- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^4;
- sb
- sbit dula=P2^6;
- sbit wela=P2^7;
- uchar code table[]={0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delayms(uint);
- uchar numt0,num;
- void display(uchar numdis)
- uchar bai,shi,ge;
- bai=numdis/100;
- shi=numdis%100/10;
- ge=numdis%10;
- dula=1;
- P0=table[bai];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfe;
- wela=0;
- delayms(5);
- dula=1;
- P0=table[shi];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfd;
- wela=0;
- delayms(5);
- dula=1;
- P0=table[ge];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfb;
- wela=0;
- delayms(5);
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void init()
- TMOD=0x01;
- TH0=(65536-45872)/256;
- TL0=(65536-45872)%256;
- EA=1;
- ET0=1;
- void keyscan()
- if(key1==0)
- delayms(10);
- if(key1==0)
- num=0;
- while(!key1);
- if(key2==0)
- delayms(10);
- if(key2==0)
- num++;
- if(num == 60)
- num=0;
- while(!key2);
- if(key3==0)
- delayms(10);
- if(key3==0)
- if(num == 0)
- num=60;
- num--;
- while(!key3);
- if(key4==0)
- delayms(10);
- if(key4==0)
- while(!key4);
- TR0=~TR0;
- void main()
- init();
- while(1);
- { keyscan();
- display(num);
- void T0_time() interrupt 1
- numt0++;
- if(numt0 == 20)
- numt0=0;
- num++;
- if(num==999)
- num=0;
