查看: 1800|回复: 0
EDA中此程序只能一位数码管显示帮忙看看怎样实现两位数码管显示
ID:723220 发表于 2021-5-9 16:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   LIBRARY IEEE;
   USE IEEE.STD_LOGIC_1164.ALL;
   use ieee.std_logic_arith.all;
   use ieee.std_logic_unsigned.all;
ENTITY Vhdl1 IS
PORT (CP,R,EN:IN STD_LOGIC;
CO:OUT BIT;
Y:OUT INTEGER RANGE 0 TO 10;
LED : out std_logic_vector(6 downto 0));
END Vhdl1;
architecture RT of Vhdl1 is
signal Q:INTEGER RANGE 0 TO 10;
BEGIN
PROCESS(CP,R,EN)
   BEGIN
        IF R='1' THEN Q<=0;
        ELSIF(EN = '1')THEN
        IF(CP'EVENT AND CP='1')THEN
        IF Q=9 THEN
                CO<='1';
                Q<=0;
                ELSE
                Q<=Q+1;
                CO<='0';
        END IF;
        END if;
    END IF;
     Y<=Q;
END PROCESS;
with Q select
  LED<="1000000" when 0,
           "1111001" when 1,
           "0100100" when 2,
            "0110000" when 3,
           "0011001" when 4,
     "0010010" when 5,
         "0000010" when 6,
         "1111000" when 7,
         "0000000" when 8,
     "0010000" when 9,
     "1111111" when others;
END RT;
