- #include<REG52.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit DATA=P1^0;//dht11data端接单片机的P1^0口//
- #define LCD_data P0 //数据口
- sbit LCD_RS = P3^5; //寄存器选择输入
- sbit LCD_RW = P3^6; //液晶读/写控制
- sbit LCD_EN = P3^4; //液晶使能控制
- sbit LCD_PSB = P3^7; //串/并方式控制
- /*定义数字ascii编码*/
- unsigned char mun_char_table[]={"0123456789"};
- uchar code dis1[] = {"温度:"};
- uchar code dis2[] = {"湿度:"};
- uchar RHL,RHH,CL,CH;
- uint m,n;
- //很正要的延时
- void delayus(uchar n)
- while(n--);
- //很正要的延时
- void Delay10ms(void)//12M晶振下延时
- uchar a,b;
- for(b=249;b>0;b--)
- for(a=17;a>0;a--);
- //粗延时
- void delay_ms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=614;y>0;y--);
- //起始
- void Start(void)
- DATA=1;
- delay_ms(10);
- DATA=0;
- Delay10ms(); //主机把总线拉低必须大于
- //18msDHT11能检测到起始信号
- Delay10ms();
- Delay10ms();
- DATA=1;
- delay_ms(1);
- uint integer(uchar x)
- uchar h,l;
- uint n;
- l=x&0x0f;
- h=(x&0xf0)>>4;
- n=h*16+l;
- return n;
- uchar readdht11_byte()
- uchar i,dht;
- for(i=8;i>0;i--)
- dht=dht<<1;
- while(!DATA); //等待50ms
- delayus(30); //延时29us
- if(DATA==1)
- dht=dht|0x01;
- delayus(60);
- else
- return(dht);
- void read_dht11()
- Start();
- DATA=0; //数据线拉低>18ms
- delay_ms(20); //延时>18ms
- DATA=1; //拉高等待
- DATA=1;
- if(!DATA)
- while(!DATA);//
- while(DATA);
- RHH=readdht11_byte();//湿度整数数据
- RHL=readdht11_byte();//湿度小数数据
- CH=readdht11_byte();//温度整数数据
- CL=readdht11_byte();//温度小数数据
- //////////////以下是LCD12864驱动程序////////////////
- /*检查LCD忙状态 */
- /*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
- bit lcd_busy()
- bit result;
- P0=0X00; //关掉数码管的信号。阻止数码管受到P0口信号的影响
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_EN = 1;
- delay_ms(1);
- result = (bit)(P0&0x80);
- LCD_EN = 0;
- return(result);
- /*写指令数据到LCD */
- /*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
- void lcd_wcmd(uchar cmd)
- while(lcd_busy());
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_EN = 0;
- _nop_();
- _nop_();
- P0 = cmd;
- delay_ms(1);
- LCD_EN = 1;
- delay_ms(1);
- LCD_EN = 0;
- /*写显示数据到LCD */
- /*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
- void lcd_wdat(uchar dat)
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 0;
- P0 = dat;
- delay_ms(1);
- LCD_EN = 1;
- delay_ms(1);
- LCD_EN = 0;
- /* LCD初始化设定 */
- void lcd_init()
- LCD_PSB = 1; //并口方式
- lcd_wcmd(0x34); //扩充指令操作
- delay_ms(5);
- lcd_wcmd(0x30); //基本指令操作
- delay_ms(5);
- lcd_wcmd(0x0C); //显示开,关光标
- delay_ms(5);
- lcd_wcmd(0x01); //清除LCD的显示内容
- delay_ms(5);
- /* 设定显示位置 */
- void lcd_pos(uchar X,uchar Y)
- uchar pos;
- if (X==0)
- {X=0x80;}
- else if (X==1)
- {X=0x90;}
- else if (X==2)
- {X=0x88;}
- else if (X==3)
- {X=0x98;}
- pos = X+Y ;
- lcd_wcmd(pos); //显示地址
- //////////////////以上是LCD12864驱动程序////////////////
- void main()//主函数模块//
- uchar i=0;
- lcd_init();
- delay_ms(1500);
- lcd_pos(0,0); //设置显示位置为第一行的第1个字符
- i = 0;
- while(dis1[i] != '\0')
- { //显示字符
- lcd_wdat(dis1[i]);
- i++;
- lcd_pos(1,0); //设置显示位置为第一行的第1个字符
- i = 0;
- while(dis2[i] != '\0')
- { //显示字符
- lcd_wdat(dis2[i]);
- i++;
- while(1)
- delay_ms(1500);
- read_dht11();
- m=integer(RHH);
- delay_ms(1);
- n=integer(CH);
- lcd_pos(0,3);
- lcd_wdat(mun_char_table[n/10]);
- lcd_wdat(mun_char_table[n%10]);
- lcd_pos(1,3);
- lcd_wdat(mun_char_table[m/10]);
- lcd_wdat(mun_char_table[m%10]);
复制代码 |
