查看: 2233|回复: 0
适合战舰V3和精英STM32开发板)ATK-ESP8266 WIFI模块(数据接收处理控制成功)
ID:316613 发表于 2021-7-25 14:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "sdio_sdcard.h"
  10. #include "w25qxx.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "text.h"
  14. #include "touch.h"
  15. #include "usart3.h"
  16. #include "common.h"
  17. int main(void)
  18. {
  19.         u8 key,fontok=0;
  20. LED0=0;
  21.         delay_init();                     //延时函数初始化
  22.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
  23.         uart_init(115200);                 //串口初始化为115200
  24.         usmart_dev.init(72);                //初始化USMART
  25.         LED_Init();                                          //初始化与LED连接的硬件接口
  26.         KEY_Init();                                        //初始化按键
  27.         LCD_Init();                                           //初始化LCD
  28.         W25QXX_Init();                                //初始化W25Q128
  29.         tp_dev.init();                                //初始化触摸屏
  30.         usart3_init(115200);                //初始化串口3
  31.         my_mem_init(SRAMIN);                //初始化内部内存池
  32.         exfuns_init();                                //为fatfs相关变量申请内存
  33.         f_mount(fs[0],"0:",1);                 //挂载SD卡
  34.         f_mount(fs[1],"1:",1);                 //挂载FLASH.
  35.         key=KEY_Scan(0);
  36.         if(key==KEY0_PRES&&((tp_dev.touchtype&0X80)==0))//强制校准
  37.         {
  38.                 LCD_Clear(WHITE);                //清屏0
  39.                 TP_Adjust();                          //屏幕校准
  40.                 TP_Save_Adjdata();
  41.                 LCD_Clear(WHITE);                //清屏
  42.         }
  43.         fontok=font_init();                        //检查字库是否OK
  44.         if(fontok||key==KEY1_PRES)        //需要更新字库
  45.         {
  46.                 LCD_Clear(WHITE);                //清屏
  47.                 POINT_COLOR=RED;                //设置字体为红色
  48.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  49.                 while(SD_Init())                //检测SD卡
  50.                 {
  51.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  52.                         delay_ms(200);
  53.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  54.                         delay_ms(200);
  55.                 }
  56.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  57.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  58.                 key=update_font(20,110,16,"0:");//从SD卡更新
  59.                 while(key)//更新失败
  60.                 {
  61.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  62.                         delay_ms(200);
  63.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  64.                         delay_ms(200);
  65.                 }
  66.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  67.                 delay_ms(1500);
  68.                 LCD_Clear(WHITE);//清屏
  69.         }
  70.         atk_8266_test();                //进入ATK_ESP8266测试
  71. }
代码工程下载: 适合战舰V3和精英STM32开发板)ATK-ESP8266 WIFI模块(数据接收处理控制成功).7z (1.3 MB, 下载次数: 45)
参与人数 1黑币 +10 收起 理由
admin + 10 共享资料的黑币奖励!
收藏收藏3 分享淘帖 顶 踩
