查看: 1808|回复: 0
适用于STC15F104W单片机模拟串口接收数据对比函数
ID:917140 发表于 2021-5-25 03:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
typedef unsigned char BYTE;
BYTE RX_Buffer[32]={"                                "};
void RECEIVE_DATA(void) interrupt 4 using 1         //′串口中断
        unsigned char i = 0;
        if(RI == 1)
                temp = SBUF;
                if(num < 32)
                   RX_Buffer[num] = temp;
                   num++;
                        num = 0;
                if(temp == '\n'){
                        num = 0;
                        flagReceive = 1;                //óDêy¾Y½óêÕ
                RI = 0;
对比函数
void isReceiveOKOrTimeout()
        unsigned int count = 0;
        while(count++ < 30000)         //接收到OK或者超时退出
                if(flagReceive){
                        flagReceive = 0;
                        if(
                                RX_Buffer[0] == 'O'
                                && RX_Buffer[1] == 'K'
                                && RX_Buffer[2] == '\r'
                                && RX_Buffer[3] == '\n'
                                break;
收藏收藏1 分享淘帖 顶 踩
