详情见附件!
- #include "config.h"
- sbit DT = P0 ^ 7;
- sbit SCK = P0 ^ 6;
- #define DT_HIGH DT=1
- #define DT_LOW DT=0
- #define SCK_HIGH SCK=1
- #define SCK_LOW SCK=0
- unsigned long ReadCount(void)
- unsigned long Count=0;
- unsigned char i;
- DT_HIGH;
- SCK_LOW; //使能AD
- while(DT); //AD转换等待
- for (i=0;i<24;i++)
- SCK_HIGH; //put down SCK 置高(发送脉冲)
- Count = Count << 1; //下降沿来时变量count左移一位
- SCK_LOW ; //PD SSCK 置低
- if(DT) Count++;
- SCK_HIGH;
- Count = Count ^ 0x800000; //第25个脉冲下降沿来时,转换数据
- SCK_LOW ;
- return(Count);
复制代码- #include "config.h"
- void main()
- float Date ;
- UartInit() ;
- while(1)
- Date = ReadCount() ;
- Date = (unsigned int)((float)Date/4.35+0.05);
- UART_SendStr("The press is ") ;
- UART_SendStrNum(Date);
以上程序51hei提供下载:
压力传感器检测是否有杯子放入.zip
(46.92 KB, 下载次数: 9)
