef, 0xff,0xf7, 0xff,0xfb, 0xff,0xfd, 0xff,0xfe,
- 0x7f,0xff, 0xbf,0xff, 0xdf,0xff, 0xef,0xff, 0xf7,0xff, 0xfb,0xff, 0xfd,0xff, 0xfe,0xff};
- uchar code table_H[]={
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
- 0x00,0x08,0x40,0x04,0x40,0x02,0xFE,0x7F,0x20,0x01,0x20,0x02,0x00,0x40,0x20,0x49,
- 0x20,0x49,0xFE,0x3F,0x90,0x24,0x90,0x24,0x90,0x20,0x80,0x20,0x00,0x20,0x00,0x00,/*"桂",0*/
- 0x00,0x10,0x80,0x0C,0x80,0x02,0xF8,0x3F,0x40,0x01,0x40,0x0A,0x00,0x04,0x40,0x02,
- 0x40,0x01,0xFC,0x7F,0x20,0x01,0x20,0x02,0x00,0x04,0x00,0x08,0x00,0x08,0x00,0x00,/*"林",1*/
- 0x00,0x00,0x00,0x00,0xE0,0x01,0x20,0x06,0x20,0x05,0x20,0x05,0xFE,0x3F,0x90,0x42,
- 0x10,0x42,0x10,0x42,0xF0,0x41,0x00,0x40,0x00,0x40,0x00,0x38,0x00,0x00,0x00,0x00,/*"电",2*/
- 0x00,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x88,0x00,0x88,0x20,0x88,0x20,0xE4,0x40,
- 0x94,0x3F,0x4C,0x00,0x44,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x00,0x00,0x00,0x00,/*"子",3*/
- 0x00,0x10,0x80,0x08,0x90,0x04,0x90,0x02,0xF0,0x7F,0x48,0x01,0x44,0x01,0x00,0x02,
- 0x50,0x02,0xA0,0x02,0x00,0x02,0xFE,0xFF,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,/*"科",4*/
- 0x00,0x04,0x40,0x04,0x40,0x22,0xFE,0x7F,0x20,0x01,0x20,0x20,0x00,0x20,0x20,0x15,
- 0x20,0x09,0xFE,0x08,0x90,0x16,0x90,0x21,0x00,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"技",5*/
- 0x00,0x00,0x00,0x40,0x80,0x20,0x80,0x10,0x80,0x08,0x80,0x06,0xFE,0x01,0x40,0x02,
- 0x40,0x04,0x40,0x08,0x40,0x10,0x40,0x20,0x00,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"大",6*/
- 0x00,0x00,0x80,0x09,0xE0,0x08,0x44,0x08,0x48,0x08,0x40,0x09,0xA4,0x48,0xA8,0x86,
- 0xA0,0x7D,0xB0,0x04,0x2E,0x04,0x20,0x04,0x60,0x04,0x20,0x00,0x00,0x00,0x00,0x00,/*"学",7*/
- 0x00,0x20,0x40,0x11,0x40,0x0A,0x20,0x04,0xE0,0x0B,0x00,0x40,0x80,0x20,0x70,0x18,
- 0x4E,0x07,0x20,0x08,0xA0,0x10,0x60,0x20,0x20,0x60,0x00,0x40,0x00,0x40,0x00,0x00,/*"欢",8*/
- 0x80,0x10,0x80,0x10,0x88,0x12,0x90,0x1D,0x00,0x10,0xF0,0x13,0x10,0x12,0x08,0x11,
- 0x0C,0x20,0xE0,0x2F,0x10,0x20,0x10,0x61,0xF0,0x61,0x00,0x20,0x00,0x20,0x00,0x00,/*"迎",9*/
- 0x00,0x00,0x40,0x20,0x20,0x30,0xF0,0x03,0x0C,0x18,0x40,0x20,0xA0,0x41,0x18,0x48,
- 0x16,0x52,0xF0,0x43,0x08,0x50,0xA8,0x60,0x18,0x45,0x00,0x08,0x00,0x00,0x00,0x00,/*"您",10*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x33,0xF8,0x33,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",11*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",12*/
- 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,/*"-",13*/
- 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,/*"-",14*/
- 0x00,0x00,0x00,0x06,0x80,0x03,0x00,0x00,0x00,0x10,0x00,0x20,0x00,0x40,0xFC,0x3F,
- 0x00,0x00,0x00,0x00,0x40,0x00,0x80,0x01,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,/*"小",15*/
- 0x00,0x04,0x40,0x02,0x40,0x01,0xFE,0x7F,0x20,0x01,0x20,0x43,0x40,0x21,0xC8,0x1E,
- 0x78,0x00,0x28,0x00,0x64,0xFE,0xA4,0x00,0x20,0x01,0x00,0x02,0x00,0x02,0x00,0x00,/*"桥",16*/
- 0x00,0x00,0x40,0x00,0x88,0x30,0x10,0x0E,0x00,0x40,0x20,0x30,0xA0,0x0D,0x60,0x01,
- 0xA2,0x3E,0x94,0x00,0xD0,0x1E,0x90,0x20,0x10,0x20,0x00,0x20,0x00,0x38,0x00,0x00,/*"流",17*/
- 0x00,0x10,0x80,0x10,0x80,0x08,0x40,0x04,0x40,0x03,0xC0,0x20,0x00,0x40,0xFC,0x7F,
- 0x80,0x00,0x40,0x01,0x20,0x02,0x18,0x04,0x00,0x0C,0x00,0x08,0x00,0x08,0x00,0x00,/*"水",18*/
- uchar L=0,H=0;
- uint t=0,x=0;
- #define h sizeof(table_H)
- void main()
- // extern uint h;
- EA=1;
- ET0=1;
- TMOD=0x01;
- TH0=(65536-1000)/256;
- TL0=(65536-1000)%256;
- TR0=1;
- // h=sizeof(table_H);
- while(1)
- if(L==32)
- L=0;
- H=0;
- void T0_time() interrupt 1
- Input(table_L[L]);
- Input(table_L[L+1]);
- Input(table_H[H+x]);
- Input(table_H[H+x+1]);
- Output();
- L=L+2;
- // if(L==32)L=0;
- H=H+2;
- // if(H==32)H=0;
- t++;
- if(t==100)//移动
- t=0;
- x=x+2;
- if(x>=h-32)x=0;
