有谁能教教我这个代码怎么改吗
内容在附件里,谢谢
- //适用于市场上用量最大的HT6121/6122及其兼容的IC编码。
- //使用外部中断0接收P3.2
- //发射引脚(接PNP三极管b极)
- //PNP三极管e极接2Ω电阻,c极接红外发射管
- #include<reg52.h>
- #include "lcd1602.h"
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define LCD_DATA P0
- #define SBM 0x80 //识别码
- #define m9 (65536-9000) //约9mS
- #define m4_5 (65536-4500) //约4.5mS
- #define m1_6 (65536-1630) //约1.65mS
- #define m_65 (65536-580) //约0.65mS
- #define m_56 (65536-560) //约0.56mS
- #define m40 (65536-40000) //约40mS
- #define m56 (65536-56000) //56mS
- #define m2_25 (65536-2250) //约2.25mS
- sbit IRR = P3^6; //定义发射引脚(接PNP三极管基极)
- sbit LED = P2^3;
- uchar KEY(void);//按键
- void SanZhuan(void);//键值和ASCII码值的转换
- void ZZ(uchar x);//
- void Z0(uchar temp);
- void TT0(bit BT,uint x);
- void YS(uchar time);
- uchar code tab[] = {0X30,0X31,0X32,0X33,0X34,0X35,0X36,0X37,0X38,0X39};
- uchar code set[] = {0X30,0X31,0X30,0X30,0X30,0X30,0X30,0X30,0X30,0X30};
- uchar code tab1[] = {0X4F,0X31,0X32,0X33,0X34,0X35,0X36,0X37,0X4F,0X39};
- uchar code tab2[] = {0X46,0X31,0X32,0X33,0X34,0X35,0X36,0X37,0X4E,0X39};
- sbit IR = P3^3; //接收引脚
- sbit LCD_RS=P2^0;
- sbit LCD_RW=P2^1;
- sbit LCD_EN=P2^2;
- uchar N[4]; //识别码,操作码存放
- uchar X1,X2,X3,X4;
- void XSQ(void);
- typedef unsigned int u16; //???????????
- typedef unsigned char u8;
- sbit IRIN=P3^2; //????
- u8 IrValue[4] = {'\0'};
- u8 Time;
- /*????,i=1?,????10us*/
- void delay(u16 i)
- while(i--);
- void DigDisplay()
- u8 i;
- write_com(0x83);
- for(i=0;i<4;i++)
- if(IrValue[i]/16<10)
- write_data(IrValue[i]/16 + 0x30);
- else
- write_data(IrValue[i]/16 + 0x37);
- if(IrValue[i]%16<10)
- write_data(IrValue[i]%16 + 0x30);
- else
- write_data(IrValue[i]%16 + 0x37);
- /*??????0(????????)*/
- void IrInit()
- IT0=1;//?????
- EX0=1;//????0??
- EA=1; //?????
- IRIN=1;//?????
- void ReadIr() interrupt 0
- u8 j,k;
- u16 err;
- Time=0;
- delay(700); //7ms
- if(IRIN==0) //??????????????
- err=1000; //1000*10us=10ms,????????????
- while((IRIN==0)&&(err>0)) //????9ms??????
- delay(1);
- err--;
- if(IRIN==1) //??????9ms???
- err=500;
- while((IRIN==1)&&(err>0)) //??4.5ms????????
- delay(1);
- err--;
- for(k=0;k<4;k++) //??4???
- for(j=0;j<8;j++) //??????
- err=60;
- while((IRIN==0)&&(err>0))//???????560us?????
- delay(1);
- err--;
- err=500;
- while((IRIN==1)&&(err>0)) //???????????
- delay(10); //0.1ms
- Time++;
- err--;
- if(Time>30) //??3ms ????
- return;
- IrValue[k]>>=1; //k???????
- if(Time>=8) //?????????0.8ms,???1
- IrValue[k]|=0x80;
- Time=0; //?????????
- if(IrValue[2]!=~IrValue[3]) //?? ??? ????? ???? ?????
- return;
- 函数功能: 4×4矩阵键盘
- uchar KEY(void)
- uchar H,L; //行值,列值
- H=0;
- L=0;
- P1 = 0xf0; //将键盘端口行值设为1,列值设为0
- if(P1!= 0xf0) //检测是否有按键按下,如果有则hangval必不为0x0f
- YS(10); //按键去抖动,延时10毫秒
- if(P1!=0xf0) //确实有按键按下
- H = P1&0xf0; //按键后得到按键的行标志位,将行标志位赋值给hangval
- P1 = 0x0f; //翻转键盘接口输出
- L = P1&0x0f; //得到列标志位
- return (H+L);
- return 0;
- 函数功能:散转程序
- 入口参数:v
- // 13 14 15 16
- // 9 10 11 12
- // 5 6 7 8
- // 1 2 3 4
- uchar v;
- v =KEY();
- switch(v)
- case 0x77:ZZ(0x00);v=0;break; //"0"
- case 0xb7:ZZ(0x01);v=0;break; //"1 "
- case 0xd7:ZZ(0x02);v=0;break; //"2 "
- case 0xe7:ZZ(0x03);v=0;break; //"3"
- case 0x7b:ZZ(0x04);v=0;break; //"4 "
- case 0xbb:ZZ(0x05);v=0;break; //"5"
- case 0xdb:ZZ(0x06);v=0;break; //"6"
- case 0xeb:ZZ(0x07);v=0;break; //"7"
- case 0x7d:ZZ(0x08);v=0;break; //"8"
- case 0xbd:ZZ(0x09);v=0;break; //"9"
- case 0xdd:ZZ(0x0a);v=0;break; //"a"
- case 0xed:ZZ(0x0b);v=0;break; //"b"
- case 0x7e:ZZ(0x0c);v=0;break; //"c"
- case 0xbe:ZZ(0x0d);v=0;break; //"d"
- case 0xde:ZZ(0x1e);v=0;break; //"e"
- case 0xee:ZZ(0x1f);v=0;break; //"f"
- default:v=0;break;
- 函数功能:发送主程序
- void ZZ(uchar x)
- TT0(1,m9); //高电平9mS
- TT0(0,m4_5); //低电平4.5mS引导
- /*┈ 发送4帧数据 ┈*/
- Z0(SBM); //识别码
- Z0(~SBM);
- Z0(x); //数据码
- Z0(~x);
- /*┈┈ 结束码 ┈┈*/
- TT0(1,m_65);
- TT0(0,m40);
- /*┈┈ 重复码 ┈┈*/
- while(KEY())
- TT0(1,m9);
- TT0(0,m2_25);
- TT0(1,m_56); //38khz
- TT0(0,m40);
- TT0(0,m56);
- LED = !LED; //指示灯
- LED = 1;
- 函数功能:单帧发送程序
- 入口参数:1帧数据
- uchar v;
- for (v=0;v<8;v++) //循环8次移位
- TT0(1,m_65); //高电平0.65mS
- if(temp&0x01==1) TT0(0,m1_6); //发送最低位
- else TT0(0,m_56);
- temp >>= 1; //右移一位
- 函数功能:38KHz脉冲发射 + 延时程序
- 入口参数:(是否发射脉冲,延时约 x (uS))
- TH0 = x/256; //输入T0初始值
- TL0 =x%256;
- TF0=0; //清0
- TR0=1; //启动定时器0
- if(BT == 0)
- while(!TF0); //BT=0时不发射38KHz脉冲只延时;BT=1发射38KHz脉冲且延时;
- else while(1) //38KHz脉冲,占空比5:26
- IRR = 0;
- if(TF0)break;
- if(TF0)break;
- IRR = 1;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- if(TF0)break;
- TR0=0; //关闭定时器0
- TF0=0; //标志位溢出则清0
- IRR =1; //脉冲停止后,发射端口常态为高电平
- 函数功能:按键消抖 延时程序
- 入口参数:1ms×time (晶振=12MHz)
- uchar i,j;
- for(i=0; i<time; i++)
- for(j=0; j<247; j++)_nop_();
- /*******************************接收*********************************************/
- void delay1(unsigned char t) {
- unsigned char i;
- while(t--)
- for(i = 200; i > 0; i--);
- void LCD_write_instruction(unsigned char LCD_instruction) { //写指令到LCD
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_DATA = LCD_instruction;
- LCD_EN = 1;
- _nop_();
- LCD_EN = 0;
- delay(1);
- void LCD_write_data(unsigned char LCD_data) { //输出一个字节数据到LCD
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_DATA = LCD_data;
- LCD_EN = 1;
- _nop_();
- LCD_EN = 0;
- delay(1);
- void LCD_set_position(unsigned char x) { //LCD光标定位到x处
- LCD_write_instruction(0x80|x);
- void LCD_printc(unsigned char lcd_data) { //输出一个字符到LCD
- LCD_write_data(lcd_data);
- void LCD_prints(unsigned char *lcd_string) { //输出一个字符串到 LCD
- unsigned char i = 0;
- while(lcd_string[i] != 0x00) {
- LCD_write_data(lcd_string[i]);
- i++;
- void LCD_initial(void) { //初始化 LCD
- LCD_write_instruction(0x38);
- LCD_write_instruction(0x0c);
- LCD_write_instruction(0x06);
- LCD_write_instruction(0x01);
- /**********************LCD显示函数************************/
- void XSQ(void)
- while(1) {
- uchar temp1,temp2,temp3,temp4;
- temp1=tab[X4];
- temp2=set[X3];
- temp3=tab1[X1];
- temp4=tab2[X1];
- LCD_set_position(0x88); //LCD换行显示
- LCD_printc(temp3);
- LCD_set_position(0x89); //LCD换行显示
- LCD_printc(temp4);
- LCD_set_position(0xC8); //LCD换行显示
- LCD_printc(temp2);
- LCD_set_position(0xC9); //LCD换行显示
- LCD_printc(temp1);
- SanZhuan();
- /********************** 外部中断函数************************/
- void exint0() interrupt 1
- uint cnt;
- uchar i;
- EX0 =0;
- cnt = 0;
- while(!IR) cnt++; //记录引导码时间
- if(cnt < 1000){EX0=1;return;} //9ms的计数值(12MHz:1000< cnt <1500)
- cnt =0;
- while(IR) if(cnt++ > 400){EX0=1;return;} //防卡死,超时保护(12MHz: > 300)
- if(cnt < 200){EX0=1;return;} //(12MHz不分频: <260)
- for(i=0; i<32; i++) //读取32位位码
- cnt =0;
- while(!IR);
- while(IR) if(cnt++ > 200){EX0=1;return;} //超时保护(12MHz:>=200)
- N[i/8] >>= 1;
- if(cnt>60) N[i/8] |= 0x80; //0和1的计数界线(12MHz:< 109)
- if(N[0] == ~N[1] && N[2] == ~N[3]) //校验识别码,操作码
- X1 =N[0]/16;
- X2 =N[0]%16;
- X3 = N[2]/16;
- X4 = N[2]%16;
- EX0 =1;
- /****************** 主函数 *******************/
- void main(void)
- TMOD = 0x01; //T0 16位工作方式 //发射端口常态为高电平
- IRR=1; //发射端口常态为高电平
- IrInit(); //????0(?????)
- init_lcd(); //???1602
- while(1)
- DigDisplay(); //??
- SanZhuan();
代码.rar
(45.91 KB, 下载次数: 5)
